mscotter
Joined: 15 Jan 2006 Posts: 49 Location: Winston-Salem, NC
Posted: Fri Oct 26, 2007 9:28 am Post subject: Kitfox vs. Van's RV |
Your statement kind of begs the question. Are there any Kitfox owners out there who regularly throw in a couple loops or rolls to mix things up? I know the 'Fox can do these things, I'm just wondering if anyone really does in practice, i.e. do people feel comfortable doing them, are they fun in the Kitfox, etc.
Mark Scott
Elkton, MD
| Quote: | -------------- Original message --------------
...SNIP...
"Jimmy's" video of the Kitfox IV speedster shows that model Kitfox doing aerobatics but I would not try it in my long wing Vixen. The wings flex to much and not enough ailerons control for me.
I'm not saying it can't be done, I'm just not comfortable with these things.
There are old pilots, and there are bold pilots, but there are no old, bold pilots!
I rent a Super Decathlon to get aerobatic time when I feel the need. Again different mission.
Mark
Kitfox 5 Vixen
912UL IVO
Hartford, Wisconsin
| [quote][b]
_________________ Mark Scott
Winston-Salem, NC |
MichaelGibbs(at)cox.net Guest
Posted: Fri Oct 26, 2007 9:40 am Post subject: Kitfox vs. Van's RV |
| Quote: | Are there any Kitfox owners out there who regularly throw in a
I have heard that it's not uncommon to see Steve Kellandar doing just
that in his Model IV-1200 Speedster.
| Quote: | ...are they fun in the Kitfox, etc.
That's what Tim Weber indicated after a couple of flights in my 'fox.
Mike G.
N728KF
Phoenix, AZ
darinh
Posted: Fri Oct 26, 2007 10:26 am Post subject: Re: Kitfox vs. Van's RV |
I am with Mark on this, I don't know how comfortable I would feel doing aerobatics in the Fox. It definitely can be done as shown by Jimmy Franklin in the famous Classic IV airshow video but...
I knew an instructor that used to do rolls in a Cessna 150...CRAZY!! Unfortunately, he is not around anymore.
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
Michel
Posted: Fri Oct 26, 2007 2:04 pm Post subject: Kitfox vs. Van's RV |
On Oct 26, 2007, at 1:03 PM, dave wrote:
Dave, I have seen, I think, all of your videos on YouTube. I have send
their link to many friends and, since the earth is round, I have even
received back those links from friends.
I cannot do what you are doing from my 2,400 ft asphalt runway because
it is an ICAO certified airfield with strong regulations. But even so,
I wouldn't dare to do half of what you are doing.
But I thank you for doing it and illustrate in as videos because it
shows me what a Kitfox can do and endure and it makes me feel more
confident if an incident should occur.
This being said and while I fly from a very safe airfield with lots of
flat fields around, I often do dead-stick landing on the mark, just to
practice precision landing if I should experience an engine cut. But
otherwise, I have never done what you guys are doing, like flying a few
feet over a river bed, etc. I am never below the legal 500 ft AGL.
Still, I love flying and I love my Kitfox and wouldn't exchange it for
anything else.
Cheers,
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
akanka(at)kiamichiwb.org Guest
Posted: Fri Oct 26, 2007 2:29 pm Post subject: Kitfox vs. Van's RV |
Michel,
The flying regulations in the U.S. do not specify a minimum altitude over
open water or sparsely populated areas. I've copied the part that specifies
our minimum altitude below:
"Except when necessary for takeoff or landing, no person may operate an
aircraft below the following altitudes:
(a) Anywhere. An altitude allowing, if a power unit fails, an emergency
landing without undue hazard to persons or property on the surface.
(b) Over congested areas. Over any congested area of a city, town, or
settlement, or over any open air assembly of persons, an altitude of 1,000
feet above the highest obstacle within a horizontal radius of 2,000 feet of
the aircraft.
(c) Over other than congested areas. An altitude of 500 feet above the
surface, except over open water or sparsely populated areas. In those cases,
the aircraft may not be operated closer than 500 feet to any person, vessel,
vehicle, or structure.
(d) Helicopters. Helicopters may be operated at less than the minimums
prescribed in paragraph (b) or (c) of this section if the operation is
conducted without hazard to persons or property on the surface. In addition,
each person operating a helicopter shall comply with any routes or altitudes
specifically prescribed for helicopters by the Administrator."
John Hart
Float Flyr
Posted: Fri Oct 26, 2007 3:51 pm Post subject: Kitfox vs. Van's RV |
Up here in the Great soon to be white, North TC (Transport Canada) has these
regs on low flight. There is also regs for allowed low flight, Approaches
and take offs Etc.
602.14 (1) [Repealed]
(amended 2003/03/01; previous version)
(2) Except where conducting a take-off, approach or landing or where
permitted under section 602.15, no person shall operate an aircraft
(a) over a built-up area or over an open-air assembly of persons unless the
aircraft is operated at an altitude from which, in the event of an emergency
necessitating an immediate landing, it would be possible to land the
aircraft without creating a hazard to persons or property on the surface,
and, in any case, at an altitude that is not lower than
(i) for aeroplanes, 1,000 feet above the highest obstacle located within a
horizontal distance of 2,000 feet from the aeroplane,
(ii) for balloons, 500 feet above the highest obstacle located within a
horizontal distance of 500 feet from the balloon, or
(iii) for an aircraft other than an aeroplane or a balloon, 1,000 feet above
the highest obstacle located within a horizontal distance of 500 feet from
the aircraft; and
(b) in circumstances other than those referred to in paragraph (a), at a
distance less than 500 feet from any person, vessel, vehicle or structure.
More words but essentially the same as the FAA regs.
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Fri Oct 26, 2007 4:43 pm Post subject: Kitfox vs. Van's RV |
Darin sez:
| Quote: | I knew an instructor that used to do rolls in a Cessna 150...CRAZY!!
Why do you consider that crazy? A properly executed roll would never
come close to the design limits for a normal category airplane. I'm
assuming that there are no restrictions on performing the maneuver in
the operating limitations. My Turbo Arrow has a placard saying that
no aerobatic maneuvers, including spins, are approved.
Mike G.
N728KF
Phoenix, AZ
dave
Posted: Fri Oct 26, 2007 5:12 pm Post subject: Re: Kitfox vs. Van's RV |
aileron roll is 1 g
loop 3 g
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
dave
Float Flyr
darinh
Posted: Sat Oct 27, 2007 8:59 pm Post subject: Re: Kitfox vs. Van's RV |
Mike,
Have you ever flown a C150 (this is a 1964 150 not a newer 152 Acrobat)? I fly one regularly and although it is capable of a roll, it just is not made for them and doesn't execute them very well at all...this is why I think he was crazy. The way he would roll the aiplane was to first point the nose toward the ground to get the airplane right up to redline then pull up fairly aggressively and do the roll. When the roll was completed, he would exit in a pretty steep nose down attitude and would have lost a couple hundred feet in the process. The POH on the C150 says nothing about acro except that loaded under utiliy class, it can do spins. You may think rolls is a 150 are fine but I think its a bit loco.
Series 7
914 Turbo
Kaysville, Utah |
Posted: Sat Oct 27, 2007 9:27 pm Post subject: Kitfox vs. Van's RV |
Darin sez:
| Quote: | Have you ever flown a C150 (this is a 1964 150 not a newer 152 Acrobat)?
Yes. I did my initial training in a C-150. Didn't fly a 152 until I
was almost ready for my private pilot check ride.
| Quote: | I fly one regularly and although it is capable of a roll, it just is
I was just asking why you thought so, not suggesting it was smart.
Short-winged Kitfoxes are supposed to be able to roll at 120 degrees
per second. I never rolled my Model IV myself but it seemed like
that number was in the ball park. I think the Kitfox would do a much
better job than your description of the 150's version.
Mike G.
N728KF
Phoenix, AZ
wingsdown(at)verizon.net Guest
Posted: Sat Oct 27, 2007 9:35 pm Post subject: Kitfox vs. Van's RV |
Good point Darin. As it was pointed out to me once by a very experienced
pilot, yes you can do aerobatics in a Kitfox. However, the margin for
error is very small. Do it exactly right every time and you're a great
pilot. Get it wrong and it can be very very wrong and usually
unrecoverable for a variety of what should be oblivious reason. I think
some years ago another wise person on the list suggested it is best to
get into an aircraft designed to do what you intend to do in it. Like
Noel said, the tri gear is not going to like the sand bars. And so the
debate of how good a person thinks he or she is compared to what the
aircraft was designed for goes on. I would rather not gamble with that
side of luck. I do however hold sacred anyone's right to make that
decision for their self. I to have had much fun in my life while doing
stupid things. Seems the older I get the more stupid things I realize I
have done. Not suggesting anyone here is stupid.
Rick
darinh
Posted: Sun Oct 28, 2007 7:28 am Post subject: Re: Kitfox vs. Van's RV |
Rick,
Very well said...my thoughts exactly.
Series 7
914 Turbo
Kaysville, Utah |
Float Flyr
Posted: Sun Oct 28, 2007 8:00 am Post subject: Kitfox vs. Van's RV |
Stupid things??? I'm still doing them.
Earlier this fall a friend visited here with his Ducatti (ST3??) This is a
sport touring machine. Of course I had to take it for a little run. I went
up a hill behind a pick up truck at about 60 KPH. Slipping the clutch in
first gear. At the top of the hill I fire walled the throttle and before
you can say "Boo" I was through three or four gears and way too close to
200Kph for comfort.
Easing off the throttle allowed the bike to slow a little. The lightest
squeeze on the ABS brakes had me back to 80 Kph. No I didn't need to change
my shorts. I can only imagine trying to explain to a Mountie that I really
didn't intend to exceed the posted limit by over a hundred Kilometres per
hour! Even if it was only for the length of a cat's tail.
The fact I'd love to have one of those bikes makes me think I should have my
head examined. I figure you could time the validation of my license with a
stopwatch if I had one of those.
Noel
[quote] --
Kitfox III-A
dave
Posted: Sun Oct 28, 2007 8:04 am Post subject: Re: Kitfox vs. Van's RV |
Rick, Can you elaborate on what this means ?
Thx
| Quote: | Do it exactly right every time and you're a great
unrecoverable for a variety of what should be oblivious reason. |
