notsew_evets(at)frontiern Guest
Posted: Sun Oct 21, 2007 6:17 pm Post subject: 601 XL |
I m installing the control cables in my 601 XL and have a problem with the trun buckles.
Do the barrells have a right and left hand thread ?
I think they do and all of the "forks and eyes" have right hand threads.
Am I wrong or did Zenith send me the wrong parts ??
Steve # 55
naumuk(at)alltel.net Guest
Posted: Sun Oct 21, 2007 6:24 pm Post subject: 601 XL |
They're right and left threads, but I couldn't tell you offhand which is which.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
bryanmmartin
Posted: Sun Oct 21, 2007 6:38 pm Post subject: 601 XL |
The turnbuckle barrels have a left hand thread on one end and a right hand thread on the other. There should be forks or eyes with either left hand thread or right hand thread to match the barrels. If Zenith sent the wrong parts, give them a call and they should send out the right parts right a away. I've gotten real good service from them while I was building my plane.
On Oct 21, 2007, at 10:16 PM, steve wrote:
| Quote: | I m installing the control cables in my 601 XL and have a problem with the trun buckles.
Steve # 55
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
gboothe5(at)comcast.net Guest
Posted: Sun Oct 21, 2007 6:39 pm Post subject: 601 XL |
They are designed so that you can turn the barrel one way to tighten, one way to loosen. They need both right and left.
Gary Boothe
Cool, CA
601 HDSTD, WW Conversion 90% done,
Tail done, wings done, working on c-section
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bill Naumuk
Sent: Sunday, October 21, 2007 7:24 PM
Subject: Re: 601 XL
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Mon Oct 22, 2007 4:23 am Post subject: Re: 601 XL |
The barrel end with the a notch going around it indicates the side with left hand threads.
Good luck,
_________________ David Gallagher
Cincinnati, OH area |
Posted: Mon Oct 22, 2007 5:58 am Post subject: 601 XL |
Steve,
It sounds like the wrong parts, but take the time to call Zenith and ask
them and you'll
resolve this thing faster.
the trun buckles.
Steve # 55
GLJSOJ1
Joined: 18 Aug 2007 Posts: 82 Location: Chesapeake, Virginia
Posted: Mon Oct 22, 2007 6:26 am Post subject: 601 XL |
HI STEVE
THE TURN BUCKLES DO NEED TO HAVE RIGHT AND LEFT HAND THREADS SO THAT BOTH WILL TIGHTEN UP AND LOOSEN AT THE SAME TIME.
GLENN
| Quote: | Date: Mon, 22 Oct 2007 08:56:11 -0500
Subject: Re: Zenith-List: 601 XL
--> Zenith-List message posted by: LarryMcFarland <larry(at)macsmachine.com>
Steve,
them and you'll
> the trun buckles.
> Steve # 55
Boo! Scare away wormecare.live.com/standard/en-us/purchase/trial.aspx?s_cid=wl_hotmailnews' target='_new'>Try now! [quote][b]
_________________ 601XL N676L FLYING PHASE I
CHESAPEAKE VA |
Posted: Mon Oct 22, 2007 6:41 am Post subject: 601 XL |
Thanks to you all for the response. I had the feeling I was right. I ve always had "fun" with turn buckles. Especially the safety wiring .....
SW
planejim(at)bellsouth.net Guest
Posted: Mon Oct 22, 2007 9:22 am Post subject: 601 XL |
Steve,
The end of the turnbarrel with the left hand thread will have a small groove around it. Obvoiusly, you will need left hand threaded forks or eyes to screw into the left hand thread end of the barrel.
Jim Hoak
DaveG601XL
Posted: Mon Oct 22, 2007 11:30 am Post subject: Re: 601 XL |
Steve,
Just curious, but all my turnbuckles came from ZAC put together, where each barrel had the required threaded forks or eyes already threaded in. This meant all the right threads were in the right holes. Did yours come as separate pieces? Just wondering.
Posted: Mon Oct 22, 2007 11:54 am Post subject: 601 XL |
All turn buckles were apart in the finish kit....
