melkel2000
Posted: Wed Sep 26, 2007 12:55 pm Post subject: Question about an Aux Alternator |
Hi all:
This is my first post to this list. Do I get a prize?
I have a couple of questions regarding how to go about wiring up my alternator and my Aux Alt. I want to simplify the Nuckolls "all electric airplane" since 1) I'm building a VFR airplane and 2) the only reason I'm even considering an Aux Alt is that it already is installed in the used engine I bought. Specifically, I would like to eliminate the LR-3 Alternator Controller.
Issue 1: It it ok to leave both the aux alt and the main alt in the ON position during flight? I would think that the outputs act much like batteries in parallel so there shouldn't be an issue right?
Issue 2: Is it permissible to wire the output of both alternators to a single shunt? I would like my ammeter to read the output of both alternators as a system. I would check the output of each alternator during start up by turning off each and checking the ammeter. If the main alternator goes off line in flight, I will have an idiot light come on. My ammeter will still show output but with the light on, I'll know that power is coming from the Aux and not the main.
Issue 3: As far as determining the exact wiring diagram to use, can I just treat each system as a separate system? In other words, can I use, for instance, the Aux Alt side of the electric airplane figure in the Nuckolls book and pair it with a simplified main alt layout?
Kelly Johnson
RV-9A in progress
nuckolls.bob(at)cox.net Guest
Posted: Wed Sep 26, 2007 2:38 pm Post subject: Question about an Aux Alternator |
At 01:55 PM 9/26/2007 -0700, you wrote:
Hi all:
airplane"
Keep in mind that these drawings have been distilled down
over the past 10-20 years to minimize parts count, installation
and operating complexity while maintaining a favorable failure
mode effects analysis.
| Quote: | since 1) I'm building a VFR airplane and 2) the only reason I'm even
I bought.
Which alternator is installed?
| Quote: | Specifically, I would like to eliminate the LR-3 Alternator Controller.
For which alternator?
| Quote: | Issue 1: It it ok to leave both the aux alt and the main alt in the ON
How will you be notified if one of the alternators
fails?
| Quote: | Issue 2: Is it permissible to wire the output of both alternators to a
If you have both alternators on line all the time AND
the aux alternator is being controlled by an SB-1 regulator,
then normal operating modes call for both alternators to
be on all the time but the aux alternator is set for about 1
volt lower. Hence, while the main alternator is working, the
aux alternator relaxes and the SB-1's annunciator light is dark.
If the main alternator fails, but bus votlage sags and the
aux alternator picks up the loads. If the load exceeds 20A
the annunciator flashes until you shed loads to some value
below 20A wereupon the light stop flashing. This is Figure
Z-12 but with the SB-1 regulator not being substitutable.
| Quote: | My ammeter will still show output but with the light on, I'll know that
Why worry about the ammeter at all? You have some
more rudimentary architecture and operating protocols
to figure out. The elegant solution doesn't even call
for an ammeter.
| Quote: | Issue 3: As far as determining the exact wiring diagram to use, can I just
Now I'm totally lost. You began with a discussion of the
"all electric" (on a budget) which would be Z-13/8 but mentioned
and LR-3 regulator which suggests an SD-20. Don't know what
your vision is for the separation between systems.
Let's begin with a list of the hardware you have in hand
or expect to use. What kind of alternators, what kind of
regulators? Now, pick one of the z-figures that comes
close to what you think you'd like to craft and lets go
from there.
melkel2000
Posted: Wed Sep 26, 2007 3:07 pm Post subject: Re: Question about an Aux Alternator |
Hi Bob:
The main alternator will be a Plane Power 60 A. The Aux Alt is one of those SD-8s. The regulator supplied with it I presume is one that was purchased with the alternator. I'm not a home at the moment so I can't check the specific model number, but I will.
I would like to eliminate the controller for either alternator. I'm hoping that the built in OV protection in the Plane Power will be sufficient for that one. I'm hoping to use the idiot light function in that alternator as well for only that alternator. There is no need to have a light for the aux alt in my case.
My thought about knowing if there is a failed alternator in flight is as follows:
1-If the Aux alt fails, I will not know nor do I care. I'm flying VFR and the Aux Alt is only there because it came with the engine. I can, however, check each alts function on the ground before every take off by 1) watching the idiot light go out which tells me the main alt is functioning and 2) by shutting down the main alt and then enabling the Aux. If the ammeter shows a current, I have a good alternator. Right?
2-If the main alt fails, the idiot light comes on but the ammeter will not show a discharge if 1) the aux alt has enough current to keep up with the load and 2) I can in fact wire both alts to the same shunt.
As far as you being totally lost, that makes two of us! I'm trying to understand all this.
From what I gather from the All Electric Airplane is that the intention is to have a seamless switch from the main alt to the aux. Maybe I'm wrong here. For my situation, I don't necessarily need seamless. I'm perfectly fine with having to throw a switch to activate the back up.
I will look again at the various examples in the book, will pick one, and go from there.
The reason for leaving out the LR-3 controller is once again the fact that had the engine not come with an aux alt, I wouldn't even be using one. If it's going to cost me hundreds of dollars to make it function, I'll take it out and put a plate over the hole.
Thanks!
Kelly
melkel2000
Posted: Wed Sep 26, 2007 4:55 pm Post subject: Re: Question about an Aux Alternator |
Hi again Bob:
I do in fact have a B&C regulator.
Let's use Figure Z-13 as the baseline. Two changes I would like to make:
1-Wire both alternators to a single shunt.
2-Eliminate the LR-3.
KJ
Posted: Wed Sep 26, 2007 5:22 pm Post subject: Question about an Aux Alternator |
At 05:55 PM 9/26/2007 -0700, you wrote:
Hi again Bob:
KJ
Which aux alternator do you have? If an SD-8 why not
wire exactly like Z-13/8 and forget the shunts completely
or put a shunt in the main alternator only. When you're operating
from the SD-8, your loads are KNOWN and PREDICTABLE. There's
good reasons for wiring as shown. See description for Z-13
on page 3 of
http://aeroelectric.com/articles/Rev11/AppZ_R11K.pdf
You can use any other combination of voltage regulator,
http://www.aeroelectric.com/Pictures/Regulators/Ford_SS_Reg.jpg
ov protection
http://www.aeroelectric.com/Pictures/Products/OVM-14_C.jpg
and low voltage warning
http://www.aeroelectric.com/Pictures/Products/9005_OBS/9005.jpg
to replace an LR3 . . . but if you already have
one, why do you want to replace it?
Posted: Wed Sep 26, 2007 5:53 pm Post subject: Question about an Aux Alternator |
At 04:07 PM 9/26/2007 -0700, you wrote:
Hi Bob:
Aha! I've responded to what may have been an earlier post
of yours. Disregard. Okay, a PP/60 and SD-8. You don't
need the LR-3 and in fact it's not even useable with this
combination. You still need active notification of low voltage.
| Quote: | I would like to eliminate the controller for either alternator. I'm hoping
that one.
yes
| Quote: | I'm hoping to use the idiot light function in that alternator as well
no . . . the inadequacy of the built in alternator
failure warning has been discussed at length here on the
List. I recommend separate, independent notification of
low voltage.
| Quote: | There is no need to have a light for the aux alt in my case.
Nor is one shown on Z-13 . . .
| Quote: | My thought about knowing if there is a failed alternator in flight is as
follows:
There are good reasons why Z-13 is crafted the way it is for
both active notification of low voltage and orderly step down
to 8A e-bus loads in case of main alternator failure. The independent
shunts offer ability to pre-flight each alternator independently of
the other.
| Quote: | >From what I gather from the All Electric Airplane is that the intention
Don't know what you consider "seamless". The multi-layered
architecture provides means by which all equipment is pre-flight
testable, offers adequate notification of certain failures in flight
and places enough separation between layers that no single failure
of plan-A (or plan-B) precipitates down into the their respective
subordinate plans.
| Quote: | I will look again at the various examples in the book, will pick one, and
go from there.
I'm not sure what this means. The SD-20 aux alternator is usually
shipped with an SB-1 regulator. If the LR-3 came with your engine,
it was probably intended for use with some alternator other than
the SD-20. If you already have an SD-8, then do you have the rectifier
regulator that goes with it? See:
http://www.aeroelectric.com/Pictures/Alternators/sd8.jpg
The PlanePower will have its own regulator and ov protection
so the only thing you are missing is independent notification
of low voltage. Obviously you can wire your airplane any
way you wish but the Z-figures as published represent my best
recommendations for their respective applications. If I were
building an airplane today, it would have Z-13/8 in it.
mprather(at)spro.net Guest
Posted: Wed Sep 26, 2007 6:07 pm Post subject: Question about an Aux Alternator |
Run both alternator b-leads through one hall effect sensor - (requires a
controller circuit or different kind of ammeter)?
Matt-
Posted: Wed Sep 26, 2007 6:19 pm Post subject: Question about an Aux Alternator |
At 08:02 PM 9/26/2007 -0600, you wrote:
That works! I have a number of readers who have done
just that. Of course, the hall effect ammeter needs to
run from the e-bus so that it is ALWAYS active under
any operating condition.
andrewbutler(at)ireland.c Guest
Posted: Thu Sep 27, 2007 4:07 am Post subject: Question about an Aux Alternator |
Hi Bob,
Do you supply the AEC9005? I don't see it on your website
Can this module be used to monitor the voltage on the Endurace bus powered by an SD-8 during main alt out? I know that the load is supposed to be predictible, but lets say I wanted to use the AEC9005 to check the SD-8 during pre-flight checks?
Andrew.
[quote]---
Posted: Thu Sep 27, 2007 4:51 am Post subject: Question about an Aux Alternator |
At 12:04 PM 9/27/2007 +0000, you wrote:
| Quote: | Hi Bob,
It's slated to be replaced by the AEC9011 later this year
and there are other suppliers of similar products.
| Quote: | Can this module be used to monitor the voltage on the Endurace bus powered
Yes, in fact I have some builders who have used the lv warning
system to do selective load shedding (clumsy but it works). Keep
turning things off until the lv warning light stays out. It's
far better to have plan-b loads pre-selected and part of your
alternator-out ops checklist.
| Quote: | I know that the load is supposed to be predictible, but lets say I wanted to
Yes, but the "test" may be time-dependent . . . and it
presupposes that total loads on the system do not exceed
the SD-8 output capability at pre-flight run-up speeds.
Far better that you sense the output current and simply
observe that the SD-8 picks up a load irrespective of
bus voltage and system loads. Does your system have any
other voltmeter functions in it? For example, with minimum
loads on system, when you turn the main alternator off
and the SD-8 on, any rise in bus voltage no matter
how slight is a good indication that the SD-8 is alive
and well.
( "Problems are the price of progress. )
( Don't bring me anything but trouble. )
( Good news weakens me." )
( -Charles F. Kettering- )
melkel2000
Posted: Thu Sep 27, 2007 7:35 am Post subject: Re: Question about an Aux Alternator |
I do indeed have the rectifier regulator...at least what I have looks like the one in the picture Bob linked. There is no number on it.
I don't physically have the LR-3. I was referring to it in regards to the Z-13.
Regarding the hall effect sensor comment. I'm running a Dynon FlightDEK-D180 as my main instrument. It has the ability to read current and voltage. In its manual, it states that for current, I have the option to use the GRT CS-01 hall effects sensor. So running both B leads through this sensor will do what I'm looking to do and that is to read the current of both alternators combined. The reason for this is that I don't want to have a separate ammeter for the aux alternator. I want it all to go through the Dynon. I suppose I could have some sort of selector switch set up to determine which alternator the Dynon is displaying as well right?
I don't think I ever got an answer on this one: Is it not a good idea to run both alternators to a single shunt?
Bob has commented that the SD-8 has known qualities and suggested that a case can be made for not using an ammeter for it. I personally want the ability to look at the output in flight. If a light comes on I'd like to have a warm fuzzy that the SD-8 is indeed putting out.
OK, to sum it up, this is what I understand:
1-Yes, the LR-3 can be replaced in the Z-13 diagram by the Plane Power alternator because its built in OV protection circuit is adequate.
2-Bob says that the Plane Power alternator warning light output is not recommended and that a separate warning system per Bob's book should be used.
3-Normal operation would be to run both alternators simultaneously because the rectifier regulator for the aux is set for 1 volt lower and will relax during normal operation.
Do I understand this correctly?
frank.hinde(at)hp.com Guest
Posted: Thu Sep 27, 2007 7:57 am Post subject: Question about an Aux Alternator |
I bought 2 shunts and a mini double pole (on-on) switch from radio
shack. Th panel is labelled "alt1/2" and the output of the switch wired
to the Dynon.
I can simply select which alt I wish to measure that way.
Frank
RV7a
Posted: Thu Sep 27, 2007 8:40 am Post subject: Question about an Aux Alternator |
A shunt is used to measure current in a wire by inserting a known, small
resistance in that wire. A meter is wired across this known resistance.
The reading on the meter is calibrated to show current based on how much
voltage is dropped across the shunt. Man shunts are at full scale with a
50mV drop.
In order to run to a single shunt on both alternators, the output of the
alternators would need to be hard wired together. Certain fail modes on
one alternator might lead to the other alternator not being able to
generate any output. Additionally, having both alternators wired together
may make regulation a challenge.
If you'd like to use shunt vice hall effect, I propose that you use two
shunts and then add a switch so that you can select which is driving your
instrumentation.
Matt-
<aeroncaflyer(at)gmail.com>
Z-13.
used.
http://forums.matronics.com/viewtopic.php?p=136778#136778
melkel2000
Posted: Thu Sep 27, 2007 8:50 am Post subject: Re: Question about an Aux Alternator |
Thanks! The switch is a great idea but how about this?
I'm really more interested in what is going in and out of the battery. I want to know if it is charging or discharging. If it's charging, I don't necessarily care where the juice is coming from. My idiot lights will tell me if my main alt is inop anyway.
So, what if I eliminate the two shunts as depicted in Figure Z-13 and put one in the appropriate line leading eventually to the battery but not in the starter circuit? That should do what I'm looking for right?
Posted: Thu Sep 27, 2007 9:20 am Post subject: Question about an Aux Alternator |
Sure that will work, I believe that's one of the ways Dynon suggests you
wire up the shut anyway.
It is debatable whether you even need an ammeter at all..I.e if you set
your low voltage alarm for 12v and use the Dynon audible output then you
know when you have a low battery voltage and therefore a malfunctioning
alternator.
I don't honestly remember when I had to use my ammeter, even when I did
an operational check of my SD8...I just knew the batt voltage alarm went
off when I hit the transmit button...
Cheers
Frank
Posted: Thu Sep 27, 2007 1:43 pm Post subject: Question about an Aux Alternator |
Z-13.
The Z-figures are to suggest ARCHITECTURE only, there are a host
of alternator, regulator, ov-protection, lv-warning combinations
that will happilly integrate into the Z-13 archtecture.
| Quote: | Regarding the hall effect sensor comment. I'm running a Dynon
If you have a voltage reading on the display, then you
can live quite happily with no shunts whatsoever.
| Quote: | I don't think I ever got an answer on this one: Is it not a good idea to
Only if your willing to abandon the features depicted
in the Z-figures. There are reasons why they'll crafted
as shown. You can certainly depart in any manner you choose
and you will no doubt achieve some level of functionality.
But it's up to you to decide if that's what you want.
I get dozens of emails every month extolling the virtus
of one z-figure or another followed by a narrative of all
the things the writer wants to change and wants me to
somehow bless the changes.
I don't have the time to take on another consulting
task and it's doubtful that the writer would want to
pay my outrageous fees. Further, he's at risk that
I would still recommend that he stay with one of
the z-figures and then bill him for the advice.
So please understand that I'm not trying to be a hard-ass
on some sort of not-invented-here syndrome. I'm only
pointing out that what you see is what you get and the
price is certainly right. If your personal requirements
depart from the recommendations, that's fine with me
but please don't expect me to spend a lot of time either
supporting or trying to dissuade you from making the
changes.
Posted: Sat Sep 29, 2007 8:04 pm Post subject: Question about an Aux Alternator |
At 08:35 AM 9/27/2007 -0700, you wrote:
Z-13.
Okay, if you use a generic, externally regulated alternator
the you need the equivalent of the LR-3 in the three components
I illustrated.
To do so departs from the architecture described in Z-13.
But you could use a single hall effect sensor for both
alternator feeds. The hall effect measures current in each
wire independently and does not disturb the recommended
architecture.
| Quote: | Bob has commented that the SD-8 has known qualities and suggested that a
If the SD-8 is working, the lv warn light goes out.
| Quote: | OK, to sum it up, this is what I understand:
Not quite. The LR-3 is designed for use in conjunction
with an externally regulated alternator, NOT a PlanePower
product which has its own, built in regulation and ov
protection.
| Quote: | 2-Bob says that the Plane Power alternator warning light output is not
That's the recommendation.
| Quote: | 3-Normal operation would be to run both alternators simultaneously because
No, Figure Z-13 is a two layer system set up to back up the
main alternator driving the main bus with an SD-8 alternator
driving an e-bus.
| Quote: | Do I understand this correctly?
The autoswitch feature I described is UNIQUE to Z-12 with
an SD-20 alternator and SB-1 regulator driving the main
bus and set up like the STC used to put this system on
a host of TC aircraft.
With Z-13, you leave the SD-8 off until needed when
it is determined that the main alternator is off line
(lv light on). You drop to e-bus loads, open battery
contactor, turn SD-8 on and continue to airport of
intended destination. If the SD-8 is not overloaded,
the lv warning light will go back out.
Paul Valovich
Posted: Mon Oct 01, 2007 8:37 am Post subject: Question about an Aux Alternator |
A different aux alt question:
Rv-8A QB Z-13/8 with a continuous main bus load of 21 amps and an intermittent max load of 28 amps. I initially was going to use a B&C 60 amp alternator and an SD-8, but got to thinkin’ that a 40 amp alt would be sufficient. If the SD-8 is continuously on, wouldn’t it pick up any intermittent loads (up to 8 amps) above the main alternator max limit ?
Paul Valovich
N192NM Reserved (Again)
Posted: Mon Oct 01, 2007 7:21 pm Post subject: Question about an Aux Alternator |
At 12:36 PM 10/1/2007 -0400, you wrote:
| Quote: | A different aux alt question:
amp alternator and an SD-8, but got to thinkin that a 40 amp alt would be
sufficient. If the SD-8 is continuously on, wouldn t it pick up any
The 40A would be fine all by itself. This still gives you plenty
of headroom to recharge a battery.
The SD-8 generally should not be used to "boost" total
output and in the case you've cited above, isn't
necessary.
melkel2000
Posted: Tue Oct 02, 2007 6:50 am Post subject: Re: Question about an Aux Alternator |
"With Z-13, you leave the SD-8 off until needed when
the lv warning light will go back out."
With regards to the SD-8 and the lv light, Z-13 has a single lv light on the diagram. The descripton for the PV/OV crows foot kit available from B and C states that "The PM/OV was designed to give over voltage protection to the permanet magnet alternator. The yellow light will annunciate if the alternator switch is left off, or the crowbar over voltage protection has been tripped. "
So, will the single lv light depicted on Z-13 light if either the main alt or the SD-8 are off line?
If the SD-8 has its own unique lv light as described on the B and C site, does it light if the aux alt selection switch is OFF? Or, does it only light if the aux alt selector switch is ON AND the SD-8 is off line? If the first case is true, during normal operation, the aux lv light will alway remain lit which would not be an ideal situation.
Kelly
