acepilot(at)bloomer.net Guest
Posted: Sun Sep 23, 2007 2:34 pm Post subject: Lightening holes in ribs |
Bought an OLD wing kit for my RV-4 recently. The lightening holes need
to be cut out on the ribs. Does anybody have a pet method for
accurately finding the center of the cutout...I will be using a fly
cutter to do the cutting job.
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
sbuc(at)hiwaay.net Guest
Posted: Sun Sep 23, 2007 4:01 pm Post subject: Lightening holes in ribs |
Scott wrote:
Scott, measure the diameters of the lightening holes and make a set of
round templates (cut out of poster board?) with a hole in the middle.
Center a template on the rib in a lightening hole recess, make a mark in
the center hole with a Sharpie, and crank up the fly cutter.
Be careful with the fly cutter, that thing can be deadly!
Sam Buchanan
d-burton(at)comcast.net Guest
Posted: Sun Sep 23, 2007 5:47 pm Post subject: Lightening holes in ribs |
Hi Scott,
You can copy the drawing for the ribs or order a new one from Vans. They
are only $3 or so for a full sized sheet. Cut it out and lay it in the rib
to mark the centers.
Just a silly suggestion:
DON'T get on a roll and cut lightening holes in ALL the ribs. The tank ribs
and ends of the tanks don't get "lightened". It's a hassle to fix them
after they have big holes in them, ask me how I know... And no, it wasn't
me, it was Van's themselves. I got one of the first set of wing kits that
came with the lightening holes done at the factory. Whoever they gave that
task to did them all... tank ribs and all!
Dave
Posted: Sun Sep 23, 2007 6:05 pm Post subject: Lightening holes in ribs |
Ooh, now there's some advice I can really use!! Yes, I probably
would've done just that! I would have gotten the flycutter all set up
and done every hole that was that size in one fell swoop. Thanks for
saving me from having to send MORE money to Van...
Scott
David Burton wrote:
Hi Scott,
Dave
webmaster(at)flion.com Guest
Posted: Sun Sep 23, 2007 7:46 pm Post subject: Lightening holes in ribs |
That's a great idea; I wish I'd thought of it. I carefully did the first
rib and then used the stock I'd just removed to mark all the rest of the
ribs. Even then, I'd clamp the rib in place and rotate the fly cutter by
hand to check where it was cutting. By the way, that removed stock is
useful for making small bits. Even the small holes yielded clamping pads,
bolt washers (for when I was bolting the longerons to the jig), and shims.
Waste nothing!
Patrick Kelley - RV-6A - working on canopy frame
Posted: Mon Sep 24, 2007 3:02 am Post subject: Lightening holes in ribs |
That's a good idea as well (big fender washers!!)! Guess I better buy a
metal "trash" bin to throw all the various bits of leftovers into.
Scott
Waste nothing!
jan(at)claver.demon.co.uk Guest
Posted: Mon Sep 24, 2007 9:02 am Post subject: Lightening holes in ribs |
I found it easy to just draw a couple of lines at 90 deg on the disk to cut
out - Got the centre with no problem that way... Did use a large compass to
draw a circle, just to make sure before getting the fly cutter out ...
I also made a small jig to clamp the rib in place during cutting ... and
watch you hands !!
