M-14b Timing
Michael Bolton
PostPosted: Tue Oct 02, 2007 5:09 am    Post subject: M-14b Timing Reply with quote
Does anyone out there know the initial Mag timing for the M-14b? yes that is a "B" I only have the manual for the P model. The "B" has mags with centerfugal advance.
Thanks for any help you guys might be able to supply.
Michael J. Bolton, Vice President
Young Forest Products, Inc.
(O)803.438.4259
(C)803.427.0604
dsavarese(at)elmore.rr.co
PostPosted: Tue Oct 02, 2007 5:33 am    Post subject: M-14b Timing Reply with quote
I'm working on it Michael and will get back to you with the information.
Dennis
cliff(at)gesoco.com
PostPosted: Tue Oct 02, 2007 10:39 am    Post subject: M-14b Timing Reply with quote
The spark advance for the M14 series engines is 22-24 degrees BTDC.
If you have M9-35M magnetos, there is a degree stamp on the mating face
of the magneto body under the mag cap.
This stamp is typically between 23 and 37 degrees.
To compensate for the centrifugal advance of the mag use the following
formula:
23 - (degree stamp / 1.25) = timing mark on the cylinder pointer in #4
cylinder.
If you're timing the engine via prop flange, then you will need to
multiply the above result by the reduction gear ratio.
On M14-P it's .658
On M14-B it's .787
So....with a "36" degree stamped magneto-
23- (36/1.25) = -5.8 or 6 degrees *after* top dead center as seen on the
cylinder pointer.
at the prop flange of an M14-P: 5.8 * .658 = 3.8 or 4 degrees ATDC
at the prop flange of an M14-B: 5.8 * .787 = 4.5 degrees ATDC
Cheers,
Cliff
(O)803.438.4259
(C)803.427.0604
PostPosted: Tue Oct 02, 2007 1:56 pm    Post subject: M-14b Timing Reply with quote
The only thing I would add is be sure the Mags are M9-35's as stamped on the
data plate just above the P lead and coil cover. If they are other than the
M9-35's, please post to the list.
Dennis
wlannon(at)cablerocket.co
PostPosted: Tue Oct 02, 2007 3:17 pm    Post subject: M-14b Timing Reply with quote
Dennis;
They could be M9-25M mags (23 to 27 degs of advance) on the M14B. I suspect
that the "B" is a lower RPM engine than the "M". In any case Cliff's
instructions would still apply.
Walt
PostPosted: Tue Oct 02, 2007 4:35 pm    Post subject: M-14b Timing Reply with quote
That's what I believe they are Walt. But I certainly could be wrong.
Dennis
PostPosted: Tue Oct 02, 2007 10:06 pm    Post subject: M-14b Timing Reply with quote
Hi Cliff;
Could you expand on the use of the factor of "/1.25" in calculating the
ignition advance angle?
What does that factor represent?
Thanks.
Walt
cliff(at)gesoco.com
PostPosted: Wed Oct 03, 2007 4:13 am    Post subject: M-14b Timing Reply with quote
Cliff had an oops.
I got my engines crossed between M462 and M14B.
I was going from memory about gear reduction ratio for the M14-B engine.
I'll go hit the books and make a final determination if needed.
Doug pointed out that many people are running the "B" engine with a "P"
nose case which makes the point moot anyway.
In any event, if you time by the sparkplug pointer, then the gear
reduction doesn't come into play.
Cheers,
Cliff
In any event
face of the magneto body under the mag cap.
formula:
cylinder.
On M14-P it's .658
On M14-B it's .787
the cylinder pointer.
Cheers,
Cliff
> (O)803.438.4259
> (C)803.427.0604
cliff(at)gesoco.com
PostPosted: Wed Oct 03, 2007 4:32 am    Post subject: M-14b Timing Reply with quote
The mag turns 1.25 times per crank revolution.
Dividing the retard angle by the drive ratio gives the offset from
"running" position of the rotor-which is what you are ultimately timing to.
To verify this, we can take an M9-F magneto with 0 retard angle and run
it through the formula:
23 - (0/1.25) * .658 = 15.1
So 23 degrees BTDC (crank position) translates to 15 degree BTDC (prop
flange position).
Cheers,
Cliff
Walter Lannon wrote:
Hi Cliff;
the ignition advance angle?
Thanks.
Walt
cliff(at)gesoco.com
PostPosted: Wed Oct 03, 2007 9:51 am    Post subject: M-14b Timing Reply with quote
Hey...add another 1 in there...that should read
"the mag turns 1.125 times per crank revolution"
<sigh>
timing to.
run it through the formula:
flange position).
Cheers,
Cliff
> <wlannon(at)cablerocket.com>
> Hi Cliff;
> Thanks.
> Walt
