Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Wed Oct 03, 2007 5:37 pm Post subject: VOR/LOC/GS antenna |
With some aircraft flying now what are your thoughts on an ILS capable antenna. I was considering the Comant CI-158C as my #1 Nav and the archer wingtip as my #2 (which is already installed). From what I found in the archives the ILS really wasn't mentioned too much. What kind of feedback can you all provide on this and are there any good installation pictures out there?
Eric Kallio
40518 Baggage floors
Posted: Wed Oct 03, 2007 6:13 pm Post subject: VOR/LOC/GS antenna |
We have used the Archer antenna with surprisingly good results. The
reception distance is very good. The wingtip Com's are not that great
because of the orientation, but we are very happy with the results from the
wingtip Nav. Just my $.005 (half cent, which may be more than it is worth).
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
apilot2(at)gmail.com Guest
Posted: Wed Oct 03, 2007 7:11 pm Post subject: VOR/LOC/GS antenna |
I'd say if you have enough signal to drive a VOR, the ILS will work fine on same antenna via a splitter. I'm currently running two navcoms, both with GS via one cat whisker antenna and splitters. Works fine.
On 10/3/07, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:[quote] --> RV10-List message posted by: "Jesse Saint" <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
flywithowen(at)gmail.com Guest
Posted: Thu Oct 04, 2007 4:44 am Post subject: VOR/LOC/GS antenna |
Eric_Kallio
Posted: Thu Oct 04, 2007 8:40 am Post subject: Re: VOR/LOC/GS antenna |
Do you have any pics of your cat whisker antenna install? I have been scanning builders sites and haven't found any.
Eric Kallio
John Kirkland
Joined: 13 Jan 2006 Posts: 19 Location: South Weber, UT
Posted: Thu Oct 04, 2007 10:07 am Post subject: Re: VOR/LOC/GS antenna |
Doug Reeves site vansairforce dot net had some pictures yesterday (Oct 3) that show a RV-10 just out of the paint shop. Cat whiskers on the VS top rib just below the rudder counterweight arm. Interesting.....
Edit: just noticed its here too, thread titled "Plane Completion Pictures." Wayne Edgerton, #40336, N602WT. Take a look at how he did his.
_________________ RV-10 #40333
N540XP (reserved) |
Deems Davis
Posted: Thu Oct 04, 2007 11:43 am Post subject: VOR/LOC/GS antenna |
FYI The SL-30 has NO provision for a seperate LOC/GS antenna. It has an
internal diplexor, if the aircraft has dual antennas, it requires they
be combined into a single input. Don;t know if this isi also true of
the other Garmin radios (430/480/580)
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
Kelly McMullen wrote:
| Quote: | I'd say if you have enough signal to drive a VOR, the ILS will work
fine.
*http://www.matronics.com/Navigator?RV10-List
pilotdds(at)aol.com Guest
Posted: Thu Oct 04, 2007 12:11 pm Post subject: VOR/LOC/GS antenna |
The 430 has a provision for seperate gs/vor inputs.After much experimenting I used a bowtie ant attached to the support strut inside the cabin. Excellent reception on the ils for both localizer and g.s..---728DD.Wingtip archer ant. doesnt do nearly as well and has areas of poor reception during vectors.
rene(at)felker.com Guest
Posted: Thu Oct 04, 2007 12:15 pm Post subject: VOR/LOC/GS antenna |
The 430 is just the opposite, it has an input for the both Nav and GS. Need
a splitter if you only have one antenna.
Rene' Felker
N423CF
40322
801-721-6080
carl.froehlich(at)cox.net Guest
Posted: Thu Oct 04, 2007 2:35 pm Post subject: VOR/LOC/GS antenna |
Why not a simple wire or copper tape dipole antenna in the bottom half of
the cowl? Easy, cheap, and for all practical applications just as effective
as any other antenna. If you don't want to use a VOR/GS splitter you can
put in two.
Carl Froehlich
RV-8A (350 hrs)
RV-10 (wings)
ricksked(at)embarqmail.co Guest
Posted: Thu Oct 04, 2007 6:33 pm Post subject: VOR/LOC/GS antenna |
The 480 has the same setup as the SL-30, internal diplexer, I suspect the 430 and 530 are too. It's nice because I used a comant spliter on my Nav antenna and sent one lead to each, my 480 and the SL-30. I may add the V antenna to the tail if the performance is below par...we shall see. Everyone else using the setup has no complaints so I should be good to go.
Rick S.
40185
Posted: Thu Oct 04, 2007 7:15 pm Post subject: VOR/LOC/GS antenna |
The 430 has a separate connection for GS and Nav, so you need an external
diplexer.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Kellym
Posted: Thu Oct 04, 2007 8:38 pm Post subject: VOR/LOC/GS antenna |
Yeah, I know. I still am in the world of equipment designed in the '80s
like KX155 and MK12D that all took separate nav and gs antenna inputs.
Many of the panels discussed here have more $$ involved than I have in
my current aircraft(that is well equipped with steam guages 90s stuff).
Deems Davis wrote:
an internal diplexor, if the aircraft has dual antennas, it requires
they be combined into a single input. Don;t know if this isi also
true of the other Garmin radios (430/480/580)
Deems Davis # 406
> Works fine.
KCHD |
