Afterfxllc(at)aol.com Guest
Posted: Wed Oct 03, 2007 11:23 am Post subject: Zenith building expense |
I said just the corvair FWF engine conversion was around 8,800 not counting the carb, airbox, or cowling. I said nothing about airframe. The avionics I use cost around 6,000 and as I said before I used a kit not scratch built but if you have never built an aircraft you will be surprised how the little things add up. like flap motors, trim servos, wheels, brake's hell a canopy is 600.00 + shipping ... If you are saying you can build just the airframe for 5,000 minus the expensive stuff I might agree with you but I still say that a well built 601 xl with a good reliable corvair conversion can't be done for under 25,000 If you do it great but you couldn't do it if you put in standard instruments and the proper parts for the engine.
In a message dated 10/3/2007 2:59:22 P.M. Eastern Daylight Time, ashontz(at)nbme.org writes:
Quote: | Not to drag on, but just adding up what you have listed here, by your own account, looks more like 9,000 + 8,800 for fuselage and engine. Where's the extra $17,200? If you're not going ape with avionics, even by your own admission you should be under $20,000.
Even so, I said $5,000 - $6,000 for fuselage, $10,000 total, that's a possibility for a bare bones plane, depending on how much of the engine I do myself, and I will do a lot.
See what's new="_blank">Make AOL Your Homepage.
ashontz
Posted: Wed Oct 03, 2007 11:27 am Post subject: Re: Zenith building expense |
Looking at the list, I'd have to say I'll be making at least 50% of the stuff in lines 4 - 19.
Most of the line items I would be interested in would be the internal engine parts. Still, I don't see heads listed on there, nor would I expect them to be. That being the case, why replace the jugs but not the heads. If anything it would be the other way around. If the heads are ok, I don't see any reason the jugs would need to be replaced. Hone them lightly, caliper them, if they look ok no need to spend another $350.
Gasket set, $199? I just found a complete gasket set for $58.
I'm not making this up: Nitrated street racing crank (should be good for a plane huh) $209. Brand new. No, it's not Clarks Corvair.
SCAT® CHEVY CAST CRANKSHAFTS
High-quality cast-iron crankshaft designed to replace stock crankshaft on mildly built street engines. Crankshaft is nitride hardened for superior wear resistance.
FITS 1967 Chevrolet Corvair
Review this product
Our Low Price: $209.99
Not trying to bust your stones, I'm just saying your numbers may be off. So we'll halves it, you may or may not have overpaid for some stuff and I may or may not have to replace more things than I would like to.
Afterfxllc(at)aol.com wrote: | I think his #'s are way off if you are wanting to scratch build a nice safe aircraft.... The spread sheet attached is real world #'s with the part numbers of a plane I did a builder assist on. It has aluminum brake and fuel lines and the spread sheet includes all the fittings for them also. It doesn't include the aluminum for scratch building as I used a kit. But I have been kicking around the idea of scratch building one and the best I can figure it will cost around 25,000.
In a message dated 10/3/2007 10:41:56 A.M. Eastern Daylight Time, ashontz(at)nbme.org writes:
Quote: | Building from scratch is pretty cheap. Figure $5,000 in materials, maybe a little more. Corvair with conversion, another $2,000. Basic instruments, $2,500 - $3,000. If it takes you 4 years that's $2,500/yr, or about $200/month.
See what's new="_blank">Make AOL Your Homepage. |
n4546v(at)mindspring.com Guest
Posted: Wed Oct 03, 2007 12:06 pm Post subject: Zenith building expense |
Hello All:
I recommend scrap building as the way to build for nearly free (except the
engine). But it will be a long while before you fly. So in the meantime,
start or join a flying club like ours and be a active pilot the entire time
you build.
http://www.eaa163.com/club/index.htm
We currently have four memberships available.
Buy in at $1000.00
Yearly dues $200.00
Fly at $45.00/wet tach time (we have no hobbs).
Randy, Las Vegas
Posted: Wed Oct 03, 2007 12:11 pm Post subject: Zenith building expense |
You should really buy WW's conversion manual before you waste your money. We do use the heads that come off the engine but they need new guides put in the and anything less than what falcon does IMO shouldn't be in airplanes. The crank will need to be tapped for the safety shaft and nitrated so the cost for all the machine work is around 300.00 so whichever crank you use it will cost you the same because the 209 crank will need to be tapped unless you are doing that yourself. Look I build aircraft that anyone would feel safe in I don't cut corners and I don't risk lives to save a buck so build yours how you want but please do your homework first. This is my last post on this subject
In a message dated 10/3/2007 3:28:21 P.M. Eastern Daylight Time, ashontz(at)nbme.org writes:
Quote: | Most of the line items I would be interested in would be the internal engine parts. Still, I don't see heads listed on there, nor would I expect them to be. That being the case, why replace the jugs but not the heads. If anything it would be the other way around. If the heads are ok, I don't see any reason the jugs would need to be replaced. Hone them lightly, caliper them, if they look ok no need to spend another $350 |
n85ae
Posted: Wed Oct 03, 2007 12:49 pm Post subject: Re: Zenith building expense |
I guess, you can get a really long string, and some soup cans for cheap
and then you'll have a communication device as well. In fact you can
do this for an intercom as well.
I think mid-thirties is a reasonable minimum number for a builder to
spend.
I put an injected Continental in my Kitfox, and filled the panel with stuff
by King and Garmin, I spent mid-sixties on it. I expect I will invest a
similar amount in my 801 when it is done. I could have built the plane
with a lot less, but I would have a lot less plane as well.
Jeff
psm(at)ATT.NET Guest
Posted: Wed Oct 03, 2007 1:49 pm Post subject: Zenith building expense |
Hi Randy,
What a great idea. It sounds like a wonderful excuse for me to go to
Las Vegas and play poker along with flying the club airplane.
I suppose you want me to have a medical certificate to fly the 172,
though. Oh well, I guess I'll just finish my XL and fly it as a
broken old man with Sport Pilot privileges. With any luck it will be
ready to go in 6 months or so.
Best regards,
Paul
XL fuselage
At 01:05 PM 10/3/2007, you wrote:
Quote: |
Hello All:
you build.
Buy in at $1000.00
Yearly dues $200.00
Randy, Las Vegas
naumuk(at)alltel.net Guest
Posted: Wed Oct 03, 2007 2:08 pm Post subject: Zenith building expense |
All-
I agree absolutely with the other Bill. You can easily make your own Corvair parts if you have a Bridgeport and lathe at your disposal. When I was growing up, I had access to a full machine shop two steps out of the living room door. Now I don't. I could probably build an AirCorvair for less than $2K then, but that was then.
Now I'm at 5K+ and counting. Feces occurs.
The point I'm trying to make is this. The degree of "Scratchbuilding" you can pull off is dependent on the tools you have available to use. Some tools, such as "Daves Brake" will require little investment yet save you thousands. Investing in a full machine shop is another story. If you already have access, I agree, you can do it.
Do not archive.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Posted: Wed Oct 03, 2007 3:57 pm Post subject: Zenith building expense |
Quote: | What a great idea. It sounds like a wonderful excuse for me to go to Las
Hard to say which is the bigger gamble!
A lot of pilots sell their airplanes because they loose their medical. My
Pal Bob says that's the time to buy your own airplane, because nobody will
rent to you anymore!
Randy, Las Vegas do not archive
Jeyoung65(at)aol.com Guest
Posted: Wed Oct 03, 2007 4:42 pm Post subject: Zenith building expense |
This sounds like good advice but I have a problem send money to a PO Box and not being able to reach a person. Last week I was able to spend some time in Daytona Beach, Fla. and thought this would be a great time to pickup the manual from WW. Problem was I thought the hangar was outside Dayton mapquest could not find the address. Tried calling two number, one was disconnected and the other one told me to call another number. When I called it a machine told me to leave a message and then disconnected me. So I sent an e-mail but still have not heard from anyone. No sure I will buy from anyone I can not talk to! There I got it off my chest. SORRY Jerry of Ga
"You should really buy WW's conversion manual before you waste your money."
See what's new at AOL.com and Make AOL Your Homepage.
601zv(at)ritternet.com Guest
Posted: Wed Oct 03, 2007 5:35 pm Post subject: Zenith building expense |
Jeyoung, you apparently had some very old contact info for WW. Just go to http://flycorvair.com/ for all current information.
Posted: Wed Oct 03, 2007 6:03 pm Post subject: Zenith building expense |
That is where I got the addresses and phone number. Jerry of Ga
ashontz
Posted: Wed Oct 03, 2007 6:22 pm Post subject: Re: Zenith building expense |
Hopefully I can do all that on my lather and milling machine.
[quote="Afterfxllc(at)aol.com"]You should really buy WW's conversion manual before you waste your money. We do use the heads that come off the engine but they need new guides put in the and anything less than what falcon does IMO shouldn't be in airplanes. The crank will need to be tapped for the safety shaft and nitrated so the cost for all the machine work is around 300.00 so whichever crank you use it will cost you the same because the 209 crank will need to be tapped unless you are doing that yourself. Look I build aircraft that anyone would feel safe in I don't cut corners and I don't risk lives to save a buck so build yours how you want but please do your homework first. This is my last post on this subject
ashontz
Posted: Wed Oct 03, 2007 6:24 pm Post subject: Re: Zenith building expense |
I agree, the fraction of the money is better spent on tools.
[quote="naumuk(at)alltel.net"]All-
Do not archive.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
rloer(at)aceweb.com Guest
Posted: Wed Oct 03, 2007 9:15 pm Post subject: Zenith building expense |
Gig Giacona
Posted: Thu Oct 04, 2007 5:36 am Post subject: Re: Zenith building expense |
From the top of the main page at flycorvair.com.
William Wynne
The Corvair Authority
5000-18 HWY 17 #247
Orange Park, FL 32003
This is his home address and he is no longer in the Edgewater FL hanger. That has been turned over to Gus. FOr details visit: http://www.flycorvair.com/hangar.html
Jeyoung65(at)aol.com wrote: | That is where I got the addresses and phone number. Jerry of Ga
601XL Under Construction
Posted: Thu Oct 04, 2007 6:40 am Post subject: Zenith building expense |
In a message dated 10/4/2007 9:38:33 A.M. Eastern Daylight Time, wr.giacona(at)suddenlink.net writes:
Quote: | http://www.flycorvair.com/hangar.html
Thanks Gig for the information. It filled in a lot of blank areas. Jerry of Ga
ashontz
Posted: Thu Oct 04, 2007 8:46 am Post subject: Re: Zenith building expense |
Yeah, I could have saved even more money. I actually bought some 6061-T6 bar stock from Yard, took a day off to drive up to north jersey, only to find out that the same stuff was literally 600 feet down the street at Fastenals. LOL
[quote="bill_dom(at)yahoo.com"]Yarde Metals is still cheaper than Aircraft Spruce and they pack the material very nicely. You will need to purchase 5 to 8 sheet at a time in order to take advantage of their better pricing.
William Dominguez
Zodiac 601XL Plans
Miami, Florida
Read this topic online
planecrazydld(at)yahoo.co Guest
Posted: Thu Oct 04, 2007 10:09 am Post subject: Zenith building expense |
I strongly reccomend Fastenal. They are everywhere.
Dave Downey
Harleysville (SE) PA
100 HP Corvair
ashontz
Posted: Thu Oct 04, 2007 10:14 am Post subject: Re: Zenith building expense |
The only thing I wasn't excited about them was that they were a bit limited on the aluminum sheet front. Not a lot to choose from. If they had that going for them that'd be awesome, a metal supermarket right down the street from me at competitive prices. I did manage to score some 5052 for my fuel tanks from them.
planecrazydld(at)yahoo.co wrote: | I strongly reccomend Fastenal. They are everywhere.
Dave Downey
100 HP Corvair
Posted: Thu Oct 04, 2007 11:18 am Post subject: Zenith building expense |
my local branches were willing to bring in the sheet sizes needed if they could come in at their convenience.
Dave Downey
100 HP Corvair
