Instrument Panel Access
Goto page 1, 2  Next
johnd(at)data-tech.com
PostPosted: Wed Oct 10, 2007 9:30 am    Post subject: Instrument Panel Access Reply with quote
Hi All,
I'm just wrapping up my electrical work and am getting close to putting
on the front skin over the panel area. Riveting it per the factory seems
to be a poor choice since I wont have any easy access to the rear of the
panel.
So it seems like the options are:
A) Install nutplates or similar and make the entire skin removable. As I
have a QB kit their are already 90+ rivet holes that would have to be
fitted, so thats a lot of work.
B) Install the skin permanently but add a couple of access panels on the
top. Seems like several folks on the list are doing this. My only
concern with this approach would be water leaking under the access
panel. Any ideas as to how to prevent/avoid this issue ?
Your thoughts/Ideas ?
Thanks in advance,
John Davis
Burnsville, NC
601XL QB - Jab 3300
Jaybannist(at)cs.com
PostPosted: Wed Oct 10, 2007 11:23 am    Post subject: Instrument Panel Access Reply with quote
John,
I have posted drawings of my access panel. Let me know if you would like me to e-mail them to you. I set the doubler in silicone sealant. When I install the cover plate, I will run a bead of silicone around the exposed part of the doubler and cover that with Saran before temporarily fastening the cover. When the silicone has cured, I will remove the cover and Saran and have a "permanent" gasket.
Jay in Dallas 601XL N2630J
John Davis <johnd(at)data-tech.com> wrote:
Hi All,
panel.
Thanks in advance,
John Davis
Burnsville, NC
601XL QB - Jab 3300
SkipperClyde
PostPosted: Wed Oct 10, 2007 12:45 pm    Post subject: Instrument Panel Access Reply with quote
I have seen sheet metal screws used instead of rivets.
phil
Gig Giacona
PostPosted: Wed Oct 10, 2007 1:18 pm    Post subject: Re: Instrument Panel Access Reply with quote
I'm using J-Nuts and screws all the way around the top skin.
http://www.mcmaster.com/nav/enter.asp?pagetype=ships&visitorinput=wr.giacona%40suddenlink.net&retrieveoutcome=FAILED_TO_IDENTIFY&inputtype=&search=&resultsContext=ORDNAV&resultsQueryStr=loademailform%3Dtrue
phil
W.R. "Gig" Giacona
601XL Under Construction
VideoFlyer(at)aol.com
PostPosted: Wed Oct 10, 2007 1:42 pm    Post subject: Instrument Panel Access Reply with quote
In a message dated 10/10/2007 , wr.giacona(at)suddenlink.net writes:
<<<<I'm using J-Nuts and screws all the way around the top skin>>>
I did the same thing.
Dave
N618PZ
601XL/Corvair
S> [quote][b]
graeme(at)coletoolcentre.
PostPosted: Wed Oct 10, 2007 2:07 pm    Post subject: Instrument Panel Access Reply with quote
I think the savanna has a good idea for instrument panel.
The hole instrument panel panel is a removable, screwed (probably with
rubber insulation for vibration) to
a riveted in frame for easy access.
Graeme Cairns
PostPosted: Wed Oct 10, 2007 2:10 pm    Post subject: Instrument Panel Access Reply with quote
Are you guys aware that the cowling overlaps the forward top skin? Therefore, you will have to remove the cowling to remove that skin for access. At least for the WW cowling, there is a tapered channel that fastens to the nose bowl and the top skin to support and locate the nose bowl. Seems like having to remove the cowling kinda' defeats the purpose, or at least makes access a pretty involved process. Hopefully, you will never have to access it and then difficulty becomes a moot point.
Dave
N618PZ
601XL/Corvair
GLJSOJ1
PostPosted: Wed Oct 10, 2007 2:48 pm    Post subject: Re: Instrument Panel Access Reply with quote
HI JOHN
WHAT I DID WAS MARK WHERE THE CANOPY TOUCHED THE FORWARD TOP SKIN AND MADE A SET OF ACCESS HOLES ON BOTH SIDES JUST SMALLER SO I COULD PUT ANCHOR NUTS AND SCREWS TO HOLD IT IN PLACE. THEN I MADE A LARGE COVER TO COVER BOTH SIDES. IT'S NOT TOTAL ACCESS, BUT I CAN AT LEAST GET BEHIND THE PANEL
GLENN
601XL N676L FLYING PHASE I
CHESAPEAKE VA
davgray(at)sbcglobal.net
PostPosted: Wed Oct 10, 2007 4:30 pm    Post subject: Instrument Panel Access Reply with quote
The tapered top center section of the cowl for the WW nose bowl has hinges
that allow access to the engine compartment from the top. There are only
about four screws in the center that hold this to the top forward skin and
about 6 to 8 screws that hold it to the center top section of the nose bowl.
This part can be removed in under 1 minute.
When you remove the top center section of the cowl you expose the firewall
forward to the nose bowl while the top forward skin covers the firewall
backward to the instrument panel. With a nutplated system I can open my
aircraft from the instrument panel to the nosebowl in less than 3 minutes
and replace it in under 5 minutes in two pieces.
Total work to dimple and rivet nutplates was about 2 to 3 hours extra work
and it makes it easy access when wiring, troubleshooting, repair,
inspections or modifications. I have removed it at least 15 times during
construction and during the first year. I did mine with # 8 floating
nutplates, #8 machine screws made flush with a dimple die in my rivet
squeezer.
The only problem I had was setting rivets in curved sections of the firewall
flange. Pulling the nutplate down with a screw to make the nutplate conform
to the curve prior to setting the rivets made it accurate and easy. Also
avoid crimped sections of the firewall when placing the nutplates.
Gary Ray
shilcom
PostPosted: Wed Oct 10, 2007 4:43 pm    Post subject: Instrument Panel Access Reply with quote
Caution here Jay. I did the silicone thing on a Cessna once and never could get them to quite sticking. Tried powder, which worked the best, but every annual they were stuck tight. Bob U.
PostPosted: Wed Oct 10, 2007 5:22 pm    Post subject: Instrument Panel Access Reply with quote
Bob, Thanks for the heads up. I just might have to rethink my sealing method. Maybe a thin foam tape? - Jay
"Bob Unternaehrer" <shilocom(at)mcmsys.com> wrote:
[quote]Caution here Jay. I did the silicone thing on a Cessna once and never could get them to quite sticking. Tried powder, which worked the best, but every annual they were stuck tight. Bob U.
purplemoon99(at)bellsouth
PostPosted: Wed Oct 10, 2007 6:29 pm    Post subject: Instrument Panel Access Reply with quote
Any chance of getting a couple picts? I'am doing a lot on the panel,and
have to take the whole dash top off every time It's a real pain. I was
thinking of a over lap where the cowl would be atached to a short section
that was pop riveted to the top of the fire wall and could ovre lap inside
the plane with screws etc. Joe N101HD 601XL/RAM
tonyplane(at)bellsouth.ne
PostPosted: Wed Oct 10, 2007 7:54 pm    Post subject: Instrument Panel Access Reply with quote
John,
One of the BEST decisions I made was to make the fwd top skin removable. I used rivnuts and 6-32 SS screws. Others have used nutplates and J clips?? etc.
With the skin removed, you have access not only to the instrument panel, but to the inside fwd firewall, rudder peddles and cables, steering rods, brakes, etc.
Also, I have removal of the top skin part of my annual condition inspection to check wiring, and other areas under the instrument panel that would be a real problem to inspect with the skin in place.
I also have a removable panel aft of the canopy "line" on the top skin. On it, I have provisions to mount 1 or 2 Garmin GPSs (One for the pilots side and one for my spouse's side) and have also mounted a vertical compass card.. Coming through this panel I have compass lighting wiring and hard wiring for the GPS's through grommeted holes that have a slots leading to the holes from the edge of the panel.. When I remove the top skin, I remove this panel first and can leave the wiring intact by passing it through the slot.
You can see my instrument panel at http://www.zenithair.com/zodiac/6-photo79.html (Zenith Photo Library #79) as originally finished, but since I have added some "Stuff" , such as a switch and a blinking light to show "Wig-wag" taxi/landing lights, another switch to use either Garmin GPS to drive my AP, a light to show when I have the aux fuel pump on, a Tru-Track T&B, and ...
I really like what you can easily do with your airplane when it is "Experimental". If I had to drill out the top skin rivets to gain access to the instrument panel aft areas, it would not be as much fun and also I believe would result in a real mess to clean up.
Tony Graziano
XL/Jab3300; N493TG; 304 hrs
Subject: Instrument Panel Access From: John Davis (johnd(at)data-tech.com ([email]johnd(at)data-tech.com?subject=Re:%20Instrument%20Panel%20Access&replyto=470D085D.6000304(at)data-tech.com[/email])) Date: [b]Wed Oct 10 - 10:30 AM[/b]
Hi All,
panel.
Thanks in advance,
John Davis
Burnsville, NC
601XL QB - Jab 3300
shilcom
PostPosted: Thu Oct 11, 2007 3:42 am    Post subject: Instrument Panel Access Reply with quote
I'm not sure why you need anykind of sealing. I've never seen any seals on certified airplanes, but there may be. My wife sometimes applies a phrase to me that might apply here....Don't over think it bob. My purpose was to tighten them up and prevent vibration and coming loose, but I don't think that is necessary now. I do use nylon washers on the SS screw heads. Bob U.
archerm
PostPosted: Sun Oct 14, 2007 5:12 am    Post subject: Instrument Panel Access Reply with quote
Matt
www.zodiacxl.com
archerm
PostPosted: Sun Oct 14, 2007 5:13 am    Post subject: Instrument Panel Access Reply with quote
I put hatches in the forward top skin. This has really been valuable to get
at stuff and seems to work well. I was a little concerned about the canopy
interference but now that the canopy is on I haven't had a problem. Check
it out.
http://www.zodiacxl.com/Fwd%20Top%20Skin.htm
Matt
www.zodiacxl.com
Matt
www.zodiacxl.com
PostPosted: Sun Oct 14, 2007 12:18 pm    Post subject: Instrument Panel Access Reply with quote
Very Nice! Going to use your idea , if you don't mind. Lot's of room to
work .Perfect place for fire ext.too, Did you use short self tappen screws
when you mounted the fire ext bracket to the spar? Joe N101 HD
601XL/RAM
----- Original message -----
To: <zenith-list(at)matronics.com>
Sent: Sunday, October 14, 2007 9:07 AM
Subject: Re: Instrument Panel Access
get at stuff and seems to work well. I was a little concerned about the
canopy interference but now that the canopy is on I haven't had a problem.
Check it out.
Matt
www.zodiacxl.com
rge177(at)yahoo.com
PostPosted: Mon Oct 15, 2007 7:07 pm    Post subject: Instrument Panel Access Reply with quote
Nice job Matt. I did something similar, but didn't
hinge them, and they are a little smaller, but very
helpful getting behind the panel. I put a pic in the
photo share.
Ron
601XL-3300
Time: 06:13:36 AM PST US
to get
concerned about the
canopy
had a problem.
Check
it out.
Matt
www.zodiacxl.com
archerm
PostPosted: Wed Oct 17, 2007 8:54 am    Post subject: Instrument Panel Access Reply with quote
I ended up riveting the extinguisher bracket to the spar. I had to drill
some new holes in it but it worked fine.
Good Luck
Matt
www.zodiacxl.com
Matt
www.zodiacxl.com
Ron Lendon
PostPosted: Wed Oct 17, 2007 6:13 pm    Post subject: Re: Instrument Panel Access Reply with quote
What kind of effect will those holes have on the integrity of the center spar? Has anyone given that consideration or better yet, structural analysis. Inquiring minds want to know.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
Goto page 1, 2  Next
Page 1 of 2
