		geir_olav(at)c2i.net Guest
				 Posted: Sat Sep 22, 2007 12:59 pm    Post subject: 3 leaf tail spring. Bolt size |
				I am replacing the single leaf tail  spring with a 3 leaf. But I do not know the size of the bolt that is installed.  (then I need a ˝” longer bolt ) now. Think it is a 5/16” bolt, but cant  remember. Anybody that know the original size of the bolt on my Kitfox 4.   (of course I can go over to the airport,  dismantle and find out, but  if one of you know the length and size, I would be  thankful).
 Will just replace the spring BEFORE  it breaks.
 Geir Olav  Řien
 Kitfox  4
 Jabiru  2200.
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Tom Jones
  Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
				 Posted: Sat Sep 22, 2007 6:12 pm    Post subject: Re: 3 leaf tail spring. Bolt size |
				 	  | Quote: | 	 		  | I am replacing the single leaf tail spring with a 3 leaf. But I do not know the size of the bolt that is installed. (then I need a �” longer bolt ) now. Think it is a 5/16” bolt, but cant remember. Anybody that know the original size of the bolt on my Kitfox 4. |
 Grir, I have a Classic 4 with one main leaf and one helper leaf.  My fuselage bolt goes through 2 spring leaves.  It is a AN5-20 (5/16 X 2 inch).  The rear bolt goes through one leaf and the Mall tail wheel bracket, it is a AN7-10A (7/16 X 1 inch).  The two smaller bolts that secure the tail spring clamp catch 2 leaves.  They are AN3-10A (3/16 X 1 inch).
 If you are installing 2 main leaves plus a helper leaf you probably should add 2 (1/4 inch) to each of the above AN dash numbers.
 Now, did I help or confuse you?
  _________________ Tom Jones
Classic IV
Ellensburg, WA |
		Michel
				 Posted: Sat Sep 22, 2007 11:33 pm    Post subject: 3 leaf tail spring. Bolt size |
				On Sep 23, 2007, at 4:12 AM, Tom Jones wrote:
  	  | Quote: | 	 		   If you are installing 2 main leaves plus a helper leaf you probably
 Yes, you will have to do that, Geir. And the bad news is: the main bolt
 is - as I understand it - glued inside the fuselage and you will need
 to heat it for removal.
 Med vennlig hilsen,
 Michel Verheughe
 Norway
 Kitfox 3 - Jabiru 2200
		Lynn Matteson
				 Posted: Sun Sep 23, 2007 4:34 am    Post subject: 3 leaf tail spring. Bolt size |
				Depending on how the original builder built the plane, this bolt may
 or may not be glued in place. In building mine I glued (structural
 adhesive...Hysol 9460) the bolt in place, and when I needed to remove
 it for the thicker spring/longer bolt, it was a simple matter to
 shield the fabric with a metal plate with a hole drilled in it, then
 heat the bolt on the threads. The heat will travel up the bolt,
 soften the adhesive and allow the bolt to be pushed up into the
 fuselage. I have an inspection hole nearby to facilitate work done in
 this area. If you don't have this hole, I think you'll have to remove
 the hort. stab to reach the area....maybe not.
 Lynn Matteson
 Kitfox IV Speedster  w/Jabiru 2200
 flying w/400+ hrs
 On Sep 23, 2007, at 3:32 AM, Michel Verheughe wrote:
 > numbers.
  bolt is - as I understand it - glued inside the fuselage and you
  will need to heat it for removal.
  Med vennlig hilsen,
  Michel Verheughe
  Norway
  _________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
		dave
		dave
		dave
				 Posted: Mon Sep 24, 2007 5:42 am    Post subject: Re: 3 leaf tail spring. Bolt size |
				another bolt put in
 test flew
 seems ok  now
  _________________ Realtime Kitfox movies to separate  the internet  chatter from the truth
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
		Float Flyr
				 Posted: Mon Sep 24, 2007 9:54 am    Post subject: 3 leaf tail spring. Bolt size |
				Hope it's a longer one and "in safety".
 Noel
 [quote] --
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		dave
		rexinator(at)gmail.com Guest
