ScooterF15
Posted: Mon Oct 29, 2007 12:33 pm Post subject: Radio Static Help |
Hi,
I've been on the RV-10 list for a few years, but I've never posted to AeroElectric. I've searched the list and haven't found anything that helped to solve my problem. I'd appreciate any suggestions that you can offer:
I've spent the last few weeks trying to track down a problem with radio static on my Garmin SL-30 Nav/Comm in my Vans RV-10. The SL-30 is attached to a Garmin GMA-340 Audio panel. The static itself sounds random (i.e. not obviously uniform like I would expect from an ignition system), however, it is somehow associated with engine throttle setting. The static starts around 2000 RPM and gets progressively worse as throttle increases. On takeoff, it is so bad you can not comprehend any received transmissions. During cruise it appears to be somehow associated with manifold pressure (i.e. throttle setting, not RPM). It makes listening to ATC difficult to impossible. I also think it may be affecting my radio transmissions as well, because when I have a hard time comprehending ATC, they also have a hard time understanding me. This static appears to be only affecting the Comm audio, there is no static on NAV audio reception. I have a belly mounted bent whip VHF antenna and a wingtip VOR antenna. My handheld ICOM VHF radio does not have any static when used inside the cockpit. Also, I have a Lycoming IO-540 with one mag and one LightSpeed Plasma II+ ignition.
I have searched various lists for ideas and tried to solve this problem, but I have had no success in changing it at all (for better or worse). Any suggestions for what to try or where to look will be welcome. Below is a list of some things I have tried with no luck.
General
-Shut off all avionics (except SL-30) and both ignition systems (not both at the same time)
--So it doesn't appear to be interference from other electronics
Antenna/Coaxial cable
-Added ferrite signal filters at various locations along comm coax.
-Connected SL-30 to a different comm antenna using a piece of RG-400 (tried
various routings to antennas)
-Connected SL-30 Comm to VOR antenna (great reception, still static)
--So it doesn't appear to be antenna related
Power/ground
-Ensured engine grounding cables have good contacts on both ends
-Apparently new Slick Magnetos have internal suppression and do not need a filter
-Separated SL-30 power/ground leads from bundle to reduce potential interference from other wires
-Ran SL-30 +12V and ground leads directly to battery
-Disconnected serial connection between my SL-30 and EFIS indicator
-Connected SL-30 to separate 12V battery sitting on floor of aircraft, disconnected power/ground to GMA-340. Attached ICOM handheld antenna directly to unit (SL-30 completely isolated from aircraft)-reception still has static
-Ran ground wire from battery to SL-30 tray
-Checked to ensure headseat jacks were isolated from aircraft ground.
-Checked the shield connections for tachometer and fuel flow sensor wires
I can't think of anything else to try. Again, I'd be happy to hear any suggestions.
Thanks.
-Jim
N312JE
Jim "Scooter" McGrew
http://www.mit.edu/~jsmcgrew
frank.hinde(at)hp.com Guest
Posted: Mon Oct 29, 2007 2:08 pm Post subject: Radio Static Help |
Has it always been there or did it come about after a few hours running?
Sometimes I get ignition noise...Then I change out the auto plugs and it
goes away.
If you have auto plugs on your EI it might be worth a try for a $1.20 a
piece...then turn off your mag in flight.
frank
mprather(at)spro.net Guest
Posted: Mon Oct 29, 2007 2:10 pm Post subject: Radio Static Help |
Based on the symptoms you have described, it sounds kind of like acoustic
noise getting into the intercom. Have you unplugged all of the headset
mics (the small plug) from the system while in flight?
Matt-
Hi,
offer:
attached
| Quote: | to a Garmin GMA-340 Audio panel. The static itself sounds random (i.e.
not
| Quote: | obviously uniform like I would expect from an ignition system), however,
a
| Quote: | hard time understanding me. This static appears to be only affecting the
mounted bent whip VHF antenna and a wingtip!
| Quote: | VOR antenna. My handheld ICOM VHF radio does not have any static when
Any
| Quote: | suggestions for what to try or where to look will be welcome. Below is
a
| Quote: | list of some things I have tried with no luck.
General
both
| Quote: | at the same time)
(tried
| Quote: | various routings to antennas)
Power/ground
a
| Quote: | filter
| Quote: | -Ran SL-30 +12V and ground leads directly to battery
still
| Quote: | has static
wires
suggestions.
ScooterF15
Posted: Mon Oct 29, 2007 2:18 pm Post subject: Radio Static Help |
Frank,
I've only been flying for a year. It seems like the problem has grown worse in the last 6 months. I just did an annual an changed out all my plugs (auto on top / aviation on bottom).
Thanks.
Jim
In a message dated 10/29/2007 6:10:14 P.M. Eastern Daylight Time, frank.hinde(at)hp.com writes:
| Quote: | --> AeroElectric-List message posted by: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
goes away.
frank
See what's new at AOL.com and
ScooterF15
Posted: Mon Oct 29, 2007 2:21 pm Post subject: Radio Static Help |
Yes, the intercom is completely clear when in flight with and without the other 3 headsets plugged in. For most of the testing I turned my GMA-340 off so the pilot's headset is wired directly to the SL-30 and the intercom is not operating - this does not effect the static.
Thanks.
-Jim
In a message dated 10/29/2007 6:12:07 P.M. Eastern Daylight Time, mprather(at)spro.net writes:
| Quote: | --> AeroElectric-List message posted by: "Matt Prather" <mprather(at)spro.net>
Matt-
jetboy
Posted: Mon Oct 29, 2007 10:33 pm Post subject: Re: Radio Static Help |
Have you considered the alternator regulator starting to regulate at 2000 rpm upwards, and the more pronounced effect this could be having with an older battery, letting transient noise into the DC bus?
Ralph
_________________ Ralph - CH701 / 2200a |
bakerocb
Posted: Tue Oct 30, 2007 4:20 am Post subject: Radio Static Help |
10/30/2007
Hello Scooter, You wrote: "I can't think of anything else to try. Again, I'd
be happy to hear any suggestions."
Try going to the System mode and play around with the squelch adjustments.
Please let us know how you finally solve this problem.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
Time: 01:34:50 PM PST US
Subject: Radio Static Help
Hi,
AeroElectric.
--------- BIG SKIP -----------------------------------
suggestions.
Thanks.
-Jim
N312JE
ScooterF15
Posted: Tue Oct 30, 2007 5:03 am Post subject: Radio Static Help |
I have an alternator over voltage protection setup with an alternator solenoid which will open when the alternator field circuit breaker pops. I think I've ruled out a regulator problem since the static continues after I pull the alt field c/b; is that a bad assumption?
-Jim
In a message dated 10/30/2007 2:41:35 A.M. Eastern Daylight Time, sanson.r(at)xtra.co.nz writes:
| Quote: | --> AeroElectric-List message posted by: "jetboy" <sanson.r(at)xtra.co.nz>
Ralph
See what's new at ww.aol.com?NCID=AOLCMP00300000001170" target="_blank">AOL.com and
bobf(at)feldtman.com Guest
Posted: Tue Oct 30, 2007 7:35 am Post subject: Radio Static Help |
I'd check spark plug wires.
need ones with considerable inductance (spiral wound) to surpress HV RFI
bobf
On 10/30/07, JSMcGrew(at)aol.com (JSMcGrew(at)aol.com) <JSMcGrew(at)aol.com (JSMcGrew(at)aol.com)> wrote: [quote] I have an alternator over voltage protection setup with an alternator solenoid which will open when the alternator field circuit breaker pops. I think I've ruled out a regulator problem since the static continues after I pull the alt field c/b; is that a bad assumption?
-Jim
In a message dated 10/30/2007 2:41:35 A.M. Eastern Daylight Time, sanson.r(at)xtra.co.nz (sanson.r(at)xtra.co.nz) writes:
| Quote: | --> AeroElectric-List message posted by: "jetboy" < sanson.r(at)xtra.co.nz (sanson.r(at)xtra.co.nz)>
Ralph
f.miskelly(at)imperial.ac Guest
Posted: Tue Oct 30, 2007 8:33 am Post subject: Radio Static Help |
I had an exactly identical problem with a KX155. There was a thread on it several months ago
Eventually found it was the intercom picking up ignition noise. To diagnose it i had to remove the intercom pin from the back of the radio. Most, but not all, of the noise disappeared. Just working on one headset without removing the intercom pin-out still gave the problem. Solved it by installing an external intercom.
- Frank
From: owner-aeroelectric-list-server(at)matronics.com on behalf of Matt Prather
Sent: Mon 29/10/2007 22:09
Subject: Re: Radio Static Help
Matt-
Hi,
offer:
attached
not
a
Any
a
General
both
(tried
Power/ground
a
| Quote: | filter
still
| Quote: | has static
wires
suggestions.
xl(at)prosody.org Guest
Posted: Tue Oct 30, 2007 9:59 pm Post subject: Radio Static Help |
I had a similar problem. static on takeoff and > ~2000 rpm
and loader as RPM increased.
I found a bad crimp connection on an alternator wire.
The wires were oxidized - not a gas tight connection.
I soldered the connection and it's been quiet since.
Some frequencies did not have static. 123.05 did.
Hence the randomness.
I also had static, at one time, from loose distributor caps.
Joe E (at) BFI
N633Z ~495 hours
CH601XL, Jabiru 3300A
On Mon, 29 Oct 2007, ScooterF15 wrote:
Hi,
offer:
.......snip .......snip
donaldjsmith(at)ukonline. Guest
Posted: Wed Oct 31, 2007 2:16 pm Post subject: Radio Static Help |
Have you consider the HT leads to the plugs - say breakdown of insulation/suppression. Use to get this sort of fault in the old days on cars. Might be temp. related. Suggest replacing all HT side of ignition system.
Donald
