Space for radio mounting
j.codd(at)btopenworld.com
PostPosted: Wed Sep 26, 2007 5:20 am    Post subject: Space for radio mounting Reply with quote
Hi Pat, I assume that you are using an Icom radio as do most of us here in the Uk, if so there is space to mount it on the left of the main instrument pod, mounted in this position it doesn't interfere with getting in and out of the cockpit, and also it is clear of your legs/knees when flying, in this position it is very readily accessible, if you need photos of how I did mine, post me your e-mail address and I'll send you a couple of photos.
John Codd Sandtoft UK.
pj.ladd(at)btinternet.com
PostPosted: Wed Sep 26, 2007 7:08 am    Post subject: Space for radio mounting Reply with quote
Hi Pat, I assume that you are using an Icom radio as do most of us here in the Uk, >>
Hi,
I do indeed use an Icom, bought from John Hauck incidentally. I would greatly appreciate any instructions, pics etc.
Thanks in anticipation
Pat
PostPosted: Wed Sep 26, 2007 7:13 am    Post subject: Space for radio mounting Reply with quote
post me your e-mail address and I'll send you a couple of photos.>>
Sorry John,
I missed that bit.
Here it is
pj.ladd(at)btinternet.co.uk (pj.ladd(at)btinternet.co.uk)
PostPosted: Wed Sep 26, 2007 7:20 am    Post subject: Space for radio mounting Reply with quote
Patrick:
John can attach them to a post to the Kolb List and we can all benefit from the photos.
PostPosted: Wed Sep 26, 2007 7:50 am    Post subject: Space for radio mounting Reply with quote
Right John,
either way suits me if he can do that
Pat
dcreech3(at)hotmail.com
PostPosted: Wed Sep 26, 2007 4:37 pm    Post subject: Space for radio mounting Reply with quote
Can anyone offer any suggestions as to what headsets work best (in a Kolb Firestar context) with an Icom radio? I'm replacing my old Yaesu radio which went kaput, but now find that my old Lightspeed Solo headset (which I really like, for its quietness) won't work with the new Icom A6 radio! ( it DOES work with the older Icom A3, but that's beside the point, since they're no longer sold) . . . I've pretty much accepted that I'm going to have to buy a new headset too . . . Any suggestions?
Lee
Firestar II
Subject: Re: Space for radio mounting
Date: Wed, 26 Sep 2007 16:46:53 +0100
Right John,
Pat
get=_blank>http://www.matronics.com/Navigator?Kolb-List
p://forums.matronics.com
Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy! Try it! [quote][b]
russ(at)rkiphoto.com
PostPosted: Wed Sep 26, 2007 4:46 pm    Post subject: Space for radio mounting Reply with quote
Lee, why not go to your local friendly avionics man? He knows WHY a headset won't work, and if it can be made to. Isn't it time for some expert advice?FWIW
On Sep 26, 2007, at 8:35 PM, LEE CREECH wrote:
[quote]Can anyone offer any suggestions as to what headsets work best (in a Kolb Firestar context) with an Icom radio?  I'm replacing my old Yaesu radio which went kaput, but now find that my old Lightspeed Solo headset (which I really like, for its quietness) won't work with the new Icom A6 radio! ( it DOES work with the older Icom A3, but that's beside the point, since they're no longer sold) . . .  I've pretty much accepted that I'm going to have to buy a new headset too . . .  Any suggestions?   LeeFirestar II
From: pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)To: kolb-list(at)matronics.com (kolb-list(at)matronics.com)Subject: Re: Space for radio mountingDate: Wed, 26 Sep 2007 16:46:53 +0100John can attach them to a post to the Kolb List and we can all benefit from the photos.
Right John,
Pat
get=_blank>http://www.matronics.com/Navigator?Kolb-Listp://forums.matronics.com
         - The Kolb-List Email Forum - class="Apple-converted-space"> --> http://www.matronics.com/Navigator?Kolb-List              - NEW MATRONICS WEB FORUMS - class="Apple-converted-space">   --> http://forums.matronics.com
d-m-hague(at)comcast.net
PostPosted: Wed Sep 26, 2007 5:49 pm    Post subject: Space for radio mounting Reply with quote
Lee, you probably need a mike amplifier, along with whatever plug adapters
are necessary. I'm pretty sure (gonna try it tomorrow if I don't go
flying) that my Comtronics helmet won't work with my new A24 (same as the
A6 but with VOR), but an electronics guru friend sketched up a simple amp
circuit to boost the helmet mike to the signal level the A6/A24 is
expecting. If it works I'll make it available.
Some good information on communications equipment at:
http://www.aerialpursuits.com/comms/menu.htm
-Dana
"I'm a lawyer." "Honest?" "No, the usual kind."
bill_joe(at)bellsouth.net
PostPosted: Wed Sep 26, 2007 6:03 pm    Post subject: Space for radio mounting Reply with quote
Hey Guy's...
Here is the way I have my radio set-up .Don't look at my automotive wrinkle paint that is all coming off. Now I get to do it all over again.I use a kneeboard that I strap to my right leg that hold my GPS and charts. It places the GPS in good viewing position. The holder for my ICOM A-22 is also in good viewing and easy to see when changing the frequencies.
I hope this helps.
Bill Futrell
 Filesize:  188.3 KB
 Viewed:  470 Time(s)
 Filesize:  190.99 KB
 Viewed:  472 Time(s)
 Filesize:  195.69 KB
 Viewed:  484 Time(s)
PostPosted: Thu Sep 27, 2007 4:06 am    Post subject: Space for radio mounting Reply with quote
Hi Bill,
thanks for taking the trouble but unfortunately I have the central stick set up. I should have mentioned that, I suppose.
thanks anyway
Pat
by0ung(at)brigham.net
PostPosted: Thu Sep 27, 2007 7:23 am    Post subject: Space for radio mounting Reply with quote
With the radio I am using... sporties A300 I had to decrease the mike
gain to keep the background noise to a minimum.
Boyd
herbgh
PostPosted: Thu Sep 27, 2007 8:06 am    Post subject: Space for radio mounting Reply with quote
Old Frugal Herb had a radio like that...100 dollar amp was
needed....So---I unhooked the internal mike and brought a couple of
shielded wires out of the case and used the regular non amplified mike.
By the way...bro Pike... how did the 30 dollar noise reduction , wally
world head set work? No reason why it should not..
I am waiting for them to go on sale! Smile Herb
On Thu, 27 Sep 2007 09:23:12 -0600 "boyd" <by0ung(at)brigham.net> writes:
a Kolb
radio
(which
radio!
adapters
as the
simple amp
the mike
Boyd
Richard Pike
PostPosted: Thu Sep 27, 2007 9:18 am    Post subject: Space for radio mounting Reply with quote
Funny you should ask, I just got done modifying the jack box in the MKIII so
I can listen to both VHF & the mp3 player on the trip to Chestnut Knolls
Saturday. It works real well, cuts the noise a lot and lets you hear ATC or
your mp3 player as well. A little extra hassle putting in the earbuds before
you put the headsets on, but I'm used to it, have been using the same noise
canceling gizmo w/earbuds for several months now when motorcycle riding, and
I just take it for granted.
Richard Pike
MKIII N420P (420ldPoops)
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
gaman(at)att.net
PostPosted: Thu Sep 27, 2007 10:23 am    Post subject: Space for radio mounting Reply with quote
Pat,
I'm not familiar with your aircraft but on my mark 3c I mounted the icom on the back of the windshield at the top by the steel U shaped frame.I bent a 2" wide 10" long piece of lexan almost double, so it would stand on a table in the shape of the letter A,then slipped it over the steel frame one leg flat on the windshield face,the other hanging down the inside not quite parallel to the back of the windshield.Cut out a small rectangle to clear the back of that flat loop on the radio battery and velcroed the radio to the lexan.Attached the A frame lexan to the frame with 3 rivits,ran the wires around the frame and down past the flap handle support to the hot box .I have a fiber glass fairing between the windshield and wing leading edge so it may be different on yours.
pat ladd <pj.ladd(at)btinternet.com> wrote:[quote]
PostPosted: Thu Sep 27, 2007 11:02 am    Post subject: Space for radio mounting Reply with quote
Hi Pat, I went down to Sandtoft Airfield today to do the first 25hr service/oil change etc on the 2200 Jabiru on my Mk3 Extra, as promised I took some photos of the radio/gps setup in my plane, as you will see the Icom Ic-A24E radio is attached to the left hand side of the instrument pod, this is well out of the way when getting in and out and also does not interfere when flying, the main support is a mobile phone mounting on an 8"flexible which has a suction cup for mounting to the console, additional support for the top end of the mount is in the form of a tie wrap attaching the top end of the flexible to the small metal plate on the left of the instrument pod (just slacken the two fixing screws a touch and thread the tie wrap through) tie wrap all cables and leads to the flexible support, works a treat, firm support for the radio and easily accessible, as for your previous enquiry regarding antennas, the Lynx short flexible VHF antenna works fine although we are getting better results with an antenna from Montreal, Canada, the Miracle Whip Antenna, this is a 1/2 wave diapole antenna against the Lynx's 1/4 wave, it certainly produces superior clearer reception, the manufacturers web site is j.codd(at)btopenworld.com (j.codd(at)btopenworld.com).
 Filesize:  243.84 KB
 Viewed:  468 Time(s)
 Filesize:  170.65 KB
 Viewed:  456 Time(s)
