Malcolmbru(at)aol.com Guest
Posted: Sat Oct 06, 2007 6:16 pm Post subject: 582 stater plate any one ?? |
today I burned out my charging coil , 76 hrs ago I lost the tack coil so I ran a tiny tack. the first thing I noticed was a drop in my charging volts just a little low , then it dropped way off after about 3 hrs flying time when I used my strobe and lights, after inspecting the charging wires i found a burnt wire and only 9 oms on my charging circuit. $600 and 4 hrs labor and i will be back in the air. malcolm kit fox michigan
