LV warning module with EFIS
donaldjsmith(at)ukonline.
PostPosted: Sat Oct 20, 2007 3:02 pm    Post subject: LV warning module with EFIS Reply with quote
Is it necessary to have a LV warning module when using an EFIS? Many (eg
stratomastor Enigma) have alarm and warning functions that will warn of a
low voltage occurrence.
Ref Z16 in Aeroelectric connection.
Donald J Smith
khorton01(at)rogers.com
PostPosted: Sat Oct 20, 2007 4:00 pm    Post subject: LV warning module with EFIS Reply with quote
On 20 Oct 2007, at 19:04, Donald J Smith wrote:
<donaldjsmith(at)ukonline.co.uk>
Many (eg
warn of a
If you are unhappy with the consequences of a total electrical
failure, then you should ensure that you have active notification of
an alternator failure. A low voltage warning, with a very noticeable
warning, is a good way to do that, as a low system voltage is a good
indication of an alternator failure. It really doesn't matter
whether the low voltage warning is provided by a separate low voltage
warning system, or whether it is provided by some other system
(engine monitor, EFIS, etc), as long as it is effective.
If you are convinced that the low voltage warning provided by the
EFIS will be quickly noticeable, then it should be all you need.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
mosquito56
PostPosted: Sat Oct 20, 2007 5:32 pm    Post subject: Re: LV warning module with EFIS Reply with quote
Thanks for the question and the answer. I will put low voltage on my checklist when I install my electrical system. I am just getting started and gleaming every morsel of info I from the list.
Have a good one.
Don
Don Merritt- Laredo, Tx
nuckolls.bob(at)cox.net
PostPosted: Sat Oct 20, 2007 9:15 pm    Post subject: LV warning module with EFIS Reply with quote
You only need one LV warning system. You choose.
