Posted: Wed Oct 10, 2007 12:00 pm Post subject: Antenna Selection & Location |
Dear 10-List,
It's time to select my antennas and place them on the plane. Here is my minimum list of antenna:
Recap ~$ Location
CI-122 Comm $140.00 Belly
CI-105 Transp. $100.00 Belly
CI-102 Marker $100.00 Belly
Archer #1 VOR $85.00 Internal Win Tip
GPS GA-35 GPS $350.00 Canopy Top
XM Antenna Included Canopy Top
Geeez, Can you hear me now?
The XM Antenna is included with the purchase of my Garmin GDL-69a receiver.
I am thinking of replacing 1 GA-35 GPS antenna and the XM antenna and buying a combo GPS/XM antenna from Comant (CI 401-460 http://www.comant.com/pdfs/CI_401-460.pdf ) They offer a couple of different models so when Tech Support calls me back I can get their best recommendation. This will eliminate one bump/penetration on my canopy.
Regarding location I reviewed the archives and Tim's Antenna page including Comant's suggested antenna location: http://www.myrv10.com/files/antennas/comant/Comant_Suggested_Antenna_Locations.pdf
My current plan is to place the antennas in these locations:
Shark Blade just aft of the exhaust outlet
Marker Beacon basically between the main gear or aft of the rear bulkhead
2 Comm side by side aft of the main gear but forward of the step
Archer VOR in each wing tip
2 GPS plus 1 XM in tandem on top of canopy around where the rear window ends OR
1 GPS & 1 GPS/XM antenna in tandem on top of canopy around where the rear window ends
I see Tim has one GPS antenna near the rear bulkhead and one just behind the windscreen. Tim also has his marker antenna aft of the bulkhead and the Comm antenna side by side in the location I am proposing.
Other than seeing if I can get Tim to finish my plane...Can I get any comments on my antenna selection and placement?
Thanks in advance,
Robin
RV-4 Sold
RV-6A 400 hours
RV-10 BPE engine Ships next week
rene(at)felker.com Guest
Posted: Wed Oct 10, 2007 12:20 pm Post subject: Antenna Selection & Location |
My configuration is similar to yours except I went with the Bob Archer
Marker Antenna.......40" piece of wire out in the wing tip. I am not flying
yet, so can not tell you how they work.
Put my 1 GA-35 on the top right behind the baggage bulkhead. When I rolled
my A/C out in front of the hanger, the Garmin came alive within about 30
seconds......
Rene' Felker
N423CF
40322
801-721-6080
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Wed Oct 10, 2007 12:21 pm Post subject: Re: Antenna Selection & Location |
| robin1(at)mrmoisture.com wrote: |
Thanks in advance,
Robin
RV-4 Sold
RV-6A 400 hours
RV-10 BPE engine Ships next week |
Hay Hay Hay, hold your horses. Get in line. I got my request in first.
His plane is finished so what does he have to do now?
About the antenna placement, I am about 2 months behind you so I am listening also.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
LloydDR(at)wernerco.com Guest
Posted: Wed Oct 10, 2007 1:21 pm Post subject: Antenna Selection & Location |
I did the two comms on the belly, transponder in the center forward, Archer VOR's in each wing tip, and per Checkoways site used 40" of stripped coax for the marker beacon glassed into a wing tip. I use the GPS antenna that came with the pinpoint mounted just aft of the cabin top and the portable GPS ant is on the glare shield to aid in removal. All works well with testing, and am happy.
Dan
N289DT RV10E Flying
RobHickman(at)aol.com Guest
Posted: Wed Oct 10, 2007 3:15 pm Post subject: Antenna Selection & Location |
I just received my Garmin 430W and the GA-35 is included with it.
This is perfect timing, I was just getting ready to install all the antenna's and you have exactly what I do.
I attached the latest panel drawing. It is being laser cut and I should have it later this week. The only change I am going to make is that I no longer need the three dimmer knobs. We are about to release a smart dimmer module that will enable the AF-3500 EFIS to control external lighting circuits from the EFIS.
Rob Hickman Advanced Flight Systems
N401RH RV-4 (500+ hours)
N402RH RV-10 Mounting Antenna's and trying to get the doors to fit.
Posted: Wed Oct 10, 2007 4:40 pm Post subject: Antenna Selection & Location |
Nice panel layout, Rob. What are those big screens you are using in your panel? J
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
From: RobHickman(at)aol.com [mailto:RobHickman(at)aol.com]
Sent: Wednesday, October 10, 2007 6:15 PM
Subject: Re: Antenna Selection & Location
Posted: Wed Oct 10, 2007 4:43 pm Post subject: Antenna Selection & Location |
Thanks for the antenna plan - very useful for this builder.
I'm trying to do with less antenna on my ship but with equivalent
function. I'd appreciate thoughts from the list on the following thoughts:
- Most of my flight guidance, including precision approaches, will be
using GPS. At least that's what the autopilot will be using.
- So, I'm planning on a single Nav and that Nav antenna is going in a
wing tip
- Marker beacon use barely fogs a mirror. Even when flying an ILS in
the Maule, the GPS info just trumps it. But I will have the capability
driven by the cheapest, lowest profile antenna I can fabricate -
stripped coax I guess
- I want dual comm but my experience is that I'll use only one for all
flight ops. Sometimes it's nice to use the other one for Clearance
Delivery or something but the more function in the primary comm, the
less the secondary comm is used. Backup is nice and handhelds have
limitations as a backup (management of batteries, anttena setup, and it
has to be on the checklist)
So my minimum has only one assymetrically mounted comm on the belly,
single Nav, secondary Comm and marker in wingtips. Whatever the GPS
units require on the top. And a transponder poking out of the belly in
front somewhere. I haven't gotten much further yet. I think that
will work.
Bill "installing empty conduit" Watson
Durham NC #40605
Robin Marks wrote:
Dear 10-List,
Recap ~$ Location
Thanks in advance,
Robin
RV-4 Sold
RV-6A 400 hours
rvbuilder(at)sausen.net Guest
Posted: Thu Oct 11, 2007 8:15 am Post subject: Antenna Selection & Location |
If you want to save a couple bucks on the MB antenna, you can strip a 40" section of RG58 or similar so that the center conductor is exposed. MB's are so tightly focused lot's of old timers say you can pick it up with a coat hanger sticking out the back of the receiver and in some cases with nothing. Somewhere in my logs I wrote up some stuff on it but can't remember what section anymore.
Michael
Posted: Thu Oct 11, 2007 9:01 am Post subject: Antenna Selection & Location |
Thanks Michael,
Yes after I sent the request I decided on a single Archer 1 and
was debating on the RG58 vs. the CI-102 Marker Antenna. I don't mind
removing one more item form the slipstream.
Michael are you good with my proposed location for the Comm
antenna? My Comms should be plenty powerful with dual 16 Watt
transceivers.
If I really wanted to save money on antennas I would call Garmin
and complain that their $60,000+ G900X should come with GPS antennas.
Every other GPS they make (as far as I know) come with an antenna, why
not the G900X?
Robin
orchidman
Posted: Thu Oct 11, 2007 7:15 pm Post subject: Re: Antenna Selection & Location |
| RobHickman(at)aol.com wrote: |
N402RH RV-10 Mounting Antenna's and trying to get the doors to fit. |
Rob,
Did the drawing get deleted? I am not seeing it or any link. Very interested in seeing it as we talked a couple days ago about all of this.
RV10 - # 40674
(N2GB Flying) |
Posted: Sat Oct 13, 2007 9:35 am Post subject: Antenna Selection & Location |
"We are about to release a smart dimmer module that will enable the AF-3500 EFIS to control external lighting circuits from the EFIS"
being I am one of those getting the dual 3500 please keep us informed on any updates you make.
Thanks!
Pascal
