Michel
Posted: Sat Oct 27, 2007 6:10 am Post subject: Low flying |
On Oct 27, 2007, at 12:25 PM, dave wrote:
| Quote: | when was the last time that you did some training ?
Last time was last Saturday, Dave, and I would do it again this
week-end if the weather permitted it. I do simple but rather long
traffic patterns where I use everything I know of to make me feel
confident with the plane. The reason of the "simple traffic pattern" is
that I fly under radar control with transponder on since it is within
a CTR. I fly very slow, to the edge of stall (in fact, it was Torgeir
on this list who told me first to do that) I stall, hear the turtledeck
pop and mush down. I do it straight and in a turn but not as much as 60
degrees bank. I do a lot of side slips and end up with a dead stick
landing on the mark. I do stalls on downwind at 1,000 AGL. One thing I
also like to practice is to rock the wings while keeping the nose of
the plane on one point on the horizon. It's good for co-ordinating
pedals and stick.
In fact, it's all the fun of flying a Kitfox: feel the plane and be
"with it." Flying from A to B is boring unless the scenery is very
interesting.
I also know that you do your flying from your own landing strip, Dave.
I have no objection to anything you say and if I gave the impression
that I had, I am very sorry as it was not intentional. But it doesn't
change the fact that most fatal accidents occur at low speed and low
altitude. Even the Norwegian who built my Kitfox got killed in his
first model 2, a few weeks after my plane's first flight, while he was
doing a sharp turn a few feet over the end of the runway.
Cheers,
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
dave
Posted: Sat Oct 27, 2007 2:54 pm Post subject: Re: Low flying |
Michel,
| Quote: | I stall, hear the turtledeck
pop and mush down. |
Is that the noise that you hear last year ? The thud?
Funny , with VG;s on now i have a less announced stall warning -- less buffet, food for thought if you plan on using Vgs.,
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Michel
Posted: Sun Oct 28, 2007 1:55 am Post subject: Low flying |
On Oct 28, 2007, at 12:54 AM, dave wrote:
| Quote: | > I stall, hear the turtledeck pop and mush down.
Exactly, Dave! I needed a passenger who could look backward to assess
my 'thud.' He confirmed that it was the turtledeck that was flexing. I
have the original model 3 turtledeck with the hinge in the middle. As
the plane stalls, it is the first surface to loose laminar flow and it
results in a flexing with a characteristic sound.
Cheers,
Michel Verheughe
Norway
dave
Lynn Matteson
Posted: Sun Oct 28, 2007 2:28 am Post subject: Low flying |
Michel-
The cost from here (USA) would be prohibitively expensive, but LP
Aeroplastics sells, (and maybe John McBean does too), a domed
turtledeck that resists flexing. Alas, you cannot bend the 'deck for
storage, but on the other hand it doesn't leak water in the rain
either. It (the 'deck) will fit into my cabin if I have to take it
off for some reason...trailering, etc...but just barely.
Lynn Matteson
flying w/420+ hrs
On Oct 28, 2007, at 5:54 AM, Michel Verheughe wrote:
assess my 'thud.' He confirmed that it was the turtledeck that was
flexing. I have the original model 3 turtledeck with the hinge in
the middle. As the plane stalls, it is the first surface to loose
laminar flow and it results in a flexing with a characteristic sound.
Cheers,
Michel Verheughe
Norway
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
dave
Float Flyr
Posted: Sun Oct 28, 2007 8:34 am Post subject: Low flying |
If you never have to fold your turtle deck you could run a bit of solder
into the hinge. I got two turtle decks with my plane one with and one
without the hinge. I have yet to fir the hinged turtle deck. It will fit
in the cabin of the plane or the back of the car on top of the gas
containers.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Sun Oct 28, 2007 11:01 am Post subject: Low flying |
The LP Aeroplastics turtledeck material is about .100" to .125" as I
recall, maybe thinner than that.
I can't visualize using a brake to bend Lexan...seems to me it's
gotta be heated to bend. I'm not sure why you're asking about bending
the Lexan....
Lynn Matteson
flying w/420+ hrs
On Oct 28, 2007, at 6:34 AM, dave wrote:
Lynn, could you bend a piece of Lexan in a brake to make it work ?
Would only be 2 bends and lexan bends fairly nicely.
I have to replace my Windshield one day --maybe this winter it has
been cracked for nearly 2 years now and got a band-aid on it an
taped
I have Lexan in stock here 1 and 3 mm , what is the thickness of
the turledeck ?
Rotax Dealer, Ontario Canada
Flying Videos and Kitfox Info
http://www.cfisher.com/
N369LM |
Michel
Posted: Sun Oct 28, 2007 11:05 am Post subject: Low flying |
No, Dave, I don't mind the noise of the turtledeck popping, it's my
stall warning.
Yes, Lynn, I could have a different turtledeck since I never need to
fold the wings. The rain water problem is also a concern. But it is not
in my immediate list of to-do. The strange thing is that, each time I
come in the hangar to do some work ... I find an excuse to fly instead.
Can you understand that?
Noel, I don't know about solder, I run a tape along the hinge to keep
water away, Still, if it rains, some water comes in. Mind you, my
Kitfox is never left outside but when I spend the night at a different
airfield, it may happen.
Cheers,
Michel Verheughe
Norway
Lynn Matteson
Posted: Sun Oct 28, 2007 11:16 am Post subject: Low flying |
If I had to do it...and I'm glad I don't....I'd run a length of tape
down the hinge. I can't imagine soldering that aluminum hinge, anyway.
Lynn Matteson
flying w/420+ hrs
On Oct 28, 2007, at 12:31 PM, Noel Loveys wrote:
solder
will fit
containers.
Noel
N369LM |
dave
Posted: Sun Oct 28, 2007 4:34 pm Post subject: Re: Low flying |
| Quote: | I can't visualize using a brake to bend Lexan...seems to me it's
the Lexan....
Sure you can bend Lexan in a brake .
would you like a picture or a video clip ?
Float Flyr
Posted: Sun Oct 28, 2007 4:43 pm Post subject: Low flying |
Tape will keep the water out but solder will fill the voids in the hinge and
make the turtle deck mechanically stronger. Covering the hinge with a layer
or two fibreglass may do the same thing lighter.
I'm just trying to figure a way of giving your TD a bit more strength
without actually building a new one.
Noel
[quote] --
Kitfox III-A
shinco(at)bright.net Guest
Posted: Sun Oct 28, 2007 4:55 pm Post subject: Low flying |
Hi Dave..you can use a break to bend Lexan.we do this at Honda engine
plant all the time.and it works great..even with out heat.some times
though it does break.BUT that Lexan is tuff stuff.belive me it does
work. Steve Shinabery N554KF KF2
dave wrote:
> the Lexan....
http://forums.matronics.com/viewtopic.php?p=142380#142380
Michel
Posted: Wed Oct 31, 2007 7:43 am Post subject: Low flying |
On Oct 29, 2007, at 1:42 AM, Noel Loveys wrote:
| Quote: | I'm just trying to figure a way of giving your TD a bit more strength
Thank you, Noel and Lynn. I might consider a new turtledeck but ... I
don't think the reason mine makes a sound is that it is weak ... or
does it? Nobody else is hearing that sound? It's not a big one but my
Jabiru at idle is making almost no noise at all and, in fact, I never
noticed it when I had the 582.
Cheers,
Michel Verheughe
Norway
Lynn Matteson
Posted: Wed Oct 31, 2007 9:22 am Post subject: Low flying |
I guess if it was me, I'd try to temporarily stiffen the t'deck and
see if this eliminates/changes the noise.
Lynn Matteson
flying w/420+ hrs
On Oct 31, 2007, at 11:39 AM, Michel Verheughe wrote:
I don't think the reason mine makes a sound is that it is weak ...
or does it? Nobody else is hearing that sound? It's not a big one
but my Jabiru at idle is making almost no noise at all and, in
fact, I never noticed it when I had the 582.
Cheers,
Michel Verheughe
Norway
N369LM |
