		patrick.pulis(at)seagas.c Guest
				 Posted: Sun Jan 28, 2007 3:20 am    Post subject: Nutplate Corrosion - To Prime or Not To Prime? |
				I'm in the process of installing the nut plates onto my spar and am
 seeking other builders thoughts re priming of the nut plates once
 installed to inhibit the likelihood of future corrosion.
 I am using Duralac on each nut plate prior to riveting to inhibit
 corrosion due to dissimilar metal contact and I have primed the
 countersinks in the spar flange prior to installing the nut plates.
 Should I also prime the nut plates themselves once installed on the
 underside of the spar flanges?
 Your thoughts, experiences and suggestions would be very much
 appreciated please.
 Patrick Pulis
 #40299
 Adelaide, South Australia
				 Posted: Sun Jan 28, 2007 6:02 am    Post subject: Nutplate Corrosion - To Prime or Not To Prime? |
				We prime all nutplates, either with the same primer as we use for the skins
 or with Zinc Chromate.  I doubt much of that paint would be left after
 running the screw in, but what do I know?  We haven't been using anything on
 the threads of the screws, but would be interested in others' suggestions on
 this.  We use Lithium Grease on all bolt shafts, but make sure not to get
 any on the threads.
 Do not archive.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 www.saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
				 Posted: Sun Jan 28, 2007 7:44 am    Post subject: Nutplate Corrosion - To Prime or Not To Prime? |
				I use anti-sieze on my screws and really don't worry about getting it on
 the larger bolt threads either.  I guess Jesse, being a purist, is
 worried about the changes in assembly torque on bolts with lubricated
 threads.  I'm not.  That doesn't mean you shouldn't be aware of the
 changes (or possible consequences) and follow my lead.  It's just the
 way I've done it, and yes, sooner or later I may get 'caught' by my
 blasphemous assembly.  I rather feel I'll croak from natural causes
 first.  Oh, BTW, the reason I use antisieze is because I'm not fond of
 having to drill out a few screws once a year!
 Linn .......
 any on the threads.
 Do not archive.
 Jesse Saint
 Cell: 352-427-0285
 Fax: 815-377-3694
				 Posted: Sun Jan 28, 2007 9:38 am    Post subject: Nutplate Corrosion - To Prime or Not To Prime? |
				Anti-sieze, from what I have read, is made to be used on the threads.  We
 use that or Seal Lube for the threads of the fuel and brake line pipe thread
 fittings.  I just don't like the idea of lithium grease on the nut for fear
 it might limit the effect of the nyloc action.  Anti-sieze I would not be
 against, and certainly not into a nutplate.  I do agree that using ez-outs
 or drilling a screw is a pain.
 I do think that's the first time I've been called a purist, for whatever
 reasons, so couldn't you have left that in the archives?
 So, for another question...does the server recognize the previous messages
 and remove them from the post online and thus ignore the "do not archive"
 post from previous messages?
 Jesse Saint
 Cell: 352-427-0285
 Fax: 815-377-3694
		johngoodman
				 Posted: Sat Oct 13, 2007 5:00 pm    Post subject: Re: Nutplate Corrosion - To Prime or Not To Prime? |
				Patrick,
 I would agree that the nutplates need something for long term corrosion protection. I noticed someone mentioned Lithium Grease. I used to use Lithium Grease on everything on my house on Kauai until I discovered (to my horror) that the salt air was actually condensing on it and slowly embedding salt crystals into it. I actually had well greased metal rusting underneath the grease. The crystals had worked their way down to the metal.
 Priming nutplates probably won't do much good, since the screws and other activity around them will probably do a good job of removing it.
 I would suggest Boeshield T-9. It's similar to ACF-50 but it has a waxy consistency. There is a similar product that I'm pleased with for the regular market called Bullfrog Rust Inhibitor. I've never looked into it but I wouldn't be surprised if the Bullfrog product is simply Boeshield T-9.
 On the threads, I agree with the others that they need to be clean of any lubricant that might help them back off. Locktite works great.
		AV8ORJWC
				 Posted: Sat Oct 13, 2007 9:20 pm    Post subject: Nutplate Corrosion - To Prime or Not To Prime? |
				Try soaking the screws after spraying them with LPS3 in a paper cup
 before insertion into the nutplates.
 John Cox
 40600
