Ray.R.Doerr(at)sprint.com Guest
Posted: Mon Oct 15, 2007 6:41 am Post subject: Dual Radio's using the Split Com feature. |
I have dual Garmin 430 radio's and their GMA 347 Audio Panel.
The panel has a split com feature that enables the Pilot to TX/RX on Com
1 while the Co-Pilot can TX/RX on Com 2. I found on our trip to New
Mexico that when the Co-Pilot transmitted on 122.75 for air to air on
Com 2, that I would hear a fairly loud squeal on the Receive on Com 1
when I was listening to Center. Every time you TX in Com 2, Com 1
breaks Squelch and you get a squeal.
I have two bent whip (RAMI AV-17) antenna's on the belly under
the passenger seat which are 3' 4" apart. The Garmin 430's have a
Tramsmit Interlock pin that can be wired to the MIC KEY of the opposite
radio, but if you do this the receiver sensitivity is reduced. Also
when you use the Split Com feature of the Audio Panel, you would not
want the receiver sensitivity to be reduced.
My question is to those that have dual radio's and have used the
split com feature so both the pilot and co-pilot can transmit at the
same time. Are you having similar problems, if not where are your Com
Antenna's mounted? I was thinking if I move one of my Com Antenna's to
the top of the aircraft, that may solve my problem, but I didn't want to
drill holes in the top skin just to find out that I still have the same
issue.
Thank You
Ray Doerr
N519RV 40250 (Hobbs=323)
Posted: Mon Oct 15, 2007 10:31 am Post subject: Dual Radio's using the Split Com feature. |
I have not specifically checked for those symptoms, but in several planes
with bent whips on the belly, also under 4' apart, I have never seen this or
heard of it, so I would look into some other options before moving the
antenna. The other option would be to run a wire to a remote antenna (with
an adequate ground plane) outside the plane and test it on the ground to see
if it makes a difference. Or, you could try putting a metal plate (sheet of
aluminum) between the antennas on the ground and see if that makes any
difference at all.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Posted: Mon Oct 15, 2007 10:58 am Post subject: Dual Radio's using the Split Com feature. |
Doerr, Ray R [NTK] wrote:
| Quote: | I was thinking if I move one of my Com Antenna's to
issue.
Take a long piece of coax and run it to an antenna placed where you
think it may work. Support the antenna in it's normal position and tape
it down. Give it a test. You don't have to fly it to test it!!!
Linn
Thank You
Ray Doerr
john_rv10(at)yahoo.com Guest
Posted: Mon Oct 15, 2007 11:42 am Post subject: Dual Radio's using the Split Com feature. |
Ray,
Please see the attached comments from the GNS 430W installation manual re
mandatory use of the TX interlock and placement of com antennas.
John Cleary
 Download |
| Filename: |
GNS_430W_Com_ant_loc.pdf |
90.9 KB |
| Downloaded: |
555 Time(s) |
