Posted: Mon Oct 29, 2007 10:24 am Post subject: Primer preparation question/ WD415 Trim Cable AnchorBracket |
I'm 40720 so pretty much right with you as far as parts received. I received a pretty good piece that I think is quite fine, the older piece was a welded weakly issue.
As far as options, (assuming you have three months to wait) http://www.rivethead-aero.com/rv10_005.htm
I ended up priming the whole piece, there has been no issue with placing the cable and it holding fine.
Pascal
Wings
40720
