wingnut
Posted: Mon Oct 15, 2007 5:31 pm Post subject: More starting problems |
Now that I've solved my cold starting problems with my 912UL, I've discovered another annoying issue. It doesn't want to start warm. That is, if I shut the engine down after a flight, it starts right up if I crank within a couple of minutes. If I let it cool down more then that, then it won't start until I let it cool down all the way (takes a couple of hours). It's not a situation that I find myself very often but it bit me on two recent cross country flights where I loitered too much during a fuel stop. When it happens, I can crank the battery dry and it won't get a single pop from the ignition regardless of throttle or choke position (the only two inputs I have). Any ideas?
_________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
wingsdown(at)verizon.net Guest
Posted: Mon Oct 15, 2007 7:48 pm Post subject: More starting problems |
Sounds like heat soak vapor lock.
Rick
wingnut
Posted: Mon Oct 15, 2007 8:08 pm Post subject: Re: More starting problems |
OK. Why does it happen? How do I fix it?
| Quote: | | Sounds like heat soak vapor lock. |
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
john(at)leptron.com Guest
Posted: Mon Oct 15, 2007 8:19 pm Post subject: More starting problems |
I agree to the heat soak problem. When my fox started doing that I did two
things, one I opened the oil access door any time I landed knowing I was
going to leave. 2 I installed an electric fuel "primer" pump under my seat.
I have had no problems with it since.
John Oakley
wingnut
Posted: Tue Oct 16, 2007 4:21 am Post subject: Re: More starting problems |
Is this an indication that my motor is getting too hot? It was only one landing after a long descent so I wouldn't have thought that it was too hot.
Can you tell me more about your fuel primer pump? I've noticed you mentioning your fuel primer before but I figured you where talking about a simple plunger style manual pump. Does the primer pump run all the time?
| Quote: | | I agree to the heat soak problem. When my fox started doing that I did two things, one I opened the oil access door any time I landed knowing I was going to leave. 2 I installed an electric fuel "primer" pump under my seat. I have had no problems with it since. |
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
Lynn Matteson
Posted: Tue Oct 16, 2007 8:39 am Post subject: More starting problems |
Luis-
What I normally do on my Jabiru engine, (with only one carb to worry
about) is to shut off the main fuel valve when I'm about 30 seconds
away from shutting the engine down, like for parking after a landing
and taxi, etc., then when the engine is shut down, the fuel level in
the bowl is reduced, and a subsequent hot start is immediate.
Somebody gave me this tip, and it works perfectly. Just something you
might try.
Lynn Matteson
flying w/420+ hrs
On Oct 16, 2007, at 8:21 AM, wingnut wrote:
was too hot.
all the time?
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
wingnut
Posted: Tue Oct 16, 2007 1:10 pm Post subject: Re: More starting problems |
Thanks for the tip Lynn. That sounds like an easy thing to try.
I was just looking through the Rotax operators manual and I noticed something interesting. The diagram for the fuel system shows the fuel lines going from the pump to a four way splitter. Two lines for the carbs one for the fuel pressure gage (which I don't have) and a fourth line returning to the tank. According to the caption, the purpose for this fourth line is to prevent 'vapour lock'. I'm not entirely sure that my fuel system has such a thing. Would that be unusual? Does everyone else have this installed?
I don't really understand how such a system would work. If the output of the fuel pump is split between the fuel tank and the carbs then wouldn't this dump all the fuel pressure out the vent lines in the tank?
[quote]What I normally do on my Jabiru engine, (with only one carb to worry about) is to shut off the main fuel valve when I'm about 30 seconds
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
pwmac(at)sisna.com Guest
Posted: Tue Oct 16, 2007 1:55 pm Post subject: More starting problems |
The 4th connection is for the return line to the tank and it has a
small orifice in a fitting so the flow is small. It does prevent
vapor lock. Its fairly common to use the return but many guys skip it.
Paul
| Quote: | What I normally do on my Jabiru engine, (with only one carb
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
http://forums.matronics.com/viewtopic.php?p=140319#140319
l.morris(at)tx.rr.com Guest
Posted: Wed Oct 17, 2007 12:13 am Post subject: More starting problems |
Also might try pushing your throttle full open right after you pull your mixture back. Leon Morris/classic 4/60%/ Flower Mound,TX
---- Lynn Matteson <lynnmatt(at)jps.net> wrote:
Luis-
might try.
Lynn Matteson
flying w/420+ hrs
> was too hot.
> all the time?
> Luis Rodriguez
> Model IV 1200
> Rotax 912UL
> Flying Weekly
> Laurens, SC (34A)
