Posted: Tue Oct 09, 2007 1:52 pm Post subject: Remaining questions for routing stuff under the floors |
At this point I think I have most of the electrical wiring in place:
- (2) Main power lines 2AWG and 8AWG for dual R14 dual batt/dual alt scheme
- (3) solenoid control lines for main power and crossfeed solenoids
- (2) shielded lines for left and right wing strobes
- (1) power line for strobe power supply
- (1) power for tail light
- (1) 7 multi conductor bundle for elevator trim
Yet to go are:
- (1) antenna coax for 1 comm anttenna (the other will go in wing tip or
upper fuse
- (2) Van's conduit for future revisions
- (1) for activation of projected new generation ELT (??)
Remaining questions are:
- What do I run for AHRS for projected dual Chelton panel
- Battery Bus - I'm thinking 3 lines for things like clock(?), dome
light and (??)
- Where does the static line run - can't find in plans or in archives
but I'm sure I've seen it before. Does it go thru center or along one
of the sides?
I'm assuming:
- That GPS and transponder anttennas will be forward of seats and/or in
cabin top
- Nav and Marker antennas will be in tips
- Nothing else can be run down the accessible center channel to avoid
interference with control system
All comments welcome.
Bill "filling up the fuselage bottom with systems" Watson
Durham NC #40605
LarryRosen
Posted: Tue Oct 09, 2007 3:17 pm Post subject: Remaining questions for routing stuff under the floors |
How about:
Pitch trim for autopilot. TT uses (1) 20AWG power, (1) 20AWG ground,
(6) 22AWG control. (use Stein's pre-twisted bundle
<http://www.steinair.com/wire.htm>
Run an RG-400 for a gps or some other antenna that you may want to add
to the rear of the canopy
Run the static line along with the wire.
Consider pulling some spare twisted pairs. I added a 3 and a 4
conductor. Who knows what I will use them for.
Consider 1 larger wire for the battery feed to a fuse block forward.
Will there be rudder trim in the future? (there's another 7 wires)
For the Chelton MSU (I will mount the GHARDS up front) you need (1) 3
conductor 22AWG shielded, (2) 22AWG power, (4) 22AWG ground
Strobe ground or ground local.
Larry Rosen
#356
MauleDriver wrote:
scheme
Yet to go are:
or upper fuse
light and (??)
of the sides?
I'm assuming:
in cabin top
Durham NC #40605
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Posted: Wed Oct 10, 2007 11:24 am Post subject: Remaining questions for routing stuff under the floors |
Thanks Larry... Perfect! That helps a lot.
Larry Rosen wrote:
How about:
Larry Rosen
#356
> scheme
> Yet to go are:
> or upper fuse
> light and (??)
> one of the sides?
> I'm assuming:
> in cabin top
> Durham NC #40605
