rv10(at)sinkrate.com Guest
Posted: Sun Oct 28, 2007 6:36 pm Post subject: Section 23 question about torque tube installation |
I have a question about the torque tube installation on Sec 23-7. When installing the torque tube the plans call for shimming any misalignment forward/aft using AN960-416/L washers. After the tube is slipped in place (scratching off a sizeable portion of my nicely primed and painted WD-1014C’s) and bolted together there was a fair amount of forward/aft play between the bearings. An AN960-416 on each side of torque tube between the bearings took the play out but as a result there is not enough threads poking through the AN365-428 lock nuts to be acceptable. If I take the washers out its might be possible to get 1 threads worth on each forward and aft nut but that might introduce some pre load on the structure (read squeeze things together)
Has anyone else encountered this? Should I just use a shorter lockunut?
Pictures here: http://www.sinkrate.com/rv10/pics.asp?f=sec23
-Ben
#40579
PDX
VHMUM(at)bigpond.com Guest
Posted: Sun Oct 28, 2007 7:49 pm Post subject: Section 23 question about torque tube installation |
Vans know about this and were going to change the plans and parts to a thinner lock nut.
regards chris 388
Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Mon Oct 29, 2007 4:53 am Post subject: Re: Section 23 question about torque tube installation |
Aircraft Spruce 364-428 nuts are the low profile nuts that will give you your thread engagement. Their part number is 04-01499.
Eric Kallio
40518 floors and antennas
