avex rivet question clarification
rwripper(at)verizon.net
PostPosted: Wed Sep 26, 2007 4:09 am    Post subject: avex rivet question clarification Reply with quote
Thanks for the rivet puller side (the formed head) criteria Ralph.
My real concern was regarding the backside/otherside acceptance criteria of the pulled rivet.
Thanks, Dick
DaveG601XL
PostPosted: Wed Sep 26, 2007 4:36 am    Post subject: Re: avex rivet question clarification Reply with quote
Dick,
Chris Heintz's Construction Standards manual as well as the Avex spec do not specify a shop head dimensional requirement. They only publish a grip range spec. If the actual grip falls into this range, I guess it is assumed that the shop head dimensions are good. FYI grip range for the A4 rivet = 0-1/4" and A5 = 0-5/16"
Good luck,
David Gallagher
Cincinnati, OH area
Gig Giacona
PostPosted: Wed Sep 26, 2007 6:42 am    Post subject: Re: avex rivet question clarification Reply with quote
I've pulled hundreds if not thousands of rivets on my plane and I can't think of one that has failed that there wasn't a problem on the finished side of the rivet.
So I'm pretty sure that if the shiny side is OK the ship side will be as long as you are using the proper rivets.
W.R. "Gig" Giacona
601XL Under Construction
Jeyoung65(at)aol.com
PostPosted: Wed Sep 26, 2007 7:07 am    Post subject: avex rivet question clarification Reply with quote
In so far as the grip length of pop rivets has came up again I will add my two cents. Check the way rivet grip length are given in all manuals. For a button heador dome head rivet the grip length is from the BOTTOM of the head. Now on a countersunk rivet the grip length is from the TOP of the head. David and all others that I have seen on this site list Avex's grip length for the countersunk rivets. Zenith has chose to take a countersunk rivet and form the into a button head but does not change the grip lenth. Has anyone who is in the know taken a countersunk rivet and installed it through a max. grip material and checked the formed end? Will the rivet be formed OK? Jerry of GA
Make AOL Your Homepage.
craig(at)craigandjean.com
PostPosted: Wed Sep 26, 2007 7:33 am    Post subject: avex rivet question clarification Reply with quote
In their construction standards (page 10) Zenith lists grip lengths of 0-1/4 inch (0-6mm) for the A4 and 0-5/16 inch (0-8mm) for the A5. Are they allowing for the difference? Do their numbers differ from the Avex docs?
www.zenithair.com/pdf-doc/zenair%20construction%20standards%20draft%201-07.pdf
-- Craig
jeyoung65(at)aol.com
PostPosted: Wed Sep 26, 2007 11:35 am    Post subject: avex rivet question clarification Reply with quote
The grip length on Zenithair and Avex are the same so there is no allowance for the difference. Jerry-GA
gboothe5(at)comcast.net
PostPosted: Fri Sep 28, 2007 9:23 am    Post subject: avex rivet question clarification Reply with quote
To Whoever was Concerned About the Inside Dimension of an Avex Rivet,
The grip length is only important in that the 'nubbed' end needs to be
buried in enough material to never vibrate out.
No matter how long the pop rivet is, the inside dimension will always be the
same. The nub merely pulls through the rivet until it bottoms out and
breaks. If you use the right size, or too long, the dimension is still the
same. Obviously this is unlike a driven rivet that will flatten and spread
out.
You do not need to worry about the bottom end. As someone else pointed out,
you are making a major change to the head of the rivet, and you need to obey
ZAC's dimensions on modifying the head.
Gary Boothe
Cool, CA
601 HDSTD, WW Conversion 90% done,
Tail done, wings done, working on c-section
[mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of
Sent: Wednesday, September 26, 2007 7:56 AM
Subject: Re: Re: avex rivet question clarification
winmail.dat
 Filename:  winmail.dat
 Filesize:  6.14 KB
 Downloaded:  485 Time(s)
PostPosted: Fri Sep 28, 2007 7:41 pm    Post subject: avex rivet question clarification Reply with quote
In a message dated 9/28/2007 1:25:33 P.M. Eastern Standard Time, gboothe5(at)comcast.net writes:
I think this is the question, how do you inspect this requirement?
No correction for this head change has been make with regard to the grip length! What about the fact the ZAC and Avex give the same max. grip length even though they reduced the grip length by the thickness of the rivet head?
same.
I understand the inside dimension does not change. The length of the rivet also does not change so if you form the head down (Dome the head) the length of the rivet grip length is reduced and Avex set the max. grip based on the rivet being used as a countersunk rivet. Thus the "nubbed" end is not buried. Take a .250 thickness section of material and install a 1/8 rivet. Look at the "nubbed", think it
will not vibrate out?
You had an attached file on your e-mail that I could not open, what was it?
Jerry of GA
See what's new at Make AOL Your Homepage.
PostPosted: Fri Sep 28, 2007 9:00 pm    Post subject: avex rivet question clarification Reply with quote
Jerry,
I did not attach anything. I merely hit “REPLY.”
My opinion is that you are over thinking this. You seem to be concerned about losing .025 from the change from a countersink to the modified head; when the rivets are measured in fractions of an inch. Here is a quote from Mr. Heintz:
“…One other very determinant factor for selecting the Avex rivets is that they are "grip" insensitive. The standard Avex rivets will join from grip 0 to grip 1/4" (6 mm) with the same rivet…”
Why would you try to use an 1/8” rivet if you were concerned about its length? Let common sense prevail…
Gary Boothe
Cool, CA
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Jeyoung65(at)aol.com
Sent: Friday, September 28, 2007 8:41 PM
[b]I think this is the question, how do you inspect this requirement? [/b]
[b]No correction for this head change has been make with regard to the grip length! What about the fact the ZAC and Avex give the same max. grip length even though they reduced the grip length by the thickness of the rivet head?[/b]
same.
[b]I understand the inside dimension does not change. The length of the rivet also does not change so if you form the head down (Dome the head) the length of the rivet grip length is reduced and Avex set the max. grip based on the rivet being used as a countersunk rivet. Thus the "nubbed" end is not buried. Take a .250 thickness section of material and install a 1/8 rivet. Look at the "nubbed", think it[/b]
[b] will not vibrate out?[/b]
[b]You had an attached file on your e-mail that I could not open, what was it?[/b]
[b]Jerry of GA[/b]
PostPosted: Sat Sep 29, 2007 5:38 am    Post subject: avex rivet question clarification Reply with quote
Gary, Using the 1/8 rivet was just to get you to look as one. As you are building an 601HDS your center section should be the same as my Dwg. 6-V3 dated 08/04. Look at your two rivets in the outer ribs where the drawing call for A-5 rivets. Material thickness is: 6V5-1 (.025), "L" angle (.025), 6V4-1HD (.040), 6V4-5 (.125), 6V4-6HD (.125) Total= .340. We I installed these rivets I question the rivet so took a sample using these mat'l thickness to the EAA meeting and two difference members said it was not good. Jerry
See what's new at AOL.com and Make AOL Your Homepage.
PostPosted: Sat Sep 29, 2007 7:24 am    Post subject: avex rivet question clarification Reply with quote
Jerry,
Point taken, however it looks as there are some differences in our plans. For me, 6-V3 is a wing drawing. But I have supplementals for the HDS which replace that A5 rivet with an AN3 bolt. On the center section, I also have a supplemental as I am building a tail dragger. All nose ribs have a notch for the spar cap and are not riveted at that location.
However, you did shine light on the fact that where the gear support crosses the spar, there will definitely be a need for a longer rivet. 4 of these will be needed by me, so I will merely buy some ‘x-tra longs.’
Interesting that AC43.13 has no verbage concerning Avex rivets.
Gary Boothe
Cool, CA
Sent: Saturday, September 29, 2007 6:37 AM
PostPosted: Wed Oct 03, 2007 8:11 pm    Post subject: avex rivet question clarification Reply with quote
In a message dated 9/29/2007 11:25:37 A.M. Eastern Daylight Time, gboothe5(at)comcast.net writes:
Gary, I used CherryMax rivets and did not try to "done" the head.
I have found no one who has much on the pop rivet inspection. Have fun building. Jerry
See what's new="_blank">Make AOL Your Homepage.
