lcfitt(at)sbcglobal.net Guest
Posted: Tue Oct 23, 2007 3:49 pm Post subject: Boneyard |
Kay and I finally got to the salvage yard to pick up personal belongings and
look over the remains of N96KL. I thought some of you might be interested
in what we saw.
First, though, was what we felt. I had been concerned with what my emotions
might be when I saw the remains and was surprised to find that the reunion
was a bit dispassionate. It was not very emotional at all. Kay shed a tear
as we drove away, maybe because the airplane had been, in a sense, a bit of
competition with her for my time for nearly fifteen years. I took no
souvenirs, but have numerous pictures taken over those same years and tons
of video footage taken during the numerous flights. Maybe that is why I was
not too moved seeing the pile of "junk" We would have liked to have
lingered longer to just poke around, but the owner of the salvage yard
seemed to have no interest in us or our interests. I guess by agreement, he
stood as guardion of the salvage remains as an agent of the new owners - the
insurance company to see that nothing belonging to them ended up in the
trunk of our car. On the drive out, as we talked about him, I opined that
he probably had zero personality. Kay suggested that it might be possible
to be below zero in that area and we both laughed.
And junk it was.
A brief description. The engine and all attached to it including the
firewall and instrument panel were angled toward the ground so the spinner
flange was at ground level. The windsheld and all the skylight area tubing
was just gone as were the doors. The wings were folded back against a
crumpled fuselage (for trailering) and the empennage was moderately damaged.
The wings were pretty much intact, but the wing spars were damaged as were
the flaperons, but not severly, yet not salvagable without major work. The
empennage looked the best of all the structural components - salvageable but
not without some welding. Interestingly enough, the seats were just sitting
there as secure as could be with the seat belts piled on them with virtually
nothing overhead and everything forward moved forward which provided for
easy egress for us after the dust cleared.
The most striking thing I noticed was that the lift struts were perfect,
including the recently discussed rod end fittings. These are probably the
only structural members that could be bolted directly to another airplane
with nothing needed except cleaning up the fairings.
For those of you that opted for the Hammerhead landing gear when the quiet
war was raging between Grove and Hammerhead, the following might be of
interest. the gear was sheared off completely, but the gear showed no signs
of being bent or damaged in any way. It was my understanding that
Hammerhead opted for 7075 aluminum bent then treated to T6 , which if true,
is really tuff stuff and might explain the fine appearance of the gear legs.
Both tires (Mippi style) were still on the gear and the right tire deflated.
The left tire was still pressurized. I didn't have time to examine the tire
to see why it deflated, nor much time to examine much of any of the engine
or engine compartment. I did notice that the battery was in position snugly
held by the tray and the three adel clamps. The ELT was on the seats as it
had triggered and the emergency folks removed it to shut off the signal.
As to the point of impact? The gear sheared off, the engine was angeled
down which opened up the cockpit area (absolutely nothing above the seats)
like breaking a stick over your knee, both wingtips were damaged, but not
excessively, and the fuselage was crumpled. At the site, the bottom ring
cowl was under the tailwheel. My guess is that we came down hard on the
landing gear and it didn't absorb as much energy as might be expected and
the fuselage folded down over it. We had wondered what had caused the
puncture wound in Kay's calf - there was lots of broken structural tubing
that might have caused that.
The engine was apparently still running as one prop blade was sheared off at
the hub and the engine apparently ran for a third of a revolution as the
sheared blade was in a horizontal position.
One more interesting thing that I noticed. I made a thin aluminum enclosure
to hold the power supply for the video camera. It was about .5"x1.5"x2" in
dimension, mounted by adel clamps and the circuit board for the supply (the
only mass) mounted in the opposite side from the adel clamps. The impact
distorted this box to a parallelogram shape, by maybe 1/8". I don't know
how many Gs that represents, but we feel pretty fortunate we are doing as
well as we are, let alone us both being here.
Lowell
shinco(at)bright.net Guest
Posted: Wed Oct 24, 2007 1:19 am Post subject: Boneyard |
Thank GOD,,you guys are doing fine now Lowell Family.air planes can be
replaced.people can not.and the kitfox saved you both.would another
aircraft saved you in the same matter??I may think not.it just shows you
and to the rest of us.what a little Kifox can go through and walk away
from in a accident as your.with out beeing __ __ __....I hope that I do
not go through what U did.but if I do I want to know what the little
Kitfox can do in this type of accident as yours.I belive I too could
walk awy from it too.and in one pice.I wish you the best Lowell family
and for sharing this story with us,your kit fox family..Steve
Shinabery,KF 2 ,N554KF,hope to see you again flying your new
kitfox......
Lowell Fitt wrote:
belongings and look over the remains of N96KL. I thought some of you
might be interested in what we saw.
emotions might be when I saw the remains and was surprised to find
that the reunion was a bit dispassionate. It was not very emotional
at all. Kay shed a tear as we drove away, maybe because the airplane
had been, in a sense, a bit of competition with her for my time for
nearly fifteen years. I took no souvenirs, but have numerous pictures
taken over those same years and tons of video footage taken during the
numerous flights. Maybe that is why I was not too moved seeing the
pile of "junk" We would have liked to have lingered longer to just
poke around, but the owner of the salvage yard seemed to have no
interest in us or our interests. I guess by agreement, he stood as
the trunk of our car. On the drive out, as we talked about him, I
opined that he probably had zero personality. Kay suggested that it
might be possible to be below zero in that area and we both laughed.
And junk it was.
spinner flange was at ground level. The windsheld and all the
skylight area tubing was just gone as were the doors. The wings were
folded back against a crumpled fuselage (for trailering) and the
empennage was moderately damaged. The wings were pretty much intact,
but the wing spars were damaged as were the flaperons, but not
severly, yet not salvagable without major work. The empennage looked
the best of all the structural components - salvageable but not
sitting there as secure as could be with the seat belts piled on them
with virtually nothing overhead and everything forward moved forward
which provided for easy egress for us after the dust cleared.
perfect, including the recently discussed rod end fittings. These are
probably the only structural members that could be bolted directly to
another airplane with nothing needed except cleaning up the fairings.
quiet war was raging between Grove and Hammerhead, the following might
be of interest. the gear was sheared off completely, but the gear
showed no signs of being bent or damaged in any way. It was my
understanding that Hammerhead opted for 7075 aluminum bent then
treated to T6 , which if true, is really tuff stuff and might explain
the fine appearance of the gear legs. Both tires (Mippi style) were
still on the gear and the right tire deflated. The left tire was still
pressurized. I didn't have time to examine the tire to see why it
deflated, nor much time to examine much of any of the engine or engine
as it had triggered and the emergency folks removed it to shut off the
signal.
angeled down which opened up the cockpit area (absolutely nothing
above the seats) like breaking a stick over your knee, both wingtips
were damaged, but not excessively, and the fuselage was crumpled. At
the site, the bottom ring cowl was under the tailwheel. My guess is
that we came down hard on the landing gear and it didn't absorb as
much energy as might be expected and the fuselage folded down over
it. We had wondered what had caused the puncture wound in Kay's calf
- there was lots of broken structural tubing that might have caused that.
off at the hub and the engine apparently ran for a third of a
revolution as the sheared blade was in a horizontal position.
enclosure to hold the power supply for the video camera. It was about
.5"x1.5"x2" in dimension, mounted by adel clamps and the circuit board
for the supply (the only mass) mounted in the opposite side from the
adel clamps. The impact distorted this box to a parallelogram shape,
by maybe 1/8". I don't know how many Gs that represents, but we feel
pretty fortunate we are doing as well as we are, let alone us both
being here.
Lowell
dave
Posted: Wed Oct 24, 2007 7:22 am Post subject: Re: Boneyard |
Lowell,
Excellent write up on the aftermath and saying good bye to your Kitfox. You owe that Kitfox your lives possibly for taking hte brunt of the impact.
The construction of the Kitfox likely saved your lives. The Ability of the 4130 to absorb some of the impact. This cannot be compared but certainly in this instance some of the alum tube aircraft that seem very popular perhaps the occupants might not have faired as well.
Also, what was the cause of the oil issue that instigated the forced landing? Certainly alot of 912 drivers must have the same curiosity.
What brand oil filter were you using ?
Glad to hear the "rod ends" were in fact intact.
I am waiting to see documentation showing 5 gs or 14 gs .
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Posted: Wed Oct 24, 2007 9:14 am Post subject: Boneyard |
Dave,
I don't think we will ever know about the cause of the low oil pressure
gauge indication. I doubt the FAA or NTSB will spend a lot of time on this
due to the many other tasks at hand. The FAA guy said as much when he was
here at my home. He said that he was attempting to get a Rotax rep to look
at the engine, but to date there is no indication that that has been done.
At the time of his visit he was still investigating the fatal crash of the
Bonanza at Cameron Park that same morning.
http://www.youtube.com/watch?v=gOaAZ1i2gNA
And comparitively speaking our mishap was like a fender bender to the
Highway Patrol.
My feeling, though, it was a faulty sender. On the Rotax 912 UL the oil
temp and oil pressure senders are in the front of the engine and in the air
flow right behind the prop. I had problems with the temp sender frequently
due to broken wires. This I attributed to the prop pulses on the wires. I
tied them in very tightly, but sometimes they lasted less than six months.
The pressure sender? I am not a trained investigator, but my impression is
that the engine was still running at the time of impact and neither Kay or I
recall a stationary prop blade during the descent. Interestingly enough, I
have an audio recording of that entire flight, but previous experience of
listening to recordings of stressful situations in my airplane makes me
reluctant to listen to it yet. I have lots of video and that is not a
problem blood pressure wise, but listening to the audio, for some reason, I
can feel my heart rate and adrenaline level rise. It would give the
duration of the let down as there is conversation between Kay and I as I
began the descent to the time of impact. I don't know how long a 912 would
run with no oil, but I am sure it was at least two or three minutes or more
after seeing the low oil pressure indication and the hard landing.
Lowell
mclayton(at)rochester.rr. Guest
Posted: Thu Oct 25, 2007 4:18 am Post subject: Boneyard |
Lowell,
As many others, I have been so very glad that the outcome of your accident was, in the end, as positive as it was. All the prayers were answered, I would say!
Thought you and others might be interested to know about my KitFox II. I am in the midst of rebuilding it. The previous owner was involved in a departure stall, and suffered a very hard landing as a result. He too walked away from the accident. The front wing spars were destroyed, and the wing tips as well. The fuselage was actually bent, and one of the landing gear legs was destroyed. The motor mount was bent, and the prop strike destroyed the prop, of course. The ability of the aircraft to absorb the punishment, and yet have the pilot walk away from the accident was amazing. As I rebuild the aircraft, I find few opportunities to make it better structurally (I'm a mechanical engineer). The welded steel tube structure is without a doubt one of the lightest and strongest structures around, yet with the ability to absorb crash loads, protecting the occupants.
So, stay with it, and God bless both you and your wife.
mclayton(at)rochester.rr.com (mclayton(at)rochester.rr.com)
Mobile: 585-737-5506
Home: 585-352-1763
8 Adams Trail
Spencerport, NY 14559
N16AF (KF II Rebuild in Progress)
On Oct 23, 2007, at 7:48 PM, Lowell Fitt wrote:
[quote]--> Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net (lcfitt(at)sbcglobal.net)>
Kay and I finally got to the salvage yard to pick up personal belongings and look over the remains of N96KL. I thought some of you might be interested in what we saw.
First, though, was what we felt. I had been concerned with what my emotions might be when I saw the remains and was surprised to find that the reunion was a bit dispassionate. It was not very emotional at all. Kay shed a tear as we drove away, maybe because the airplane had been, in a sense, a bit of competition with her for my time for nearly fifteen years. I took no souvenirs, but have numerous pictures taken over those same years and tons of video footage taken during the numerous flights. Maybe that is why I was not too moved seeing the pile of "junk" We would have liked to have lingered longer to just poke around, but the owner of the salvage yard seemed to have no interest in us or our interests. I guess by agreement, he stood as guardion of the salvage remains as an agent of the new owners - the insurance company to see that nothing belonging to them ended up in the trunk of our car. On the drive out, as we talked about him, I opined that he probably had zero personality. Kay suggested that it might be possible to be below zero in that area and we both laughed.
And junk it was.
A brief description. The engine and all attached to it including the firewall and instrument panel were angled toward the ground so the spinner flange was at ground level. The windsheld and all the skylight area tubing was just gone as were the doors. The wings were folded back against a crumpled fuselage (for trailering) and the empennage was moderately damaged. The wings were pretty much intact, but the wing spars were damaged as were the flaperons, but not severly, yet not salvagable without major work. The empennage looked the best of all the structural components - salvageable but not without some welding. Interestingly enough, the seats were just sitting there as secure as could be with the seat belts piled on them with virtually nothing overhead and everything forward moved forward which provided for easy egress for us after the dust cleared.
The most striking thing I noticed was that the lift struts were perfect, including the recently discussed rod end fittings. These are probably the only structural members that could be bolted directly to another airplane with nothing needed except cleaning up the fairings.
For those of you that opted for the Hammerhead landing gear when the quiet war was raging between Grove and Hammerhead, the following might be of interest. the gear was sheared off completely, but the gear showed no signs of being bent or damaged in any way. It was my understanding that Hammerhead opted for 7075 aluminum bent then treated to T6 , which if true, is really tuff stuff and might explain the fine appearance of the gear legs. Both tires (Mippi style) were still on the gear and the right tire deflated. The left tire was still pressurized. I didn't have time to examine the tire to see why it deflated, nor much time to examine much of any of the engine or engine compartment. I did notice that the battery was in position snugly held by the tray and the three adel clamps. The ELT was on the seats as it had triggered and the emergency folks removed it to shut off the signal.
As to the point of impact? The gear sheared off, the engine was angeled down which opened up the cockpit area (absolutely nothing above the seats) like breaking a stick over your knee, both wingtips were damaged, but not excessively, and the fuselage was crumpled. At the site, the bottom ring cowl was under the tailwheel. My guess is that we came down hard on the landing gear and it didn't absorb as much energy as might be expected and the fuselage folded down over it. We had wondered what had caused the puncture wound in Kay's calf - there was lots of broken structural tubing that might have caused that.
The engine was apparently still running as one prop blade was sheared off at the hub and the engine apparently ran for a third of a revolution as the sheared blade was in a horizontal position.
One more interesting thing that I noticed. I made a thin aluminum enclosure to hold the power supply for the video camera. It was about .5"x1.5"x2" in dimension, mounted by adel clamps and the circuit board for the supply (the only mass) mounted in the opposite side from the adel clamps. The impact distorted this box to a parallelogram shape, by maybe 1/8". I don't know how many Gs that represents, but we feel pretty fortunate we are doing as well as we are, let alone us both being here.
Lowell
- The Kitfox-List Email Forum -
--> http://www.matronics.com/Navigator?Kitfox-List
- NEW MATRONICS WEB FORUMS -
--> http://forums.matronics.com
