		craigb(at)onthenet.com.au Guest
				 Posted: Sat Sep 29, 2007 2:55 pm    Post subject: Trigear Max Prop Size |
				Seeing all this discussion about the size of prop allowable on Mono's
 prompts me to ask if anyone knows
 what the largest prop for the Tri is 62".... 64"....66"?? given the
 different static angles on the ground etc
 thanks
 3:40 PM
		kheindl(at)msn.com Guest
				 Posted: Sat Sep 29, 2007 4:40 pm    Post subject: Trigear Max Prop Size |
				At least 70" if you make the necessary mod to the nose gear . I had a new
 spindle machined out of the same material as the original, which is 50mm
 longer. It increases the nose-up attitude on the ground by 1.6 degrees, and
 there is no noticable change in handling.
 Karl
  	  | Quote: | 	 		  From: "craig bastin" <craigb(at)onthenet.com.au>
 Reply-To: europa-list(at)matronics.com
 Subject: Trigear Max Prop Size
 Date: Sun, 30 Sep 2007 08:56:38 +1000
 thanks
 3:40 PM
 The next generation of Hotmail is here!  http://www.newhotmail.co.uk
		ami(at)mcfadyean.freeserv Guest
				 Posted: Sun Sep 30, 2007 1:21 am    Post subject: Trigear Max Prop Size |
				Karl,
 See article in Sept 07 Sport Aviation (pp 110) for the downside of this!
 Duncan McF
				 Posted: Sun Sep 30, 2007 4:05 am    Post subject: Trigear Max Prop Size |
				Duncan,
 You had me worried for a minute. Are you referring to the article 'Range of
 Pitch' and lack of traction in a crosswind takeoff ?  I am not sure I
 understand that one. I can keep the aircraft on the ground as long as I like
 by pushing the stick forward, and I have to do that on a bumpy grass strip
 on landing, otherwise the steel spring suspension propels me back in the
 air.
 Very recently I made a takeoff in a 40 knot 90 degree crosswind without too
 much bother. The landing, though, was something else.
 Karl
 [quote]From: "Duncan & Ami McFadyean" <ami(at)mcfadyean.freeserve.co.uk>
 Subject: Re: Trigear Max Prop Size
 Date: Fri, 1 Jan 1988 01:41:01 -0000
 Karl,
 Duncan McF
		rampil
				 Posted: Sun Sep 30, 2007 7:09 am    Post subject: Re: Trigear Max Prop Size |
				My trigear has a 66" prop and no mod of the nose gear without any noticeable problem
