Posted: Tue Oct 23, 2007 3:22 pm Post subject: Tailplane slots in fuselage |
Hi All,
Step 7 on build manual pg. 19-7 describes the required travel (4
degrees up, 12 degrees down) of the trailing edge of the tailplane from
a neutral position. My fuselage had a faint but discernible ridge line
which I interpreted to be a cut-out line for the slots for the tab
link-rod TS05 which I previously followed when cutting out the slots.
As I now have the tailplanes mounted and am measuring to ensure they
can achieve the required travel, I'm finding that my slots are grossly
oversized, and most probably will be quite inviting for small birds and
varmints. Have any of you faced the same situation?
Now that I have marked the location of the tab link-rod in the extreme
up and down positions, and after taking into account the fore and aft
movement of the tab link-rod and adding 1/8" clearances, my intention
is to do some bid patching so that the slot is no larger than required.
I'm unclear as to the meaning of the last sentence on pg. 19-7 where it
states,
"...as the trailing edge of the tailplane is raised the trailing edge
of the tab raises even further, the ratio being approximately 1.3 to 1.
Therefore, when you have raised the trailing edge of the tailplane by
12 degrees, the tab should have raised 15.6 degrees relative to the
tailplane or 27.6 degrees from the zero start position.
A maximum total movement of 18 degrees and a minimum of 14.4 degrees
relative to the tailplane is acceptable."
Does the last sentence intend: A maximum total movement of the trim tab
of 18 degrees and a minimum of 14.4 degrees relative to the tailplane
is acceptable."
Or am I really missing the point?
Fred
believed to be clean.
rob(at)hyperion-ef.com Guest
Posted: Tue Oct 23, 2007 4:17 pm Post subject: Tailplane slots in fuselage |
In re: cutting the slots
The scribe lines on my fuselage were likewise “slightly” off from the actual location (and size) so I had to practice my fiberglass repair technique in order to reduce the ridiculously large gap.
In re: trim tab movement
Read on a bit further and the intent is made clear. The next paragraph in the manual concludes with this sentence: “A maximum total movement of 6 degrees and a minimum of 4.8 degrees OF TAB MOVEMENT (emphasis added) relative to the tailplane is acceptable
Best regards,
Rob Housman
Irvine, California
Europa XS Tri-Gear
S/N A070
Airframe complete
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Fred Klein
Sent: Tuesday, October 23, 2007 4:22 PM
Subject: Tailplane slots in fuselage
Hi All,
Step 7 on build manual pg. 19-7 describes the required travel (4 degrees up, 12 degrees down) of the trailing edge of the tailplane from a neutral position. My fuselage had a faint but discernible ridge line which I interpreted to be a cut-out line for the slots for the tab link-rod TS05 which I previously followed when cutting out the slots. As I now have the tailplanes mounted and am measuring to ensure they can achieve the required travel, I'm finding that my slots are grossly oversized, and most probably will be quite inviting for small birds and varmints. Have any of you faced the same situation?
Now that I have marked the location of the tab link-rod in the extreme up and down positions, and after taking into account the fore and aft movement of the tab link-rod and adding 1/8" clearances, my intention is to do some bid patching so that the slot is no larger than required.
I'm unclear as to the meaning of the last sentence on pg. 19-7 where it states,
"...as the trailing edge of the tailplane is raised the trailing edge of the tab raises even further, the ratio being approximately 1.3 to 1. Therefore, when you have raised the trailing edge of the tailplane by 12 degrees, the tab should have raised 15.6 degrees relative to the tailplane or 27.6 degrees from the zero start position.
A maximum total movement of 18 degrees and a minimum of 14.4 degrees relative to the tailplane is acceptable."
Does the last sentence intend: A maximum total movement of the trim tab of 18 degrees and a minimum of 14.4 degrees relative to the tailplane is acceptable."
Fred
Navigator to much much the Web ===========
topglock(at)cox.net Guest
Posted: Tue Oct 23, 2007 6:40 pm Post subject: Tailplane slots in fuselage |
Fred,
Realizing that the lines were only an approximation, I took care to start very small with the cuts to the fuse. When checking for clearance, one should check full deflection in both full up trim and full down trim positions. There is a noticeable difference in the clearance at each extreme. I allowed approximately 1/8" all around the range...
Keep pluggin' away, brother. You'll be flying soon enough...
Jeff - Baby Blue
336 hours
Fred Klein wrote: [quote]Hi All,
Fred
size color="#000000" face="courier new,courier">
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List href="http://forums.matronics.com">http://forums.matronics.com
Posted: Tue Oct 23, 2007 7:08 pm Post subject: Tailplane slots in fuselage |
On Tuesday, October 23, 2007, at 07:42 PM, Rman wrote:
| Quote: | Realizing that the lines were only an approximation, I took care to
Jeff...thanks bro'...and thank you too Rob,
Old Pennsylvania Dutch Saying: "Why Oh Why do I get so late smarter?"
Fred
