PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Thu Oct 18, 2007 4:15 pm Post subject: Flew an AMD 601XL yesterday |
While in AZ, I had the opportunity to say "hi" to the nice people at http://www.silverskyaviation.com
What a great group of people. I put in a couple hours of dual time with one of them in their Zodiac.
I'd flown the red & white factory demo at the Zenith hanger in Mexico, Missouri during a Rudder Workshop - but just for a few minutes. Yesterday I was able to put some real world hands-on stick time on an XL.
Impressions:
On taxi'ing out to the run-up area, I noted the short coupled landing gear made for a tight turning radius.
Acceleration upon takeoff with the 100hp Continental was brisk. Takeoff roll was short on the paved runway, and pattern altitude was attained about the time I was turning onto Downwind. Certainly could have done even better if I'd have been striving for Vy.
Plane has a sensitive elevator. That's a wonderful thing when you're going slow, and is great for holding the nose up when you're gently dropping the mains upon landing. Requires a gentle touch at speed, but it's nothing that the average guy isn't going to get the hang of within a few minutes. It's not a big deal, and you shouldn't let that scare you one bit.
Visibility out of the canopy is great. Really great. Nothing else I've ever flown even compares (except a Breezy).
My first attempts at landing were way too fast. Slowing it way down to about 60 or so was much better. The XL is an easy airplane to land, and I got the feel for it quite quickly.
We did some slow flight. With full flaps this plane will hover at about 38. Unreal, and I would not have believed it if I hadn't seen it. That's Piper Cub range. Clean stalls were around 48. There was a stall warning buzzer that went off around 55 or so. Cruise speed was about 100.
Also did some of the basic stuff - S turns, turns around a point, etc. It flew very well. Some guys a while back said "twitchy", but that's not exactly right. "Crisp" describes it better, if that makes any sense. Also, the aileron trim makes a huge difference. If it's out of trim, one wing will be very heavy. You'll notice it!
The only time I was nervous was during some steep turns. Given that this was plane was "AMD serial number 1" and there were two pretty big guys in it, I didn't want to push it. It did have the wing replaced earlier due to previous damage, and during the preflight I checked that the rear attachment bolts looked tight. Obviously we were fine, so I'll leave it at that.
Overall, I was very impressed with the aircraft. I'm 6'3" tall and had plenty of headroom. Never touched shoulders with the other guy, nor did I bump my headset on the canopy.
I'll be doing a few things different in my own Zodiac that I'm building. The shoulder harness was too long, and I didn't like the flap switch. A couple inches of leg room would be nice. Otherwise, it was darn near a perfect setup for me.
What a great way to get motivated for my own project
Patrick
XL/Corvair
kim.forest(at)surewest.ne Guest
Posted: Fri Oct 19, 2007 8:26 am Post subject: Flew an AMD 601XL yesterday |
Reference to elevator - I like to call it "responsive". It just sounds
better than "sensitive"....
Can't wait to fly!
FKeener, Rocklin, CA
CH601XL - 2% done...
shilcom
Posted: Fri Oct 19, 2007 10:36 am Post subject: Flew an AMD 601XL yesterday |
Was that cruise speed a typo. surely you did better than 100 mph. 100knts wouldn't even be to swift. Bob U.
Gig Giacona
Posted: Fri Oct 19, 2007 12:19 pm Post subject: Re: Flew an AMD 601XL yesterday |
That would be the slowest XL I've heard of.
| shilcom wrote: | Was that cruise speed a typo. surely you did better than 100 mph. 100knts wouldn't even be to swift. Bob U.
601XL Under Construction
PatrickW
Posted: Sat Oct 20, 2007 6:31 pm Post subject: Re: Flew an AMD 601XL yesterday |
| shilcom wrote: | | Was that cruise speed a typo. surely you did better than 100 mph. |
No, not a typo. I should have asked about the prop - I bet it was a "climb prop". Climb performance was pretty good, and I know that density altitude is an issue during the summer time in Arizona.
I'll fly it again next time I'm in the area and find out some more. But it sure was a nice handling airplane, and I'd be happy with it.
Patrick
XL/Corvair
psm(at)ATT.NET Guest
Posted: Sat Oct 20, 2007 7:27 pm Post subject: Flew an AMD 601XL yesterday |
At 07:31 PM 10/20/2007, you wrote:
| Quote: | > Was that cruise speed a typo. surely you did better than 100 mph.
If you look at the AMD speed specifications you will see cruise at
130 mph true airspeed. This probably translates to a real indicated
cruise speed of 100 mph as reported.
There is a reason we don't hear much about XL builders using
Continental O-200 engines. I suspect AMD chose this path because its
customers (established FBO/Flight schools) already are familiar with
this engine and they don't really care about cruise speed. I see a
similar phenomenon with the new Cessna 162 that is selling like
hot-cakes with a Lycoming engine even though it's porky empty weight
of 830 pounds doesn't allow two adult Americans to fly in it at the same time.
This plodding cruise speed is one of the reasons we are building our
planes from kits or plans instead of buying factory built
compromises. We all want recreational flying craft rather than
primary trainers.
Paul
XL fuselage
zodierocket(at)hsfx.ca Guest
Posted: Sat Oct 20, 2007 8:08 pm Post subject: Flew an AMD 601XL yesterday |
The decision to go with the 0-200 is likely a cost issue, in order to get
SLSA approval a certified engine such as the 0-200 makes the process a lot
easier. Also the target purchaser, he is typically a gent who is afraid to
lose his medical. Typically an older fellow who knows the 0-200 and has in
all likely hood flown behind one at some point. So in order to keep flying
he switches to the LSA category and looks for something he is comfortable
with and does not have to learn. Is it the best choice, maybe, I have a
preference for the Jabiru configuration, but it is not as popular to the
older crowd who just want to continue flying and not have to learn about a
new powerplant. As for the Hot cake Cessna, it is nice for a company to have
so many schools/ dealers that they can tell to purchase a new plane, It may
be selling like hotcakes on paper but it is going down hard without the
syrup for a lot of dealers that have been forced to buy it.
Mark
fderfler(at)gmail.com Guest
Posted: Sun Oct 21, 2007 9:58 am Post subject: Flew an AMD 601XL yesterday |
Actually.. I've been flying an AMD 601XL for exactly a year. On Tuesday I flew it back from its annual in Georgia to Marathon in the Florida Keys. It was about 5 hours in the air with one stop at Lakeland, FL for the old man.
As far as the indicated airspeed, in general flying I often see indicated at 110-115 knots and I often see 100 knots. Tuesday was a 100 knot day... at 8500 feet with the ground temp at 92 and the density altitude in the stratosphere someplace. I had to be that high to scrape over the tops... and at one point Ft. Myers approach said "uh, three alpha mike .. barometer 2992." That was the controller's subtle way of asking me if I knew what altitude I was at. The Dynon reported about 9100'. Some cloud tops were higher. The little prop was turning and the fuel was burning, but the airspeed was quivering at 99 knots. I held the 0-200 to 2550 RPM, although I'm sure it would have been safe closer to the red line. The EGTs and CHTs were dandy. I just told him that I was clearing clouds and he said, "Maintain VFR". That's the right answer.
My point is that discussion of indicated airspeed is silly without knowing every parameter of the flight. Density altitude is critical to the discussion.
As one commentator indicated, as an old guy flyer it gives me great pleasure to be behind an 0-200. I can drop into any field in Florida and find somebody who knows the engine.
I'm happy to report that the folks at AMD got me out of the annual in exactly 24 hours. I took off for the return flight exactly 24 hours from when I arrived. The LONGEST part of the exercise was backing up the Dynon prior to uploading the newest software rev. That took forever and we were pretty much afraid to touch anything while the Dynon was plugged into the laptop That's when we went to town and ate fried pork chops, okra, and black eyed peas. With cherry cobbler and banana pudding.
Also, happy to report that the latest rev of the D-180 software completely cured the problem of the charging the internal backup battery. It works now.
We replaced the non-skid strips and yes, the heat gun made it a piece of cake ... or pecan pie.. as the case may be.
Oh, by the way, everyone seems to want to know about the AMD Patriot. Watch for it as a production airplane, with an option for floats, in early 2008. Pieces and parts from S. America.. customized and assembled for you by fine Georgia (USA) Craftsman. Engine by Lycoming... and proud of it.
Frank Derfler
-- Daily Discussions of All the Guy Toys that aren't (clearly) illegal or (blatantly) immoral at my Blog http://MOSTLYFLYING.blogspot.com
- Pilots learn about flights to great places at www.FLYINFLORIDA.COM
-Boaters get the Best Information on Cruising the Florida Keys at www.KEYSBOATER.com
-For the Best Gifts for Guys see my www.GREATGUYBOOKS.com
naumuk(at)alltel.net Guest
Posted: Sun Oct 21, 2007 11:36 am Post subject: Flew an AMD 601XL yesterday |
Frank-
Do you have an early or current version of the Dynon? Software download problems aside, are you satisfied? Finally, are software upgrades free, as Dynon ads claim?
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Sun Oct 21, 2007 2:57 pm Post subject: Flew an AMD 601XL yesterday |
Frank--
Don't know why it took so long for your upgrade on the Dynon. I just upgraded to the latest software on both my D100 and D180. The D180 took about 20 minutes to backup current software and about 1/2 to upload new software. The EFIS only too about 20 minutes to do the upload.
George May
601XL 912s 164 hours
| Quote: | Date: Sun, 21 Oct 2007 13:55:32 -0400
Subject: Flew an AMD 601XL yesterday
Frank Derfler
| Climb to the top of the charts! Play Star Shuffle: the word scramble challenge with star power. Play Now! [quote][b]
Posted: Mon Oct 22, 2007 11:01 am Post subject: Flew an AMD 601XL yesterday |
George asked if I'm happy with the Dynon, upgrades, and support. George, I'm very happy with the Dynon. Personally, I have a problem with the angle of attack indicator (see my Blog below for a movie) and can not recommend the AoA option, but otherwise it is superb. The online support is excellent. I have received responses to a question within an hour even on a weekend. They are open with their problems and solutions. Not only are the software upgrades free, they are easy.
Bill asked why my software upgrade on the D-180 took so long. Bill, some of us are silly enough to want to backup the old software load just in case. That Backup takes forever, I have a feeling there is a mismatch between the block read and block transmission size going from the Dynon RAM thru the Dynon serial port and on through the laptop Serial-to-USB converter we were using. Blame it on the laptop converter. Yes, the upload of the new software is speedy and painless.. as long as you don't interrupt it in any way.
(For Bill and others... the Dynon D-180 that I have (one year old) uses a serial RS-232 port. You can still find those serial ports on desktop computers, but they are rare on new laptops. So, you load a USB to serial converter (made in China by companies with wierd names that include Moon and Start or similar objects) into your laptop, cross your fingers, and hope you got all the cable connections right. Or, you just go out onto eBay and buy an old laptop with a serial port! (recommended!) ) Or, you bring a desktop PC to the plane or take the Dynon to the desktop. etc. etc.
AMD went so far as to install a serial to USB converter into the airplane. I can get at the Dynon software port from the front panel USB plug (or is it a jack?.. who knows with USB!). I recommend bringing out either the serial connection or a USB connection to the panel!
Frank Derfler
yak52
Posted: Fri Oct 26, 2007 6:20 am Post subject: Re: Flew an AMD 601XL yesterday |
The decision to go with an 0-200 is based on more factors than cost although:
1.You can buy an 0-200 and rebuild it to specifications that have been proven by over 40 years of flying experience for less than the cost of a new Rotax or Jabiru.
2. Sensenich and other propellor manufacturers will be able to provide you with a propellor specifically for that engine.
3. An 0-200 does not require you to be the test pilot while Rotax and others go through their "teething" problems.
3. Almost any airport with a maintenance facility can and will repair your 0-200 should you need it during cross country flights.
Additionally, there is nothing new to "learn" to operate either a Rotax or a Jabiru other than how to get the engine over to the repair facility during its "teething" problems.
Cessna's decision to use the Continental came after the airplane was taken around the airshow circuit with a Rotax and seeking pilot input as to their preference for the engine. Cessna wanted the Rotax, but the people who were going to fly and maintain them wanted the Continental.
