goodings(at)yorku.ca Guest
Posted: Wed Oct 03, 2007 6:20 pm Post subject: Heavy left wing7 |
The "heavy left wing" phenomenon is fairly common on the HD and HDS (I
don't know about the XL). I think it is probably due mainly to
clockwise-rotating propeller torque. Slightly incorrect offset angle of
the engine mount might be another reason. Non-skid wing root material
won't be a contributor. In other words, I can't give you a definitive
answer! Has anyone experienced heavy RIGHT wing with a
counter-clockwise-rotating prop? It would be fun to know. I have never
heard of a case of heavy right wing. We put our trim tab about half way
out along the aileron; the precise distance is not critical. Further out
from the fuselage will have more effect. It is absolutely NOT necessary
to go to the trouble of making two trim tabs, one for each wing; you have
better uses for your time!
John Goodings, C-FGPJ, CH601HD with R912S, Ottawa Carp/Toronto.
Posted: Wed Oct 03, 2007 6:46 pm Post subject: Heavy left wing7 |
| Quote: | Has anyone experienced heavy RIGHT wing with a counter-clockwise-rotating
Corvairs spin the "other" way.
-- Craig
leo(at)zuehlfield.com Guest
Posted: Wed Oct 03, 2007 7:39 pm Post subject: Heavy left wing7 |
I was concerned with this "heavy left wing phenomena" a couple of years
ago when I did my phase one flight testing. I have an HDS with electric
aileron and elevator trim. I noticed that with both wing tanks full, my
trim tab indicated that I had a "heavy left wing". I landed and moved
to the right seat, and took off, you guessed it, I now had a "heavy
right wing". I find that I have to adjust aileron trim, or switch fuel
tanks, about every 10 minutes to maintain "hands off trim", solo or
with passenger. This topic has been beat to death in the past. Do not
archive.
Leo Gates
N601Z, CH601HDS TDO, Rotax 912UL
John M. Goodings wrote:
rloer(at)aceweb.com Guest
Posted: Wed Oct 03, 2007 9:31 pm Post subject: Heavy left wing7 |
If I understand a trim tab on an aileron when you have a heavy or low left wing you put a tab on the left and bend it up which moves the aileron down and raises the wing.
If this is correct would it make a difference where or how far out on the aileron it was mounted?
Robert Loer
[quote]-----
Posted: Thu Oct 04, 2007 3:21 am Post subject: Heavy left wing7 |
the closer to the center of area that any force is applied the lower the extraneous forces the structure has to manage. In this case it is torsion on the aileron - and in this case the aileron is actuated from the end rib so it probably does not matter at all because the tab loads are constant and the control loads are reversing.
In the case of a wing leveling tab it does matter: the tab should favor high aspect ratio and be located as far outboard as possible to result in the lowest drag for any applied correction.
Oh wait a minute! This is real aircraft engineering data, applied to an airplane that may be around for much longer than the builder lives, where durability and fatigue resistance may actually be a concern...never mind.
Dave Downey
Harleysville (SE) PA
100 HP Corvair
steveadams
Posted: Thu Oct 04, 2007 3:52 am Post subject: Re: Heavy left wing7 |
I don't know about the 601, but the 640 and CH2000 drawings specify an aileron trim tab to be placed on the bottom inboard surface of the aileron, effectively pushing that aileron up. This makes sense to me as you are applying the trim tab force closest to the end rib actuator, thus there is less of a twisting force applied.
Steve
pmaxpmax(at)HOTMAIL.COM Guest
Posted: Thu Oct 04, 2007 5:39 am Post subject: Heavy left wing7 |
My Corvair spins the "wrong way", and I have the slight left wing heavy thing, so it's not prop-wash. I usually just fill the right tank only or burn fuel from the left tank first. I find leaning my knee on the stick helps.
Phil Maxson
601XL/Corvair
Northwest New Jersey
> From: craig(at)craigandjean.com
| Quote: | To: zenith-list(at)matronics.com
Subject: RE: Re: Heavy left wing7
Date: Wed, 3 Oct 2007 20:44:01 -0600
--> Zenith-List message posted by: "Craig Payne" <craig(at)craigandjean.com>
-- Craig
Boo! Scare away worms, re.live.com/standard/en-us/purchase/trial.aspx?s_cid=wl_hotmailnews' target='_new'>Try now! [quote][b]
davgray(at)sbcglobal.net Guest
Posted: Thu Oct 04, 2007 8:41 am Post subject: Heavy left wing7 |
There is another method to consider shown on
http://www.ch601.org/builder%20resources.htm under the Bungee Trim heading.
To me the advantage would be to bias the system and assist the electric trim
system for single pilot operation.
In my aircraft with me at 218 lbs flying alone with evenly balanced fuel, my
electric trim tab is deployed 1/2 to 3/4 of full travel depending on air
speed. I may install this modification to allow a nearly neutral trim tab
position and use the electric trim for fine the finer adjustments as fuel
burns off.
Gary Ray
graeme(at)coletoolcentre. Guest
Posted: Thu Oct 04, 2007 2:30 pm Post subject: Heavy left wing7 |
If two identical wings are made I doubt the condition you describe should be called heavy left wing.
Your aircraft is rolling to the Left!
If the two wings are identical
the weight of the pilot in the Lh side will cause roll to the left.
Other things to check is the wing incedance is correct over the entire length of both wings.
If this ok you should be able to place a trim tab on Aileron to balance controls for the particular configoration
most commonly flown ( 1 person, two person)
Roll to the left corrected by lifting Lh wing if tab placed on lh aileron must be bent up (pushes down Lh aileron)
Graeme Bell CH 701
naumuk(at)alltel.net Guest
Posted: Thu Oct 04, 2007 2:38 pm Post subject: Heavy left wing7 |
Thanks, Paul. Now I don't have to move my trim tab to the other aileron!!!
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Posted: Fri Oct 05, 2007 3:36 pm Post subject: Heavy left wing7 |
Trying to follow too many strings. Sorry, PHIL!
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
