		john_graham
  Joined: 09 Aug 2007 Posts: 45 Location: Algonquin, IL
				 Posted: Wed Oct 17, 2007 9:56 am    Post subject: RPA Checklist |
				The RPA checklist for a Yak 52 has been a great help to me.  I have 3 questions:
 1.  During the run up it states to set the prop at 64% and move the throttle and verify the 64% stays constant.  What is the purpose of this.
 2.  Before take off it states to move the flap handle to Neutral. Won't this depressurize the flap system and slam them down when the flaps are lowered?
 3.  During climb and after raising the gear, it states to put the gear handle in Neutral.  Any reason for this or can it stay in th UP position.
 Thanks (as always) for the help.
 N15YK
 Yahoo! oneSearch: Finally, mobile search
 that gives answers, not web links.
 http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ John Graham
N15YK  1993 Yak-52
CubFlyer1940@Yahoo.com
(847) 641-1330 |
				 Posted: Wed Oct 17, 2007 10:24 am    Post subject: RPA Checklist |
				John,
 None of that is in my now anciently translated version of the original YAK
 student pilot's handbook. It says set the prop at full forward and set
 "advance" (manifold pressure) at 70%, check mags for not greater than 3%
 drop per side.
 It only recommends setting the flaps and gear to the neutral position for
 the cockpit that is not commanding the gear or flaps. It only specifies
 placing the gear handle in neutral  to depressurize the system before
 blowing the gear down from the emergency system.
 Have not looked at in a while but that is the best that I remember of it,
 Doc
		dsavarese(at)elmore.rr.co Guest
				 Posted: Wed Oct 17, 2007 11:05 am    Post subject: RPA Checklist |
				John,
 My comments IAW your question numbers -
 1. The purpose is to check the prop governor's ability to hold a constant
 RPM.
 2. Do NOT do this!  You are 100% correct.  If your copy of the manual says
 this, the manual should be changed immediately and you should notify the
 creator of manual that it is wrong.
 3. Do NOT do this!  You are depressurizing the landing gear actuators AND
 the uplock assemblies.  Unless you remember to put the gear handle BACK to
 the UP position BEFORE moving the gear handle to the DOWN position, the
 landing gear actuators will slam down.  I guarantee it WILL get your
 attention and a neophyte back seater will have the crap scared out of them.
 Keep the gear handle in the UP position but DO NOT put the slide lock in
 place while the gear handle is in the UP position during flight.  Too many
 people have lowered the gear handle to the neutral position with the slide
 lock in place and "heard" the hiss, thinking the gear was down and locked
 when in fact, the gear was just hanging limp.  They also did not check for
 the green lights and assumed the gear was down AND locked because they 1)
 felt the firm stop of the gear handle and 2) heard the hiss of the actuators
 depressurizing.   When the prop goes "ding", "ding" on the runway, you'll
 realize you only had the handle in the neutral position and a very loud "Oh,
 SH--" is heard emanating from the cockpit.
 As I said, wherever the flight manual is posted, it should have these
 instructions immediately corrected.  Especially #3 because it is inviting a
 potential gear up landing.
 Dennis
		cliff(at)gesoco.com Guest
				 Posted: Wed Oct 17, 2007 12:52 pm    Post subject: RPA Checklist |
				John, it sounds like you have the instructors manual, not the pilot's
 manual.
 In any event, unless the compressor is having real problems, there's no
 real reason to return the handles to the neutral position after selection.
 It's certainly not going to damage anything to select gear neutral after
 the gear is locked up.
 The uplocks are mechanical latches and will not release until the gear
 is selected down.
 The same is true from the flap system- it's mechanically locked in
 either position.
 If either of these systems allow movement after they've reached the
 selected position, then you have a failure of the locking mechanism-
 most likely due to corrosion.
 Dennis is absolutely correct about air cushioning.  The gear system
 *requires* pressurization on the opposite side of the actuator to slow
 the movement of the gear.  DAMAGE WILL RESULT from slamming the gear up
 or down.  The uplocks take the damage from slamming the gear up- most
 notably the nose gear.  If the little roller wheel is bent off to the
 side, then the gear's been slammed up.
 If you or your mechanic is slamming the gear down during the emergency
 gear system test....You're doing it wrong!  And eventually the system is
 going to crack at the actuator attach points.
 So before selecting up, select down first and vice versa.....or simply
 never leave the handles in the neutral position.
 Sure if you're low on air and you want to conserve what you've got for
 starting, then go ahead and select the neutral positions *before opening
 the main air valve* and that will only allow the air to be used for
 starting and brakes.
  Just don't forget to select gear down and flaps up after the engine is
 running.
 If anyone needs a gear swing checklist let me know off list.
 Cliff
 A. Dennis Savarese wrote:
  <dsavarese(at)elmore.rr.com>
  John,
  constant RPM.
  says this, the manual should be changed immediately and you should
  notify the creator of manual that it is wrong.
  AND the uplock assemblies.  Unless you remember to put the gear handle
  BACK to the UP position BEFORE moving the gear handle to the DOWN
  position, the landing gear actuators will slam down.  I guarantee it
  WILL get your attention and a neophyte back seater will have the crap
  scared out of them. Keep the gear handle in the UP position but DO NOT
  put the slide lock in place while the gear handle is in the UP
  position during flight.  Too many people have lowered the gear handle
  to the neutral position with the slide lock in place and "heard" the
  hiss, thinking the gear was down and locked when in fact, the gear was
  just hanging limp.  They also did not check for the green lights and
  assumed the gear was down AND locked because they 1) felt the firm
  you'll realize you only had the handle in the neutral position and a
  very loud "Oh, SH--" is heard emanating from the cockpit.
  inviting a potential gear up landing.
  Dennis
		cjpilot710(at)aol.com Guest
				 Posted: Wed Oct 17, 2007 1:39 pm    Post subject: RPA Checklist |
				In a message dated 10/17/2007 4:53:38 P.M. Eastern Daylight Time,  cliff(at)gesoco.com writes:
  John,
  I agree totally with all below except for one item.  At least on the  CJ-6 the flaps do not have lock down or lock up.  Pressure holds the flaps  down as long as either flap handle is in the down position.  The rear  handle (instructors seat) has presidents over the front handle.  Put both  handles in the neutral position, takes pressure off both sides of the  actuator.  A bungee cord in the flap area will pull the flap up.  At  least on the CJ - I am not sure about the Yak.
  One other detail not mention here is that both the gear and flap lines have  small conical washer with a hole about .05 dia.  These are  usually located in the lines where B nuts attach to fittings in the wheel  wells.  For the flap they are located right where the line attaches to the  flap actuator.  If you take off these lines for any reason, it is very easy  for these to drop out un-noticed.  The purpose is to meter the out and in  flow.  These control to certain extent the rate that gear and flaps  retract.  Craig Payne went to a great deal of fiddling to get his gear to  retract evenly and at the same time, just by adjusting the size of these  holes.  But you still need the air pressure to work against.
  Leaving gear handle in the up position has absolutely no effect on the wear  of seals in the actuator.  As a matter of fact, some CJ (mine is one) have  no up locks at all.  The only thing that holds the gear up is the pressure  in the system.
  Jim "Pappy" Goolsby
  [quote]-->    Yak-List message posted by: Cliff Coy    <cliff(at)gesoco.com>
 manual.
 is selected down.
 either position.
 running.
 Cliff
 [quote] --> Yak-List message posted by: "A.    Dennis Savarese"
     John,
  constant    RPM.
  Dennis
