		txpilot
				 Posted: Mon Oct 08, 2007 8:07 am    Post subject: 701 Fuel System with Rotax 912S |
				I have a couple questions regarding the fuel system.  According to the Rotax installation manual, a return line is required from the fuel manifold back to the fuel tank.  I spoke with ZAC about this since the 701 plans make no mention of this return line.
 They said the return line is not necessary if you're running 100LL because of the reduced chance of vapor lock.  Although I plan on running only 100LL, I'm wondering if any other builders are installing a return fuel line.  If there are builders installing return lines, do you go to a wing tank or to the gascolator?
 I spoke with my EAA tech adviser and he wasn't sure.  He did make another suggestion:  use stainless steel fuel lines instead of the supplied 1/4" rubber hose.  That leads me to another question for the forum:  are there any builders experiencing problems with their rubber hose fuel lines, or are stainless steel fuel lines an overkill?
 Dan Ginty
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		gfmjr_20(at)HOTMAIL.COM Guest
				 Posted: Mon Oct 08, 2007 1:02 pm    Post subject: 701 Fuel System with Rotax 912S |
				Dan--
    Many rotax engines are run without a return line.  The major reason for the return line is to help avoid vapor lock when using autogas.  I did install a return line in the system on my 601xl because I mostly use autofuel. If you usage of auto fuel is minimal, I'd skip the return line.
     You can ever go wrong using the stainless steel line in the engine compartment, but I personally think it is overkill for the mission of our planes.  The rubber fuel line will suffice and if in doubt about they can be relatively easily changed out every couple of years
  George May
  601xl 912s  162 hrs
  	  | Quote: | 	 		   Subject: 701 Fuel System with Rotax 912S
  Date: Mon, 8 Oct 2007 09:07:07 -0700
  --> Zenith-List message posted by: "txpilot" <djg7(at)comcast.net>
  Dan Ginty
  http://forums.matronics.com/viewtopic.php?p=138777#138777
 Windows Live Hotmail and Microsoft Office Outlook – together at last. Get it now!  [quote][b]
