kearney(at)shaw.ca Guest
Posted: Sat Sep 22, 2007 9:35 pm Post subject: Puzzled, perplex & confused in the fuse .... |
Hi
As I continue to build I have found that when anything didn’t seem right in the kit, it was because of the then builder not getting the right slot “a” lined up with the right slot “b”. Until now that is..
I have spent the priming and deburring parts associated with Secton 28 – the mid fuse. I started to assemble the forward fuselage bulkhead sub-assembly (Page 28-4) and found that the inboard forward seat rail support just won’t fit. The bolt / rivet holes that should match the corresponding holes on the F1043A L/R & F1043B L/R bulkheads are two close by about 1/8”. The nut plate hole that should match the hole in the F1043B L/R flange is too far forward by 1/16” inch.
The outboard seat rail supports fix perfectly.
I have assembled the inboard seat rail supports correctly (see page 28-3) (there is really only one way to make the supports).
Has anyone else run into this problem? Any suggestions? I would like to press on building this weekend and plan to call Van’s on Monday.
Cheers
Les Kearney
#40643 – frustrated in the fuse ..
egohr1
Joined: 17 Jan 2006 Posts: 38 Location: Oklahoma City
Posted: Sun Sep 23, 2007 4:45 am Post subject: Re: Puzzled, perplex & confused in the fuse .... |
I had the same problem. If you look at the parts in question and compare them to the other seat rail supports and find one of the legs on the angle to be short call Vans, they sent me new parts.
_________________ eric gohr
EGOHR86@alumni.carnegiemellon.edu |
DLIUDVINAITIS(at)aol.com Guest
Posted: Sun Sep 23, 2007 6:04 am Post subject: Puzzled, perplex & confused in the fuse .... |
LES
HAD SAME PROBLEM . THE F1043F-L&R ARE DRILLED WRONG. LOOK AT THE ANGLE AT ITS SIDE VIEW. HOLES TO JOIN BOTH F1043F PARTS TOGETHER ARE ON THE LARGER WIDTH SIDE WHEN IT NEEDS TO BE ON THE SMALLER. CALLED VANS THEY REPLACED BOTH SETS AOK! HOPE THIS HELPS.
DAVE LIUDVINAITIS
#40466
FUSELAGE
See whtarget="_blank">Make AOL Your Homepage.
Posted: Sun Sep 23, 2007 10:58 am Post subject: Puzzled, perplex & confused in the fuse .... |
Eric / Dave
Thanks for the timely response. I am glad I wasn’t seeing things <vbg>.
Perhaps this should be added to Tim’s “Gotcha” list so that builders can check for this problem before they need the parts.
Cheers
Les
#40643 – now only partially confused in the fuse…
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney
Sent: September-22-07 11:33 PM
Subject: Puzzled, perplex & confused in the fuse ....
Hi
Cheers
Les Kearney
#40643 – frustrated in the fuse .. | Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
