patrick.pulis(at)seagas.c Guest
Posted: Sun Oct 07, 2007 4:38 pm Post subject: Angle of Attack Probe Vs Stall Warning Vane |
Posted: Sun Oct 07, 2007 5:52 pm Post subject: Angle of Attack Probe Vs Stall Warning Vane |
Could anyone please indicate their thoughts regarding the deletion of
the Vans stall warning vane and micro-switch in favour of installing
only an angle of attack device.
I have purchased the Advanced Flight Systems Angle of Attack Pro and the
features of this device seem to negate the need to install the Vans
stall warning vane and buzzer.
If anyone out there has adopted this configuration I would very much
like to hear from you, with a view to gauging your thoughts regarding
the success or otherwise of this approach.
Thanks in advance from downunder.
PATRICK PULIS
RV-10 #40299
Adelaide, South Australia
Email: patrick.pulis(at)seagas.com.au
ScooterF15
Posted: Sun Oct 07, 2007 6:29 pm Post subject: Angle of Attack Probe Vs Stall Warning Vane |
I have both. I have the AFS AOA Sport version. Once calibrated the wing stall warning vane works great, besides the buzzer I also added a light on the panel; I like the way it works and think it's a good idea to have on the plane. The AOA, on the other hand, can be used for more than just stall detection, but I have had trouble with mine. I get error messages which have required recalibration every few flights, so I've learned not to count on it working. Recalibration has never failed to clear the errors, but I've gotten tired of taking the 10 minutes out of my flight to perform the calibration procedure and stopped using it. (Nothing against AFS, as I haven't taken the time to report this to them, so I haven't given them a chance to help me fix it yet).
So, I suggest keeping the wing stall detector on there per the plans, but install the AOA Pro for it's added functionality.
-Jim
40134 - 1st Annual Complete - Flying Again!
Jim "Scooter" McGrew
http://www.mit.edu/~jsmcgrew
In a message dated 10/7/2007 9:54:13 P.M. Eastern Daylight Time, patrick.pulis(at)seagas.com.au writes:
| Quote: | --> RV10-List message posted by: "Patrick Pulis" <patrick.pulis(at)seagas.com.au>
PATRICK PULIS
RV-10 #40299
DAVELEIKAM(at)wi.rr.com Guest
Posted: Sun Oct 07, 2007 6:48 pm Post subject: Angle of Attack Probe Vs Stall Warning Vane |
I am installing the AFS Sport and will not install the stall warning from
Van's. I think the AOA is a much better device. Just makes more sense. I
will install the indicator on my panel where it will be as easy to see as
possible. I have not flown an AOA equipped plane yet but I expect to use
that indicator on takeoff and landing almost more than airspeed.
Dave Leikam
40496
wing guts
N89DA reserved
Posted: Sun Oct 07, 2007 7:18 pm Post subject: Angle of Attack Probe Vs Stall Warning Vane |
With everyone talking redundancy- I see this as redundant and more important
to me than counting on the AOA alone. Should I chose not to use it later-
fine, I can disable the buzzer but at least I'll have it until than as a
backup to the AOA, or vice versa.
Pascal
ricksked(at)embarqmail.co Guest
Posted: Sun Oct 07, 2007 7:31 pm Post subject: Angle of Attack Probe Vs Stall Warning Vane |
Patrick,
I have a light, the horn and the AOA on the 3500, I figure if one or the other fails, there is still a backup. I was not planning on using the AOA as a primary stall indicator but for a more stabilized approach. Anyone who has flow the RV-10 can tell you it has plenty of stall warning through the seat of your pants let alone all the other goodies we can put in it. I can pull the CB on the stall vane system if it gets too annoying. And besides, it came with the kit and I would hate to let Van know he sold something to me and I didn't install and use it, that would be like selling someone something they didn't need!!
Rick S.
40185
Posted: Sun Oct 07, 2007 7:58 pm Post subject: Angle of Attack Probe Vs Stall Warning Vane |
Thanks for all your great responses guys.
Pat
acs(at)acspropeller.com.a Guest
Posted: Sun Oct 07, 2007 11:04 pm Post subject: Angle of Attack Probe Vs Stall Warning Vane |
Pat, also check this out in Part 101 Australian CAO 's for Amateur Built
category, Airworthiness Certification requirements( probably similar
existence in the FARs ).
If any Aussies need the full Part 101 copy contact me off-list.
Make of it what you will.
John 40315
"3.11 Stall warning
There must be a clear and distinctive stall warning with wing flaps and
landing gear in any normal position, in both straight and turning flight,
sufficiently in advance of the stall to provide the pilot with adequate
warning.
Note: The warning may be furnished either through inherent aerodynamic
qualities of the aeroplane or by a device that will give clearly
distinguishable indications under expected conditions of flight. However, a
visual stall warning device that requires the attention of the crew within
the cockpit is not acceptable by itself".
LloydDR(at)wernerco.com Guest
Posted: Mon Oct 08, 2007 6:37 am Post subject: Angle of Attack Probe Vs Stall Warning Vane |
I have installed the AOA Pro from AFS and left out the stall vane from
vans. I figured the AOA will let me know when I am getting close and the
seat of my pants will tell me when I am falling off the edge.
Dan
N289DT RV10E Flying
Posted: Mon Oct 08, 2007 6:45 am Post subject: Angle of Attack Probe Vs Stall Warning Vane |
Does this mean the buffet from approaching stall, coupled with the
visual indication and audible warning from the AOA will meet the
requirement? This worked for the FAA on my plane, but as we know in the
US it is entirely dependant on which inspector you get.
Dan
N289DT RV10E Flying
johngoodman
Posted: Mon Oct 08, 2007 7:36 am Post subject: Re: Angle of Attack Probe Vs Stall Warning Vane |
Patrick,
I am not installing Van's stall warning system. Instead, I am installing two AOA systems. What can I say, I'm a Navy Carrier guy.
The first one is the Dynon heated pitot/AoA tube in place of Van's pitot. This connects to a Dynon EFIS, which will give a visual indication on the screen and will also give an audible alarm at stall.
The second one is the AOA from InAir. They call it the "Lift Reserve Indicator" or LRI. I'm putting it in the right wing. It's purely mechanical and uses a round gauge. I plan on mounting that one where the Navy puts theirs - the upper left corner of the windscreen.
Both systems work on the same principle - one tube of air is more affected than the other due to a change in angle of attack. I've seen other systems that use a small vane on the wingtip that is electric. Any of them should work.
The real advantage of AOA is that it can tell you, stall, approach, L over D max (best lift over drag), best climb, best glide, etc. As the builder you will have to calibrate and calculate that stuff yourself.
RobHickman(at)aol.com Guest
Posted: Wed Oct 10, 2007 4:44 pm Post subject: Angle of Attack Probe Vs Stall Warning Vane |
In a message dated 10/7/2007 7:30:51 PM Pacific Daylight Time, JSMcGrew(at)aol.com writes:
| Quote: | | The AOA, on the other hand, can be used for more than just stall detection, but I have had trouble with mine. I get error messages which have required recalibration every few flights, so I've learned not to count on it working. Recalibration has never failed to clear the errors, but I've gotten tired of taking the 10 minutes out of my flight to perform the calibration procedure and stopped using it. (Nothing against AFS, as I haven't taken the time to report this to them, so I haven't given them a chance to help me fix it yet). |
This is not the norm, I have had my AOA Pro for the last 400 hours (long before we purchased the AOA company) and have not had to recalibrate it. The most common issue with what you are describing is leaking plumbing. You should verify the wing ports, static, and pitot. To check the wing ports do the following:
- Disconnect the tubing from the CPU
- Suck through the Green and Blue tubes, are they clear?
- Tape over the top wing port hole and suck the blue tube, you should not get any air.
- Tape over the bottom wing port hole and suck the green tube, you should not get any air.
Next thing is to make sure you have a good connection on the red hose to the pitot and the clear tube to the static. We have had some people push the ¼” tubes in to far on the Tee’s and block the cross drilled holes for the small tubes.
Rarely is there ever a problem with the CPU and they do work really well.
The last major problem we had was with a customers Lancair 4P, we had the CPU twice, he checked the plumbing multiple times and it still acted like you are describing. Finally after assuring me he had checked the plumbing he flew the plane to Oregon so I could look at it. Guess what? The clear tube to the static system was pinched with a tie strap.
Call me if you need any help any time.
Sincerley,
Rob Hickman cell (503) 701-5042
ScooterF15
Posted: Wed Oct 10, 2007 5:32 pm Post subject: Angle of Attack Probe Vs Stall Warning Vane |
Thanks. I'll take a look at those things.
-Jim
In a message dated 10/10/2007 8:46:37 P.M. Eastern Daylight Time, RobHickman(at)aol.com writes:
| Quote: | In a message dated 10/7/2007 7:30:51 PM Pacific Daylight Time, JSMcGrew(at)aol.com writes:
Sincerley,
See what's new at ww.aol.com?NCID=AOLCMP00300000001170" target="_blank">AOL.com and
