		poneill(at)irealms.com Guest
				 Posted: Mon Oct 08, 2007 12:52 am    Post subject: Drillbit extensions |
				I'm planning to enlarge the wiring run holes in the QB wings in the next
 week or two and I am trying to locate a source for a drill bit extension
 that will accommodate the unibit's 3/8" shank.  I can find many 1/4" and
 7/16" shank extensions, but so far I have found none for a bit with 3/8"
 shank.
 The ones I have been looking at are the 12" or 18" extensions (planned on
 using several as required) with Allen head screws to secure the bit in the
 extension.  I don't believe an extension for a 7/16" shank would work
 because of the difficulties centering the bit.  The last thing I want is a
 crazed unibit wreaking havoc inside the wings.
 I know some homegrown solutions were discussed here not long ago, but does
 anyone have a good recommendation or online source for such extensions?
 Best Regards,
 Patrick #40715
		tomhanaway
				 Posted: Mon Oct 08, 2007 1:49 am    Post subject: Re: Drillbit extensions |
				I just went through this on my 10 QB wings.  The other issue is that any head that holds a 3/8 shank is bigger than the max 3/4" recommended hole.
 Avery tools makes a 12" extension where the size of the head has been cut down to just fit through the 3/4" hole yet it holds a 3/8" shank.  Works great.  Plus, although not necessary for this portion of the project, you can easily extend the 12" extension with standard 1/4 " extenders since the shank of the Avery tool is 1/4".
 Of course, if you live in South Florida, you're welcome to borrow mine :^)
 Tom Hanaway
		johngoodman
				 Posted: Mon Oct 08, 2007 6:58 am    Post subject: Re: Drillbit extensions |
				Patrick,
 I just finished that step. Instead of enlarging, I put in another set of holes. Here's how I did it. First, made a template so they would line up. In the open bays, I used a #30 to start a pilot hole, then followed up with a unibit to 3/8". This size is perfect for a #4 snap bushing. Instead of the unibit I got from Avery, I went to the Home Depot Aviation Supply Store and bought a #1 unibit, which has a 1/4" shank. It was easier to use in my smaller Sioux drill (it fits in a bay).
 For the areas that have been skinned, I started a pilot hole in the wing root rib using the same template with a #30. I marked the next rib with the template and then pulled out the 12 inch long #30 I got from Avery. Once the second rib is drilled, the two holes acted as a guide for the rest. You do need to pull the inspection port a little further in, but you get the picture.
 Next, I went to the Ace Hardware Aviation Supply Store and bought a metal cutting 12 inch long 3/8" drill bit. After using the unibit on the wing root pilot hole, I switched over to the long 3/8" bit and it went like a dream. Used my hand held cordless set to a high speed because the shank is 3/8".
 If you have already skinned everything in, the outer bays could still be done with the shank extensions you talked about. Using the smaller #1 unibit, you could assemble it in place between each rib. Drill the hole, disassemble, and repeat. Hope this helps.
 John
  	  | poneill(at)irealms.com wrote: | 	 		  I'm planning to enlarge the wiring run holes in the QB wings in the next
 shank.
 Best Regards,
 Patrick #40715 |
  _________________ #40572 Phase One complete in 2011 |
		Mike Whisky
				 Posted: Mon Oct 08, 2007 7:40 am    Post subject: Re: Drillbit extensions |
				Patrick,
 I used an extension I got from Avery tools and but a metric Unibit in. I drilled the holes to the perfect size so that the Vans conduits fitted nicely once you got it in.
 http://www.averytools.com/p-533-6-12-step-drill-extensions.aspx
 check out my website
 www.wellenzohn.net
 Michael
  _________________ RV-10 builder (flying)
#511 |
				 Posted: Tue Oct 09, 2007 5:19 am    Post subject: Drillbit extensions |
				So Avery has one eh? How in the heck did I miss that.  I thought I made all
 the rounds to check the preferred places.
 How many extensions did you end up needing (Avery + how many regular 12") to
 get all the ribs under the QB attached bottom skins?
 Also where do they caution against using larger than 3/4" hole?  I've seen
 others use and was thinking about running the Van's nylon conduit and I
 think it requires a bit larger than that.
 Unfortunately, I'm in So-Cal otherwise I'd take you up on the offer and put
 an end to this item!
 Best Regards,
 Patrick #40715
				 Posted: Tue Oct 09, 2007 5:25 am    Post subject: Drillbit extensions |
				Hi Michael,
 What size hole did you end up drilling for the Van's conduit?
 Also what did you do if anything to secure the conduit in place?
 Thanks!
 Best Regards,
 Patrick #40715
				 Posted: Tue Oct 09, 2007 5:37 am    Post subject: Drillbit extensions |
				Hi John,
 I didn't consider that a smaller Unibit might have a smaller shank.  Very
 helpful!
 How did you go about making a template?  I was thinking about making a
 second conduit run for most of the wire runs and using the one called for in
 the plans for the strobe.  I'm not quite sure how to make the most effective
 template for this.  That would certainly simplify things.
 But that does help a lot, thank you very much.
 Best Regards,
 Patrick #40715
		Mike Whisky
