zsmith3rd(at)earthlink.ne Guest
Posted: Thu Sep 20, 2007 12:38 pm Post subject: Battery cable size |
Mike,
I used #4 welding cable from the local welding supply. Tough insulation, flexible, etc.
They also stock nice copper end terminals
Zed/701/912/etc/90+%/blue scotchbrite pads
Geoff Heap
Joined: 12 Jan 2006 Posts: 266 Location: Lindenwold, New Jersey
Posted: Thu Sep 20, 2007 12:49 pm Post subject: Re: Battery cable size |
Zed. you've been 90% done for the last 4 years
Geoff 90% done do not archive
pmaxpmax(at)HOTMAIL.COM Guest
Posted: Mon Sep 24, 2007 12:19 pm Post subject: Battery cable size |
I think #4 Tefzel wire is a better choice than welding cable. Tefzel insulation has been proven in aircraft over and over, and with welding cable, your gambling on the insulation. Many builders use it, but why take the chance?
Phil Maxson
601XL/Corvair
Northwest New Jersey
> Date: Thu, 20 Sep 2007 15:37:45 -0500
| Quote: | From: zsmith3rd(at)earthlink.net
Subject: Re: Battery cable size
--> Zenith-List message posted by: Zed Smith <zsmith3rd(at)earthlink.net>
Mike,
Can you find the hidden words? Take a break and play Seekadoo! Play now! [quote][b]
Posted: Mon Sep 24, 2007 1:20 pm Post subject: Battery cable size |
Hi Phil,
You'd find #4 Tefzel is fairly rigid in bending and the same for fitting
connectors. Welding cable is flexible and durable to a fault and the
wire is fine enough that connectors can
be soldered with excellent results. There is no risk taken in using
Welding Cable for battery to starter contactor and battery connections
and it's much easier to lay up tight in corners and bends than Tefzel.
Welding cable insulation is extremely durable as it get stepped on,
driven over and will take an enormous amount of abuse. That said, I'd
not use anything but Tefzel for all light gage wiring jobs.
I'm sure that welding cable costs less and can be had at Farm and Fleet
Stores.
Phil Maxson wrote:
| Quote: | I think #4 Tefzel wire is a better choice than welding cable. Tefzel
take the chance?
Phil Maxson
601XL/Corvair
bryanmmartin
Posted: Mon Sep 24, 2007 2:52 pm Post subject: Battery cable size |
The biggest advantage of Tefzel is if you have a short and the wire
burns up, the Tefzel won't emit toxic vapors like welding cable will. I
used Tefzel everywhere inside the cabin. On the other hand, your battery
will most likely be outside the cabin where toxic fumes are not going to
be an issue. In that case the flexibility of welding cable can be useful.
LarryMcFarland wrote:
Hi Phil,
not use anything but Tefzel for all light gage wiring jobs. I'm sure
that welding cable costs less and can be had at Farm and Fleet Stores.
> take the chance?
> Phil Maxson
> 601XL/Corvair
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
_________________ --
Bryan Martin
do not archive. |
purplemoon99(at)bellsouth Guest
Posted: Mon Sep 24, 2007 4:51 pm Post subject: Battery cable size |
Bryan, my batery is in the cabin ,on the fire wall, passenger side. on the
floor the leads are about 6" long and they go back through the fire wall
into the engine compartment to terminals that go to eng . and to smaller
wires that go back to the dash. It is a dry cell batt. and that I felt it
would be safe. what do you think ?
bryanmmartin
Posted: Mon Sep 24, 2007 5:50 pm Post subject: Battery cable size |
It depends on what type of insulation is used. Some of that stuff can
give off a dense cloud of noxious smoke. It can not only be hard to
breathe, it can be difficult to see through. Put the battery contactor
as close to the battery as possible and make sure the cable from the
battery to the contactor can't possibly short out to ground. That way
you can stop the current flow with the master switch and stop the smoke.
Make sure the rest of your wiring is protected by fuses or breakers that
have a lower current rating than the wire in the circuit.
Tefzel isn't the easiest stuff to work with, but how often do you have
to monkey with your battery cables?
Southern Reflections wrote:
<purplemoon99(at)bellsouth.net>
the floor the leads are about 6" long and they go back through the fire
wall into the engine compartment to terminals that go to eng . and to
smaller wires that go back to the dash. It is a dry cell batt. and that
I felt it would be safe. what do you think ?
Bryan Martin
Zenith 601XL N61BM
Bryan Martin
do not archive. |
Posted: Mon Sep 24, 2007 6:32 pm Post subject: Battery cable size |
Bryan, Iam going to check what type of wire was used,the person that put it
in the plane is along time builder Rv 6, Z 701, etc. and well though in the
air craft comm. around here. The wire he used is white and rather stiff I've
never looked at the name or no. on the wire, but I will tomorrow .The master
switch is a great idea, going to put it on the hot side between the pole, on
pilot side by my knee on the center console , by the way do have any exp.
about how good a Icom IC 200 raido is ? Thanks Joe N101HD 601XL
(about to fly again)
n4546v(at)mindspring.com Guest
Posted: Mon Sep 24, 2007 6:43 pm Post subject: Battery cable size |
Hello Larry:
I have been warned by people supposedly in the know against soldering
aircraft connections. Something about that if you solder a multi-strand
wire, the solder binds together the mutiple strands and causes it to act
like a large, single strand wire, when subject to vibration, you loose the
benefit of muti-strand wire flexing and if it breaks it breaks all at once.
Any opinion regarding this?
Randy, Las Vegas do not archive
| Quote: | Welding cable is flexible and durable to a fault and the wire is fine
Posted: Tue Sep 25, 2007 5:48 am Post subject: Battery cable size |
Randy,
The vibration is not going to affect any soldered cable connection of a
size 6 or larger, but I agree that small wires should be crimped
properly. When soldering
is recommended or felt necessary, extra steps should be taken to isolate
the wire from vibration. I have several cable connections that are
silver soldered
and only a few connections where pins are involved in multi-wire plugs
that needed to be soldered. These are encased in shrink wrap and tied
down to keep
vibration to a minimum. All I know "electrical" is found in the
complete manual sold by The AeroElectric Connection. Information Service
and Guide Theory,
Operation, Design and Fabrication of Aircraft Electrical Systems. by Bob
Knuckolls. His book advocates using battery cables with soldered
connections and
describes how best to do it. I have had to repair one 22 gage wire, non
Tefzel, (from an instrument) that broke from flexing as a 6-inch free
loop where no solder was
involved at 50 hours total time.
Randy L. Thwing wrote:
<n4546v(at)mindspring.com>
Hello Larry:
multi-strand wire, the solder binds together the mutiple strands and
causes it to act like a large, single strand wire, when subject to
vibration, you loose the benefit of muti-strand wire flexing and if it
> Larry McFarland 601HDS at www.macsmachine.com
planecrazydld(at)yahoo.co Guest
Posted: Tue Sep 25, 2007 7:40 am Post subject: Battery cable size |
I respectfully disagree. Soldered connections lead to cable fatigue in ALL cases - you may just not get there!
Dave Downey
Harleysville (SE) PA
100 HP Corvair
Posted: Tue Sep 25, 2007 8:17 am Post subject: Battery cable size |
Dave,
I understand your concern, but a properly supported cable is not going
to get tired the first 100 years and fail all by itself unless you
put it under stress. Properly done cables are not placed under stress.
To have cable fatigue you have to hang a battery from it or
some flexing tensioned condition and in this case I'd agree with you.
Larry McFarland
David Downey wrote:
| Quote: | I respectfully disagree. Soldered connections lead to cable fatigue in
Dave Downey
100 HP Corvair
Float Flyr
Posted: Wed Sep 26, 2007 1:08 pm Post subject: Battery cable size |
Solder wicks up into the wire through capillary action. that causes all the flex to occur at the point where the solder ends... that's where it is going to break not at the connector. Personally if a joint is going to be subjected to vibration, regardless of the wire size, I'll pass on the solder.
So far I have resoldered a #24 wire three times in my GPS. It always breaks at the point where the solder ends. This is a very small wire which connects the external power tab to the positive terminal of the circuit board.
Before any one asks I haven't done a cold solder joint in more than thirty years.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
t_fogelson(at)yahoo.com Guest
Posted: Wed Sep 26, 2007 5:29 pm Post subject: Battery cable size |
I second what Noel says, all military wiring is crimp
type lugs, not soldered. The only thing I have ever
seen soldered on a military aircraft is small wires
into a cannon plug, but then there is a strain relief
to keep the wire from flexing at the solder joint.
There is also lots of clamps and tiewraps around wire
bundles.
Terry
--- Noel Loveys <noelloveys(at)yahoo.ca> wrote:
| Quote: | Solder wicks up into the wire through capillary
that's where it is
I'll pass on the
solder.
my GPS. It always
board.
years.
Noel
n85ae
Posted: Thu Sep 27, 2007 11:35 am Post subject: Re: Battery cable size |
I've soldered a LOT of connectors in Grumman E-2C's, so they definetly
are out there. However they are on the way out.
There are several reason solder isn't used much now:
1). Most people solder poorly, and even a lot of people who think they don't solder poorly actually do. AND even perfect looking solder joints, when examined under a microscope some times you can see a clear
separation line between the solder and the cup (i.e. the solder is simply
acting as a filler). I worked a job where everything we soldered was
inspected under a scope, that's how I know this. Even in a professional
shop, with a good QA department, almost everything hand soldered
would go through a couple iterations of rework before passing final
inspection.
2). Any trained ape can properly crimp connectors AND consistently
if they use the right tools.
I personally took a fly cutter and replaced the cutter with a swiveling
post. I attached a 18 gauge tefzel wire with an Amp crimp connector to
the post. The fly cutter was mounted in my drill press. I attached the
other end of the wire to the drill press frame with a spring so the wire
was under constant tension. I then turned on the drill press at let it
run. It was a couple hours before the crimped wire broke. It broke 1/2"
from the crimp in the insulated part of the wire. The crimp did not fail.
Use whatever you want, but for me I'll always use crimp connectors.
Jeff
