huronflyer
Posted: Wed Oct 17, 2007 9:52 am Post subject: Floats |
Ray,
Yes some people charge $2000 - 3000 for floats to fit Lazair/Kolb.
And that is cheap compared to some of the other heavier factory built stuff.
There are 750 lb floats available used for $600 - 700.
I bought mine for $500 broken ( I was in love with plane at that point).
I found some real neat wooden floats, Google "Muk Tuk" I think...
scratch built or kit. His site is worth reading just for the fun of his mind
set.
Cheers.
drh
CYEL
_________________ DO NOT ARCHIVE |
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Wed Oct 17, 2007 12:20 pm Post subject: Re: Floats |
I also found the Muk-Tuk floats and site stories an enjoyable read even if your not looking for floats.
I was thinking of a mono float that might sit between the existing landing gear so I could still land off water.
If this drought keeps up I may just use the extended shoreline to take off from as the water level drops and exposes a long beach landing area.
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
malcolmbru(at)aol.com Guest
Posted: Fri Oct 19, 2007 4:34 am Post subject: Floats |
I built a set of alouminom floats from plans but uou can find them used building your own will cost you alot of time and you need the space we had a set of plans floating around for free the material will cost over $1,000 mal mk 2 pilot
jb92563
Posted: Fri Oct 19, 2007 7:43 am Post subject: Re: Floats |
How did you seal the rivet seams on your aluminum floats?
I'm going to try designing a single float for the Kolb Ultrastar if possible to keep the weight light.
Have not decided on a material....have to do the basic shape configuration first to see what is feasable.
Moni MotorGlider
Do Not Archive |
Steve Boetto
Posted: Fri Oct 19, 2007 7:52 am Post subject: Floats |
In a message dated 10/19/2007 11:44:20 A.M. Eastern Standard Time, jb92563(at)yahoo.com writes:
| Quote: | How did you seal the rivet seams on your aluminum floats?
Ray, I would use a product called 3M 5200. Most boat stores sell It
Steve
Firefly 007/Floats
See w [quote][b]
Posted: Sat Oct 20, 2007 5:01 pm Post subject: Floats |
in the Zenair builders guid they sugest something diferent .. they also sugest a special rivet from Granger malcolm michigan
Steve Boetto
Posted: Sat Oct 20, 2007 6:18 pm Post subject: Floats |
In a message dated 10/20/2007 9:02:04 P.M. Eastern Daylight Time, malcolmbru(at)aol.com writes:
| Quote: | in the Zenair builders guid they sugest something diferent .. they also sugest a special rivet from Granger malcolm michigan
Don't know about that, But, Can-Zac and Czech Float both have built the Zenair design and both use 3M 5200. I currently fly the Czech Float and am waiting for a set from Can-Zac. Czech Float has tried 2 part urethanes but the last time I talked to them they went back to 3M.
Steve B
Firefly 007/Floats
See w [quote][b]
biglar
Posted: Sat Oct 20, 2007 6:31 pm Post subject: Floats |
You're right, Steve. 5200 and its' competitor, SikaFlex, are waterproof and probably the strongest and most flexible adhesives I've ever seen. Used them a lot on boats in another life, and when you stick something with one of 'em you'd best want it to stay stuck, 'cause you're not gonna get it apart again. There is a solvent, but it's mostly for cleanup. Doesn't penetrate joints very well, and takes a loooong time.
I saw a documentary on stickums the other night and they made a big deal out of another 3M product.......a tape called, uh, RBX ?? RHB ?? Something like that, and it's amazing stuff. Lar.
N27SB(at)aol.com (N27SB(at)aol.com) wrote: [quote] In a message dated 10/20/2007 9:02:04 P.M. Eastern Daylight Time, malcolmbru(at)aol.com (malcolmbru(at)aol.com) writes:
Steve B
Firefly 007/Floats
See w | Quote: |
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
capedavis(at)yahoo.com Guest
Posted: Sat Oct 20, 2007 7:01 pm Post subject: Floats |
Steve , I'm all behind 5300 I was a commercial fisherman for 31 years and we all used 5200 for all kinds of waterproof connections it will fasten and have more strength that what ever you are fastening , be it fiberglass to wood or steel to fiberglass the 5200 would be the strongest component in any joint always something else would come apart before the 5200 . Chris
russ(at)rkiphoto.com Guest
Posted: Sun Oct 21, 2007 4:59 am Post subject: Floats |
In re rivets -- as I recall when going thru the Edo factory many years ago -- they had a spool of zinc-chromate tape, quite thin, sort of like electrician's tape; that they put on all the faying surfaces before riveting. On course most of it squeezed out but it did seal the seams well.do not archive
Steve B
Firefly 007/Floats
See w | Quote: |
d-m-hague(at)comcast.net Guest
Posted: Sun Oct 21, 2007 5:01 pm Post subject: Floats |
At 11:43 AM 10/19/2007, jb92563 wrote:
| Quote: | I'm going to try designing a single float for the Kolb Ultrastar if
I like the idea of a monofloat for the US... seems it'd do a better job of
keeping spray off that low hanging prop.
-Dana
But do you trust the _government_ with semi-automatic assault rifles?
