Posted: Tue Oct 02, 2007 11:51 am Post subject: Rivnuts instead of self-tapping screws on canopy hoops? |
Has anybody tried using rivnuts to hold the canopy to the hoops instead of
the self-tapping screws? I've got a few stripped holes and wonder if rivnuts
could be used for repair or in the original build. One problem I see is that
the shoulder of the rivnut could be a stress point. The self-tapping screws
hold the canopy against the smooth hoop.
-- Craig
Gig Giacona
Posted: Tue Oct 02, 2007 12:14 pm Post subject: Re: Rivnuts instead of self-tapping screws on canopy hoops? |
I think your concern is correct. I'd try a larger screw first.
| craig(at)craigandjean.com wrote: | Has anybody tried using rivnuts to hold the canopy to the hoops instead of
-- Craig |
601XL Under Construction
vjvus(at)yahoo.com Guest
Posted: Tue Oct 02, 2007 12:37 pm Post subject: Rivnuts instead of self-tapping screws on canopy hoops? |
Craig, At Oshkosh this year I noticed the factory
assembled 601XL in the Sports Planes area had soft
aluminum pop rivets holding the canopy to the tubes
and the side frames. I talked to the factory guy who
said they were having no problems using the soft rivet
with aluminum body and mandrel.
--- Craig Payne <craig(at)craigandjean.com> wrote:
-- Craig
browse
Subscriptions page,
FAQ,
Web Forums!
Luggage? GPS? Comic books?
Check out fitting gifts for grads at Yahoo! Search
lrepilot(at)yahoo.com Guest
Posted: Tue Oct 02, 2007 12:56 pm Post subject: Rivnuts instead of self-tapping screws on canopy hoops? |
I tapped the holes and used 6-32 button head cap
screws with a clear plastic washer under the head
--- Gig Giacona <wr.giacona(at)suddenlink.net> wrote:
screw first.
> -- Craig
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=137673#137673
Yahoo! oneSearch: Finally, mobile search
that gives answers, not web links.
http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC
Posted: Tue Oct 02, 2007 1:08 pm Post subject: Rivnuts instead of self-tapping screws on canopy hoops? |
| Quote: | I tapped the holes and used 6-32 button head cap screws with a clear
Interesting idea. I'm surprised you got enough threads in the tube's thin
wall to hold. Any pictures?
-- Craig
John Bolding
Posted: Tue Oct 02, 2007 1:27 pm Post subject: Rivnuts instead of self-tapping screws on canopy hoops? |
| Quote: | It would be more simple safe and easy to drill all the way through the
tube and engage a K1000-6 nutplate.
I wonder if the extra holes would appreciable weaken the tube more than just
the single row of outside holes? But then again the riveted nutplate would
strengthen the hoop.
-- Craig
Posted: Tue Oct 02, 2007 1:38 pm Post subject: Rivnuts instead of self-tapping screws on canopy hoops? |
Then use "Well-nutsŪ" they work like a Rivnut but are rubber and shock absorbing.
Dave Downey
Harleysville (SE) PA
100 HP Corvair
Posted: Tue Oct 02, 2007 6:22 pm Post subject: Rivnuts instead of self-tapping screws on canopy hoops? |
Sent: Tuesday, October 2, 2007 5:33:38 PM
Subject: Re: Re: Rivnuts instead of self-tapping screws on canopy hoops?
Dave Downey
100 HP Corvair
John Bolding
Posted: Wed Oct 03, 2007 7:21 am Post subject: Rivnuts instead of self-tapping screws on canopy hoops? |
Actually I used countersunk alum pops (and countersunk the canopy) as there was an epoxy /glass canopy skirt that went on top of the rivets and I didn't want any bumps, those kind of things hold little importance now while building the 701, the whole thing is a bump. John
