		vicster_26
				 Posted: Mon Oct 15, 2007 4:15 pm    Post subject: Fuel Flow Sensor |
				Hello,
 I am trying to find a suitable location for my fuel flow sensor between the fuel pump and the Bendix injector (between the injector and flow divider is out of the question) on my Lycoming AEIO-540, At the moment the simplest location has the sensor longitudinally angled downward at about 40 deg angle (the outlet being lower than the inlet). This location also ensures a straight line prior to the inlet. I've read on previous post that it is better to have the sensor level, how critical is this?
 Vic
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		panamared5(at)brier.net Guest
				 Posted: Tue Oct 16, 2007 6:49 am    Post subject: Fuel Flow Sensor |
				Don Rivera at Air Flow Performance recommends placing the sensor
 between the fuel servo and the flow divider.  In most cases this
 would mount the sensor vertically.  I questioned him about this and
 he said, he tested it and it really makes no difference.
 I like the idea, because it seems to be the easiest solution.  But,
 at this time, I do not have a need for a fuel flow data so I have not
 installed one.
 RV6
 "Wicked Witch of the West"
 At 07:15 PM 10/15/07, you wrote:
 Hello,
 Vic
 http://forums.matronics.com/viewtopic.php?p=140177#140177
		randy(at)romeolima.com Guest
				 Posted: Tue Oct 16, 2007 8:40 am    Post subject: Fuel Flow Sensor |
				My flow sensor is mounted vertically as described below and is functioning
 perfectly.
 YMMV,
 Randy Lervold
 www.rv-3.com
		rice737(at)msn.com Guest
				 Posted: Tue Oct 16, 2007 10:04 am    Post subject: Fuel Flow Sensor |
				Hey Vic,
 I put mine inside the firewall downstream of the electric fuel pump. Works fine, I think the directions were written by a lawyer, say that it need to be between the mech fuel pump and the divider.  As I have to of the same sensors on my boat installed prior to the mech fuel pump drawing more gph for the last ten years without a problem, I think this location will be suitable on our planes as well.
 Paul Rice
 N64PR
 RV8
  	  | Quote: | 	 		   Subject: Fuel Flow Sensor
  Date: Mon, 15 Oct 2007 17:15:45 -0700
  To: rv-list(at)matronics.com
  --> RV-List message posted by: "vicster_26" <vicster(at)netvigator.com>
  Hello,
  Vic
