Construction Sequence
Kearney(at)shaw.ca
PostPosted: Tue Oct 30, 2007 8:19 am    Post subject: Construction Sequence Reply with quote
Hi All
I have been building a bit out of sequence - tail first then slo build fuse. Last will be QB wings. This has been largely driven by the amount of space available in my garage and my desire to keep the project as close as possible.
As winter aproaches and and look forward to completing section 29, I see that the tailcone attachment is not far off. This may cause a small space problem.
When I started this project, my wife agreed that the project scope must include the provision that she be able to park her car in the garage during the winter. Unfortunately she did not agree that the requirent that she be able to open her car door whilst in the garage was a scope change and subject to negotiation. Considerng the untenable position I was in, I immediatel capitualted.
I still have enough space in the garage to continue up to the point the tail and fuse are mated. I don't have enough space to allow for the tail control surfaces or wings to be attached.
My question for those who have gone before: are there any landmines in this aproach that I need to be concerned about. My plan is to leave the wings / engine / tail control surfaces to the very last.
Cheers
Les
#40643 - Still singing the section 29 blues
rene(at)felker.com
PostPosted: Tue Oct 30, 2007 8:35 am    Post subject: Construction Sequence Reply with quote
I mounted the tail control surfaces for fitting but then removed them and followed the path you are on except I did build my wings …90% point….before I started on the fuselage. I mated the tail and fuselage and put the cabin top on etc. Once I got to that point, I had to move to the hanger……I did have to rearrange my garage layout once my wife figured out that she could not get in and out of her car while it was in the garage……
Also, I stored my 90% wings in the hanger while I worked on the fuselage.
Rene' Felker
N423CF
40322
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LES KEARNEY
Sent: Tuesday, October 30, 2007 10:18 AM
Subject: Construction Sequence
Hi All
Cheers
Les
Kearney(at)shaw.ca
PostPosted: Tue Oct 30, 2007 8:58 am    Post subject: Construction Sequence Reply with quote
Rene
6nbsp;
It is reassuring to know that I am not the only plan deviant on the list E E E Where there ny 2gotchas 2 to be careful about?
6nbsp;
Cheers
6nbsp;
Les
340643 - Still singing the section 9 blues
Tim Olson
PostPosted: Tue Oct 30, 2007 9:02 am    Post subject: Construction Sequence Reply with quote
I've got 2 great options for you (her):
1) Do you have any exposed turf on your property? You could
build yourself another garage for her, or better yet, a
nice 36 x 36 heated/insulated/Cable Equipped work area.
2) I think if you check around you may still be able to find
Yugos, or Geo Metros, or if you want to treat her really special
perhaps a mini cooper. That might just give you enough
leeway.
Sorry, just couldn't resist.
As for your question, I don't think you really need to mount any
tail surfaces at all until you are just prepping for paint or
perhaps even after. No big deal doing those during final assembly,
but you'll want to trim the intersection fairing before painting
or be super careful anyway.
LES KEARNEY wrote:
Hi All
close as possible.
space problem.
_must_ include the provision that she be able to park her car in the
Cheers
Les
kearney(at)shaw.ca
PostPosted: Tue Oct 30, 2007 10:03 am    Post subject: Construction Sequence Reply with quote
I do not mess with "She who must be obeyed". Especially when she has largely
turned a blind eye to what I am doing most free hours in the garage. Your
space saving "suggestions" shall be given the consideration they deserve....
I'll check out the intersection fairing as you suggest. It should not be a
problem as my painter wants me to fly off a few hours before painting.
Cheers
Les
LloydDR(at)wernerco.com
PostPosted: Tue Oct 30, 2007 10:53 am    Post subject: Construction Sequence Reply with quote
Les
what I did was to mount the empennage and drill and rig everything while it was just the tail cone, then I took it all apart and stored the emp until final assembly. Then that left me free to attach the tail cone and move forward.
Dan
N289DT RV10E Flying
Sent: Tuesday, October 30, 2007 12:18 PM
Hi All
Cheers
Les
PostPosted: Tue Oct 30, 2007 11:07 am    Post subject: Construction Sequence Reply with quote
The fairing he is referring to is the wing root intersection fairing and
one of the biggest pains to get right. It is just a series of trial and
fits. We had the wings painted and no paint on the fuse and still ended
up scratching the side of the fuse pretty good.
Dan
rene(at)felker.com
PostPosted: Tue Oct 30, 2007 11:33 am    Post subject: Construction Sequence Reply with quote
I can not think of any problems. After doing my final assembly, I was glade that I had fitted the tail feathers early since I was able to do it at a lower working height. I had the tail set just high enough off the ground to be able to put the rudder on. Once the airplane is on its gear, us short people need a stool to be able to do anything with the tail.
Rene' Felker
N423CF
40322
801-721-6080
Sent: Tuesday, October 30, 2007 10:56 AM
Subject: Re: RE: RV10-List: Construction Sequence
Rene
It is reassuring to know that I am not the only plan deviant on the list ... Where there ny "gotchas" to be careful about?
Cheers
Les
#40643 - Still singing the section 9 blues
Kearney(at)shaw.ca
PostPosted: Tue Oct 30, 2007 11:57 am    Post subject: Construction Sequence Reply with quote
Rene
6nbsp;
Dan made a similar suggestion E I will put the tail together first and then disassemble prior to mating the fuse and tail E
6nbsp;
Thanks for the advice E
6nbsp;
E ELes
pitts_pilot(at)bellsouth.
PostPosted: Tue Oct 30, 2007 12:12 pm    Post subject: Construction Sequence Reply with quote
Or you could erect one of these to store the parts in temporarily ......
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42211
or
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=90419
And they're on sale right now ..... which means you're saving money by
buying it! Wink
C'mon now .... she uses the same rationale, doesn't she???
Linn
leeway.
LES KEARNEY wrote:
> Hi All
> Cheers
> Les
joe(at)rvbuildernet.com
PostPosted: Tue Oct 30, 2007 4:58 pm    Post subject: Construction Sequence Reply with quote
Your build sequence is the same as I have planed
So it sounds good to me
Joe Rhodes 40744
Just starting
Rvbuildernet.com
Hi All
Cheers
Les
rnewman(at)tcwtech.com
PostPosted: Tue Oct 30, 2007 5:34 pm    Post subject: Construction Sequence Reply with quote
Joe,
I'm well into section 33 and recently completed the endurance test, sec 29. I've built in order. my wings and tail are all done. Its been a slow build kit all the way.. So far I can't see any issue. I've had my wings in long term storage and have not had to visit them once during the fuse assembly. Occansionally, I'd stop by and say howdy, but have not needed them to build from.. Note. When you do get the fuse attached to the tail cone the airplane gets very long! Also, the side steps get permanently attached somewhere around sect 32 and the thing then is kinda wide too!
Changing subjects, One of our glastars was built under a similar garage negotiation arrangement and it was so tight for space that I had to disconnect the garage door opener so she didn't accidentally try to raise the door and crash it into the tail feathers. but it all worked out fine.
Bob Newman
TCW Technologies
www.tcwtech.com
