Yak 52 engine at cruise
john_graham
PostPosted: Wed Oct 10, 2007 5:15 am    Post subject: Yak 52 engine at cruise Reply with quote
Is there any danger or harm to the engine if I leave
the throttle and prop at "7 squared" for extended
periods of time while just cruising along? I don't
want to foul any plugs, but I have been flying at this
setting as it seems to be fairly economical with
respect to gph.
John P. Graham
CubFlyer1940(at)Yahoo.com
Cell phone (847) 641-1330
Tonight's top picks. What will you watch tonight? Preview the hottest shows on Yahoo! TV.
John Graham
N15YK 1993 Yak-52
CubFlyer1940@Yahoo.com
(847) 641-1330
dsavarese(at)elmore.rr.co
PostPosted: Wed Oct 10, 2007 5:52 am    Post subject: Yak 52 engine at cruise Reply with quote
There is nothing wrong with running the engine at those settings. Take a
look at the Russian M14 power setting chart. These settings will give you
the most efficient settings. As you will/can see, running the engine
"oversquare" is the most efficient power setting in cruise.
Dennis
viperdoc(at)mindspring.co
PostPosted: Wed Oct 10, 2007 5:59 am    Post subject: Yak 52 engine at cruise Reply with quote
No, not at all. The harm comes in not watching the cylinder head temps and
oil temps. The temps are seldom a problem at 70/700 as long as your gills
(shutters/cowl flaps) are appropriately positioned. That engine like 70%,
80%, 60% ect as long as it is not to hot. She almost bullet proof as long as
you don't get her to hot and especially if you keep her there.
Doc
cpayne(at)joimail.com
PostPosted: Wed Oct 10, 2007 3:23 pm    Post subject: Yak 52 engine at cruise Reply with quote
And what IAS might you see at a given altitude, using that 70 squared setting?
Craig Payne
cpayne(at)joimail.com (cpayne(at)joimail.com)
craig(at)ustek.com
PostPosted: Thu Oct 11, 2007 2:43 am    Post subject: Yak 52 engine at cruise Reply with quote
Approx 130kts at 3-5K FT (fuel flow on the EI shows 16-18GPH)
Sent: Wed 10/10/2007 7:22 PM
To: yak-list
Subject: Yak-List: Re: Yak 52 engine at cruise
Craig Payne
netmaster15(at)juno.com
PostPosted: Thu Oct 11, 2007 8:12 pm    Post subject: Yak 52 engine at cruise Reply with quote
wHEN YOU DECIDE THAT YOU CANNOT KEEP THE ENGINE RUNNING BY PUMPING AND MAKING IT TO THE RUNWAY IS QUESTIONABLE DONT FORGET TO PULL THE PROP ALL THE WAY BACK INTO HIGH PITCH- - LOW RPM--- yOU DONT NEED A SPEED BRAKE OUT FRONT
To: yak-list
Craig Payne
arget=_blank>http://www.matronics.com/Navigator?Yak-List
http://forums.matronics.com/
)­æß¢{l‹7·g(–ŠôÓM4Ñöœ{pÜ¢êâz¹ÞÁÊ.®'«Ü=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ4áy†¤.+-f¢”Z+ºmÃRÇ­…㶺'‰Ë ŠËEy«n­ëjø jÚ+¶†ë£ Ü;azf§È¸¬¶ëb–+bzË.r¬¶’¹»®*mŠ‰ì¥¨Ü0+r¯y'š­ÈC£ å¡§{¬�®Œ,x(Z´PÜ3á¢Ú,…ªÞjwf¹Èf¹Èf¢··¨kyýÆÛiÿü0Âf­®‰ârÇ(›óZ¾(¶ŠØjBâ²Øm¶Ÿÿà &jÚèž',r‰¿5«â�«h­†¤.+-ý­ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=Ã4EŒ4N4€’X(at)E9 KpÒjg ­æ­r‰íz{g£¥²†¯j)ZnW¯‰«ayg›ŠîšÍÃjÞpá¶Úýú+ºk&jÚèž',r‰¡¶Úýú+ºk&jÚèž',r‰¿kp÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷öÿ~‰íþšÞýºËømš]}
_____________________________________________________________
Vonage - Official Site
$24.99/mo. for unlimited local and long distance calls!
