Posted: Sat Oct 13, 2007 6:15 pm Post subject: PC-680 Performance |
Over the years, the Odyssey PC-680 has gotten very good reviews for its small size and high cranking amps. So, about 3 years ago, I selected one to replace a 4 year old Concorde battery.
My first Odyssey battery became weak after just under 2 years. The vendor replaced it under warranty.
Today, my ~14 month old replacement battery barely turned the engine over on a 80 degree day. Sure, the aircraft sat outside in 45 degree weather last night (Thomasville GA Fly-in - a really fun one), but the airplane had 8 hours of South Georgia sunshine to warm up, so is isn't like the battery was chilled or anything.
To get to the point, what is the RV-list's collective experience with this battery? I know it is light and has good cranking power when new, but I'm interested in what sort of longevity people are seeing. Is it lasting 1 year, 2 years, more, or less? I'd hate to go back to the Concorde, but I'd prefer that to a battery that goes soft after less than two years.
KB
walter(at)tondu.com Guest
Posted: Sat Oct 13, 2007 7:46 pm Post subject: PC-680 Performance |
Since the battery is relatively cheap, just above $100, I replace it
at every annual. This gives me peace of mind knowing I have a fresh
battery and I now have a decent backup or something to play pass the
electrons with in the shop.
I always connect to a trickle charger after each flight just to keep
it tip-top. I've never had a battery issue now in two years. ymmv.
Walter Tondu
http://www.rv7-a.com - Painting
http://www.evorocket.com - Empennage
capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Sat Oct 13, 2007 9:26 pm Post subject: PC-680 Performance |
in 2000 i purchased a pc680 for install in my 6a before it was completed. i used it to test and power up systems during final assembly. first flight in 2001- fast foreword to 2007, still going strong. I've left the master on twice in its life killing it completely. it seemed to recharge without incident. now i haven't done any discharge calculations to find out its true capacity, but it has no problem starting the o-360 after 10 days of inactivity. i have never used any trickle charger and don't remember having to jump start it when it wasn't my fault. I'd say it's probably hands down the best battery I've ever owned.( i even have one in my kids battery powered ride on truck) I'm using a B&C alternator and lr3 regulator using standard wet cell voltages.
Steven dinieri
iflyrv10.com
capsteve(at)adelphia.net (capsteve(at)adelphia.net)
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kyle Boatright
Sent: Saturday, October 13, 2007 10:08 PM
To: rv-list(at)matronics.com
Subject: PC-680 Performance
KB
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
lifeofreiley2003(at)yahoo Guest
PGLong
Posted: Sun Oct 14, 2007 5:12 am Post subject: PC-680 Performance |
I've had my PC-680 going on 5 years. Did run it flat once with the master left on. Didn't seem to affect it as it would had it been a lead acid battery. I never need to trickle charge it. Left last winter in the hangar without flying for five months. Put the charger on to see how it was in the spring and the charger indicated it was at full charge after 5 seconds of charge time. I personally can't say enough good about Odyssey's products.
Pat Long
PGLong(at)aol.com
N120PL
RV 4
Bay City, Michigan
3CM
S> [quote][b]
_________________ Pat Long
RV-4, N120PL
Bay City, MI |
tcervin(at)valkyrie.net Guest
Posted: Sun Oct 14, 2007 6:58 am Post subject: PC-680 Performance |
The Odyssey battery in my RV6-A is 4 years old and still cranks the 0-360A1A over just like day one! I have the B&C alternator & regulator which I feel is the key reason the battery is always ready to go.
After shutting down and attaching the BatteryMinder the green light starts flashing within a minute.......probably not needed. I live in Ohio and run a Reiff preheater with cylinder bands in the winter.
Tom in Ohio (10G)
Vanremog(at)aol.com Guest
Posted: Sun Oct 14, 2007 9:37 am Post subject: PC-680 Performance |
In a message dated 10/13/2007 10:31:27 P.M. Pacific Daylight Time, capsteve(at)adelphia.net writes:
| Quote: | | in 2000 i purchased a pc680 for install in my 6a before it was completed. i used it to test and power up systems during final assembly. first flight in 2001- fast foreword to 2007, still going strong. I've left the master on twice in its life killing it completely. it seemed to recharge without incident. |
I always put the Power Sonic two stage charger on mine when not flying because I have a "keep alive" circuit in my am/fm radio that uses just a little power to retain the memory. Mine last for several years each with this treatment.
N1GV (RV-6A, Flying 869hrs, O-360-A1A, C/S, Silicon Valley)
lessdragprod(at)aol.com Guest
Posted: Sun Oct 14, 2007 10:54 am Post subject: PC-680 Performance |
Hi Kyle,
I have an Odyssey battery in my RV-6A. I was told that it needed to be charged at 14.2 volts. If it was charged at a lower voltage, it would gradually loose capacity from being undercharged.
I don't have a source for the 14.2 volts. I didn't find it on the Odyssey battery website. Anyone know where the correct charging voltage is documented?
Jim Ayers
rcnewman(at)mycingular.bl Guest
Posted: Sun Oct 14, 2007 12:09 pm Post subject: PC-680 Performance |
I found some excellent information on charging of AGM seal lead acid batteries on the panasonic web site. If I remeber it takes a little digging on their site, but its there. I believe the charging voltage depends primarily on chemistry type. (Ie sla-agm) and temperature.
-bob newman
Sent via BlackBerry by AT&T
Posted: Sun Oct 14, 2007 1:36 pm Post subject: PC-680 Performance |
Thanks Walter! I will stick a note on the calendar. They do come in handy on the work bench for sure.
I guess we'll figure out the details then.
Darrell
jeffpoint
Posted: Sun Oct 14, 2007 1:47 pm Post subject: PC-680 Performance |
Ditto what others have said about charging voltage. AGMs like a higher
voltage. I don't have the paperwork handy, but I believe it was 14.2 or
14.4. If you regulator is set below 14 (likely scenario) than that
would explain the short life.
Jeff Point
RV-6 flying
RV-8 building
Milwaukee
_________________ Jeff Point
RV-6
Milwaukee WI |
Posted: Sun Oct 14, 2007 4:48 pm Post subject: PC-680 Performance |
The next issue is how does one go about adjusting the Ford voltage regulator
I installed per Electric Bob's suggestion?
KB
sbuc(at)hiwaay.net Guest
Posted: Sun Oct 14, 2007 6:01 pm Post subject: PC-680 Performance |
regulator I installed per Electric Bob's suggestion?
Kyle, the Ford regulator is keeping my PC680 charged just fine, voltage
to the battery is ~14.3.
Don't know why your 680 died an early death, but that doesn't seem to be
the norm. As inexpensive as the regulators are, you might just replace
it if the output is too low.
Sam Buchanan
ronlee(at)pcisys.net Guest
Posted: Sun Oct 14, 2007 6:56 pm Post subject: PC-680 Performance |
Look it over for an adjusting screw.
Then monitor the charging voltage when the engine is running
Posted: Sun Oct 14, 2007 7:02 pm Post subject: PC-680 Performance |
That depends on which Ford regulator you installed. The older tall units have an adjustment screw under the cap. Most of the short cap units are pre-set, not to be adjusted. If it's adjustable, a run up and volt meter will give you the charge output. You adjust the screw in for more output.
Darrell
michael(at)robbins.us.com Guest
Posted: Sun Oct 14, 2007 8:56 pm Post subject: PC-680 Performance |
| Quote: | Over the years, the Odyssey PC-680 has gotten very good reviews...
I had a PC-625 in my 180 hp IO-360 RV-8 for five years and it was still going strong when I replaced it last month. I never used a trickle charger. Maybe they have a QC issue.
Mike Robbins [quote][b]
Posted: Mon Oct 15, 2007 4:50 am Post subject: PC-680 Performance |
Darrell Reiley wrote:
<lifeofreiley2003(at)yahoo.com>
in for more output.
The VR166 type Ford regulator (mid-70's LTD) that 'Lectric Bob shows in
some of his schematics and many of us use is solid-state and doesn't
have any adjustments. Since it only costs about $10 it is easy to
replace if it has drifted out of spec. But they seem to be very reliable
units and mine has been fine for eight years.
Sam Buchanan
seiders(at)bellsouth.net Guest
Posted: Mon Oct 15, 2007 5:32 am Post subject: PC-680 Performance |
Kyle,
Don't know about Odyssey. I use a garden tractor battery . Get them at auto stores. Cost about $32. Change them out at 2 year intervals. No problems thus far in 5.5 yrs flying..
Dick RV6A
At 10:07 PM 10/13/2007, you wrote:
| Quote: | Over the years, the Odyssey PC-680 has gotten very good reviews for its small size and high cranking amps. So, about 3 years ago, I selected one to replace a 4 year old Concorde battery.
KB
LloydDR(at)wernerco.com Guest
Posted: Mon Oct 15, 2007 5:45 am Post subject: PC-680 Performance |
http://www.odysseyfactory.com/
is their website and they have their own charger, I took the part number and did a search on Google and saved a bit of money over the factory site. I use two of the batteries and always keep them charged full up, as I have an electrically dependant engine.
Dan
N289DT RV10E Flying
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of lessdragprod(at)aol.com
Sent: Sunday, October 14, 2007 2:43 PM
Subject: Re: PC-680 Performance
Hi Kyle,
Jim Ayers
