paulrod36(at)msn.com Guest
Posted: Mon Oct 29, 2007 12:38 pm Post subject: A new thread |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Does anybody know what the process is to anodyne sheet aluminum in colors? It strikes me that if your whole plane was skinned in, say, blue, or red, the only weight you'd have to carry would be the paint for some nice stripes and the N-number.
Let the games begin!
Paul Rodriguez
psm(at)ATT.NET Guest
Posted: Mon Oct 29, 2007 1:58 pm Post subject: A new thread |
Hi Paul
The process is actually called anodizing. It is a close cousin to
electroplating. The resulting surface is jelly like and absorbs food
coloring to get the actual final color. It isn't very hard and not a
good protection from the elements.
Paul
XL fuselage
At 01:37 PM 10/29/2007, you wrote:
| Quote: | Does anybody know what the process is to anodyne sheet aluminum in
Paul Rodriguez
Gig Giacona
Posted: Mon Oct 29, 2007 2:41 pm Post subject: Re: A new thread |
And I believe I've read that it would weaken the metal somewhat.
[quote="psm(at)ATT.NET"]Hi Paul
Paul
XL fuselage
Paul Rodriguez
601XL Under Construction
Jaybannist(at)cs.com Guest
Posted: Mon Oct 29, 2007 3:50 pm Post subject: A new thread |
I Don't know where either of you got that "information", because anodizing actually makes the aluminum much harder. The original purpose of anodizing was to help protect aluminum from the elements and physical abuse, typically for exterior use on buildings. It was only later that coloring during the anodizing process came into use, and coloring has no effect on hardness. The surface of anodized aluminum is ALWAYS more durable than plain aluminum; and the surface can be made to be nearly as hard as a diamond, depending on the process used.
Jay in Dallas
"Gig Giacona" <wr.giacona(at)suddenlink.net> wrote:
Paul
XL fuselage
> Paul Rodriguez
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=142620#142620
smoore
Posted: Mon Oct 29, 2007 4:01 pm Post subject: A new thread |
The surface is made harder, i.e. more brittle. Whether this is a BadThing (tm) is left to the arguers. It's hashed out in lots of forums over and over and over.
The big controversy comes when people anodize spars.
I have no opinion on the matter either way, still researching.
On 10/29/07, Jaybannist(at)cs.com (Jaybannist(at)cs.com) < Jaybannist(at)cs.com (Jaybannist(at)cs.com)> wrote:[quote]--> Zenith-List message posted by: Jaybannist(at)cs.com (Jaybannist(at)cs.com)
Jay in Dallas
"Gig Giacona" <wr.giacona(at)suddenlink.net (wr.giacona(at)suddenlink.net)> wrote:
| Quote: | --> Zenith-List message posted by: "Gig Giacona" < wr.giacona(at)suddenlink.net (wr.giacona(at)suddenlink.net)>
Paul
>XL fuselage
| Quote: | do not archive
> Paul Rodriguez
W.R. "Gig" Giacona
moore.sean(at)gmail.com (moore.sean(at)gmail.com) [quote][b]
_________________ --
Sean Moore
... re-evaluating mission |
raymondj(at)frontiernet.n Guest
Posted: Mon Oct 29, 2007 4:25 pm Post subject: A new thread |
I know nothing about anodizing myself, but I recall a discussion on one of
my lists (don't remember which) that said that anodizing made the aluminum
surface harder and more durable but the downside was that the surface could
crack during distortion and create stress concentrators and cause premature
failure of the metal.
Just a discussion I recall. Don't know if it is true or not, just offering
it as another piece of data.
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
planecrazydld(at)yahoo.co Guest
Posted: Mon Oct 29, 2007 5:16 pm Post subject: A new thread |
Paul;
While I am not an expert and am not qualified to give a rebuttal, I believe you are not right on this. color anodizing is used for a final finish on many parts in teh machine, racing, and tool industry. Anodizing is a hard coating and it is aluminum oxide so it is a barrier against further corrosion to some degree. There is even a process called hard anodizing where the surface is made hard enough to rpovide some wear resistance. I am certain that someone far more qualified than I can give accurate detailed information on the anodizing process.
Dave Downey
Harleysville (SE) PA
100 HP Corvair
Posted: Mon Oct 29, 2007 5:17 pm Post subject: A new thread |
I don't think that bending an anodized aluminum sheet would be recommended. The surface is harder, but it is also more brittle, less ductile. Anodizing is usually done on sheet metal that is already formed. Once the forming has concluded, ductility is not an issue and anodizing won't contribute a concentration of stresses.
Jay in Dallas
Raymond Julian
Kettle River, MN
"Hope for the best,
Posted: Mon Oct 29, 2007 5:19 pm Post subject: A new thread |
...just make sure thast you do not try to Alodine treat any assembled structure. The process must be thoroughly rinsed to stop the attack (all but one specific type of Alodine).
Dave Downey
100 HP Corvair
Gig Giacona
Posted: Mon Oct 29, 2007 7:22 pm Post subject: Re: A new thread |
| Jaybannist(at)cs.com wrote: | | I don't think that bending an anodized aluminum sheet would be recommended. The surface is harder, but it is also more brittle, less ductile. |
Which is what I meant by weaker. I probably should have said brittle.
jimandmandy(at)yahoo.com Guest
Posted: Mon Oct 29, 2007 8:52 pm Post subject: A new thread |
Its the so called "hard" anodizing, which is black in
color that makes parts brittle. An unfortunate
incident with black anodized helicopter control rods
was a good illistration to me. We had hard anodize
parts recently fail fatigue tests at work. I related
this to a long-retired Douglas engineer and he said it
was common knowlege. Some lessons have to be learned
over and over again.
Clear or color anodize, which is clear plus color dye,
is too thin to weaken the base metal. When I worked at
Hi-Shear (the aerospace fastener company), we anodized
all the aluminum parts we made. 2024 and 7075 alloys
need corrosion protection.
Back in the 1960's, Continental Airlines tried the
idea of gold anodized skins instead of paint for the
Convair 880. It didnt work, looked like a
checkerboard. The process is just not that even in dye
absorbtion to use on sheet metal skins.
--- David Downey <planecrazydld(at)yahoo.com> wrote:
[quote] Paul;
process.
Dave Downey
100 HP Corvair
