sidsel.svein(at)oslo.onli Guest
Posted: Wed Oct 24, 2007 10:27 pm Post subject: Nose wheel towbar and attachment |
Does anyone have a proven solution for a towbar and its attachment to the nose gear?
I have the factory's wheel fairing installed.
Svein
LN-SKJ
sideslip(at)tiscali.co.uk Guest
Posted: Thu Oct 25, 2007 8:49 am Post subject: Nose wheel towbar and attachment |
Hi Svein,
I have a towbar and fittings attached to the nose gear.
I had two pieces of approx 1.5 inch aluminium rod recessed on one side with a hole through the center. These are attached to the nose wheel axle with the existing bolt, and the fairing cut to allow them to protrude slightly. The tow bar is made of steel tube with a piece of tube at each side of the attachment end sized to match the recess size in the aluminium collars. The towbar is in two parts which slide together to enable the attachment, then pinned to retain.
Hard to describe but if you want a photo, please let me know.
Geoff Leedham
G-EOFS 914 Trigear
jeff(at)rmmm.net Guest
Posted: Thu Oct 25, 2007 9:39 am Post subject: Nose wheel towbar and attachment |
Hi Geoff,
I too would like to see a photo posted if you have time.
Jeff R.
A258 - N128LJ / Gold Rush 91 hours and changing props.
On Oct 25, 2007, at 11:49 AM, Geoff Leedham wrote:
[quote] Hi Svein,
Geoff Leedham
G-EOFS 914 Trigear
Posted: Thu Oct 25, 2007 9:48 am Post subject: Nose wheel towbar and attachment |
Hi Geoff,
Interesting. I understand how you have done it, I believe, but if you have a photo on file, I would appreciate very much to see it.
How thick, approximately, did you make the "bottom" of the recess in order to get sufficient stiffness against bending the fittings?
Svein
ami(at)mcfadyean.freeserv Guest
Posted: Thu Oct 25, 2007 11:45 am Post subject: Nose wheel towbar and attachment |
Geof,
Photo please!
Duncan McF
hurstkr(at)redzone.com.au Guest
Posted: Thu Oct 25, 2007 10:53 pm Post subject: Nose wheel towbar and attachment |
What Duncan ? You haven't committed that blasphemous act and fitted a nose wheel have you ?
Best regards
Kingsley
[quote] Geof,
Photo please!
Posted: Fri Oct 26, 2007 2:31 am Post subject: Nose wheel towbar and attachment |
If He has I bet his won’t fall off !
Bob H G-PTAG
