Dave(at)AirCraftersLLC.co Guest
Posted: Thu Nov 01, 2007 10:03 pm Post subject: 496 Audio |
Marty and all,
We learned a bunch today about audio out from the Garmin 496 that could be helpftul.
I had a harness built by Stark to allow me to put audio from the power/data chord from a 2/3/496 into unswitched audio in my GMA340 audio panel. Seemed like a simple thing, but we never got any audio from the power/data chord. Audio jack, yes, data chord, no.
Turns out the audio from the power/data cable is to drive an 8 ohm speaker. I learned that by taking apart a Garmin 12V adapter/speaker and reading the back of the $.05 speaker inside: Made in China, 8 Ohms, 2/3W.
The audio panel was looking for a 600 ohm input.
Interestingly, Garmin told told both John and me that the only audio coming out of the 496, in aviation mode, was from the audio jack(3/496s have a 1/8" audio jack, which outputs XM audio, and all the warnings, as well as "Voice +" and "Voice -" wires in the power/data cable). Garmin said not even to bother trying to get audio from the Voice wires while in aviation mode. It did not exist.
Well, it does exist because it plays just fine with the speaker/12V adapter plugged in. I put the unit in sim mode and flew into a mountain. The speaker gives every warning you would expect, and the "Sound" page of the Setup menu controls the audio as you would expect.
With a jack inserted into the audio plug, the XM audio is turned off to the power/data chord but all the warnings still come through. Which is nice, because if you wire the unit per Garmin's advice, and run the audio jack into the music input of the audio panel, your terrain warnings will get muted by intercom activity or incoming transmissions. I want to know about those pesky mountains, even if it interupts music playing in the background...
Now my problem is to figure out how to convert the 8 ohm signal from the power/data chord to 600 ohms. I guess I need a transformer. I found a 8 ohm to 1000 ohm, with center tap, at radio shack...can anyone tell me if that will work? How do I wire it?
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
bobf(at)feldtman.com Guest
Posted: Fri Nov 02, 2007 4:18 am Post subject: 496 Audio |
I'd try one half the transformer. use the center tap for ground and one of the other ones. that would be 500 ohms. - pretty dang close
bobf
On 11/2/07, Dave Saylor <Dave(at)aircraftersllc.com (Dave(at)aircraftersllc.com)> wrote:[quote] Marty and all,
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
Melvinke(at)coho.net Guest
Posted: Fri Nov 02, 2007 3:59 pm Post subject: 496 Audio |
Very useful information! I am currently wiring the 496 audio/warning output
into the "music" jack of the PS4000 audio-panel. Does one tie the "voice+"
and "warning" wires together into the "tip" terminal, and the "voice -" to
the other?
Kenneth Melvin, Hillsboro, Oregon.
Posted: Sun Nov 04, 2007 9:51 pm Post subject: 496 Audio |
I'm afraid I'm not familiar with the PS audio panel. I do know in the past
they have been far more willing to help make weird things work than Garmin
seems to be.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
Posted: Thu Nov 08, 2007 4:26 pm Post subject: 496 Audio |
I congratulate Dave Saylor upon his excellent instructions for connecting up
the audio messages/warnings from the Garmin 496 into the audiopanel. I can
now confirm that his method, described on this list November 1st., delivers
the desired results, loud and clear.
Kenneth Melvin, RV9A,
Hillsboro, Oregon.
Posted: Fri Nov 09, 2007 1:28 pm Post subject: 496 Audio |
Thanks, Ken. I'll pass this on to Jacek, who did most of the grunt work.
Dave
