bradfnp(at)msn.com Guest
Posted: Sat Nov 03, 2007 1:51 pm Post subject: A6, A7 Rivets? |
Does anyone on the list know if A6 or A7 exist? I have two holes that are
oversized to the point that an A5 won't fit. The holes are inaccessible to
put any type of backing plate in so my only(?) option is an oversized rivet?
Can anyone help?
-Brad Cohen
XL-TD working on wings
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Sat Nov 03, 2007 2:24 pm Post subject: Re: A6, A7 Rivets? |
Where are the oversize holes located?
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
planecrazydld(at)yahoo.co Guest
Posted: Sat Nov 03, 2007 2:31 pm Post subject: A6, A7 Rivets? |
please remember that as the hole/rivet size goes up so does the edge distance requirement...
Dave Downey
Harleysville (SE) PA
100 HP Corvair
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Sat Nov 03, 2007 2:40 pm Post subject: Re: A6, A7 Rivets? |
I just bought some A6's from Aircraft Spruce. Got them the other day. Good quality.
Look here for info about A6's: http://forums.matronics.com/viewtopic.php?t=33918
I don't know about A7's.
Patrick
XL/Corvair
jeffrey_davidson(at)earth Guest
Posted: Sat Nov 03, 2007 4:34 pm Post subject: A6, A7 Rivets? |
Can anyone help?
A6 rivets certainly exist. A few came with my HD kit. ZAC sells them too.
In an old note from Nick that I re-read recently looking for the HD VDO
sender instructions (which I eventually found by the way) Nick indicated
that A5 rivets commonly are used when the holes for A4 rivets are elongated
or drilled oversize, but that A6 rivets are rarely used when a hole for an
A5 is oversize. The question then becomes "Should you use a bolt?"
Jeff Davidson
CH601 HD/Jabiru 3300/working on fuel system ...
Posted: Sat Nov 03, 2007 5:11 pm Post subject: A6, A7 Rivets? |
Tim,
Leading edge nose rib #4, bottom skin holes #6 & 7 measured frmo the spar. I
used A5's throughout for additional strength, but now have elongated these
two holes
-Brad
professor71(at)HOTMAIL.CO Guest
Posted: Sat Nov 03, 2007 6:05 pm Post subject: A6, A7 Rivets? |
Have you considered using another type of rivet other than Avex? Perhaps you could find a cherry max rivet to fit. If you can not get a backing plate on a rivet how can you get a nut on the bolt or were you were thinking of a rivnut?
John
[quote] From: jeffrey_davidson(at)earthlink.net
Subject: RE: Zenith-List: A6, A7 Rivets?
Date: Sat, 3 Nov 2007 20:31:46 -0400
--> Zenith-List message posted by: "Jeff " <jeffrey_davidson(at)earthlink.net>
Can anyone help?
Jeff Davidson
CH601 HD/Jabiru 3300/working on fuel system ... ========================Climb to the top of the charts! Play Star Shuffle: the word scramble challenge with star power. Play Now! [quote][b]
Posted: Sun Nov 04, 2007 3:50 am Post subject: A6, A7 Rivets? |
John
I agree, someone on the list had suggested a nut but there is no access
(bottom of nose rib #4) I thought about a cherrymax but wanted the lists'
opinion first. I think I will order a few A6's and a few cherrymax to see
which fits best. can you seat a cherrymax rivet with the same rivet puller
that we are using for the A4 and A5's??
-Brad
| Quote: | From: john H <professor71(at)HOTMAIL.COM>
Reply-To: zenith-list(at)matronics.com
To: <zenith-list(at)matronics.com>
Subject: RE: A6, A7 Rivets?
Date: Sat, 3 Nov 2007 22:02:48 -0500
John
are
to
rivet?
> Can anyone help?
too.
elongated
an
> Jeff Davidson
http://club.live.com/star_shuffle.aspx?icid=starshuffle_wlmailtextlink_oct
GLJSOJ1
Joined: 18 Aug 2007 Posts: 82 Location: Chesapeake, Virginia
Posted: Sun Nov 04, 2007 5:19 am Post subject: A6, A7 Rivets? |
HI JEFF
THAT IS WHAT I HAVE TO DO ON ONE MOUNT FOR A ELECTRIC TERMINAL BLOCK. WHEN I RIVETED IT IT BROKE THE BLOCK, SO I'M JUST GOING TO USE A WASHER HEAD SCREW AND NUT. IT IS FAIRLY ACCESSABLE ON THE FIREWALL THOUGH.
GLENN
| Quote: | From: professor71(at)HOTMAIL.COM
.ExternalClass .EC_hmmessage P {padding:0px;} .ExternalClass EC_body.hmmessage {font-size:10pt;font-family:Tahoma;}
John
| Quote: | From: jeffrey_davidson(at)earthlink.net
Can anyone help?
Jeff Davidson
Climb to the top of the charts! Play Star Shuffle: the word scramble challenge with star power. Play Now! | Quote: |
arget=_blank>http://www.matronics.com/Navigator?Zenith-List
_________________ 601XL N676L FLYING PHASE I
CHESAPEAKE VA |
aeroads(at)comcast.net Guest
Posted: Sun Nov 04, 2007 5:27 am Post subject: A6, A7 Rivets? |
If you have access to buck a solid rivet its diameter will expand more than a pulled rivet and may fill the hole. Try a sample by drilling a test piece to your oversize, buck one
Posted: Sun Nov 04, 2007 6:19 am Post subject: A6, A7 Rivets? |
Brad
Yes you can...
| Quote: | | >can you seat a cherrymax rivet with the same rivet puller >that we are using for the A4 and A5's?? -Brad |
Boo! Scare away worms, viruses and standard/en-us/purchase/trial.aspx?s_cid=wl_hotmailnews' target='_new'>Try now! [quote][b]
Jeyoung65(at)aol.com Guest
Posted: Sun Nov 04, 2007 7:09 am Post subject: A6, A7 Rivets? |
Why would you use the head that reforms the head (as with A-4 and A-5) when the CherryMax has a flat head and is not made from alum. The CherryMax head will not be reformed. Use a flat head. Jerry of Ga
See what's new at AOL.com and
dredmoody(at)cox.net Guest
Posted: Sun Nov 04, 2007 7:19 am Post subject: A6, A7 Rivets? |
I probably didn't get the problem straight in my head but couldn't you buck a solid rivet there before closing the top of the nose skin (or is the nose skin already closed?)? In any case, a few "other" rivets are not likely to be the end of civilization as we know it. As long as they are aluminum rivets, no problems. If you use steel, you'll want to dip them in primer when setting them (galvanic corrosion protection). If it is a dome head rivet, just pull it with a flat nosepiece as if you were flush setting an A4 or A5 rivet.
Dred
wjones(at)brazoriainet.co Guest
Posted: Sun Nov 04, 2007 7:52 am Post subject: A6, A7 Rivets? |
Did you consider putting an A5 rivet next to the enlarged hole and using a flller in the enlarged hole.
Wade Jones South Texas
601XL plans building
Cont. 0200
Posted: Sun Nov 04, 2007 8:58 am Post subject: A6, A7 Rivets? |
To All,
I had to drill out rivets in the nose skin and nose ribs to replace a (ahem)
damaged spar cap...(don't ask) and that's how the holes got misshapen. I
dont have internal access to use a nut and bolt or to buck a solid rivet
because the leading edge is closed, save for these few rivets.
I will order cherry max rivets and A6's in various sizes to get the best fit
then use my standard rivet puller to seat them. (looks like Aircraft Spruce
has a decent selection) Thanks for the heads up about cortec-ing the
individual rivets.
-Brad Cohen
John
are
to
rivet?
> Can anyone help?
too.
elongated
an
> Jeff Davidson
dekano
Posted: Thu Nov 08, 2007 11:32 am Post subject: A6, A7 Rivets? |
There are A6 types, but never have heard about A7s.
dekano wrote:
Dekano
tomtafcor(at)triton.net Guest
Posted: Thu Nov 08, 2007 11:41 am Post subject: A6, A7 Rivets? |
Zenith has A6's.
grs-pms(at)comcast.net Guest
Posted: Thu Nov 08, 2007 4:10 pm Post subject: A6, A7 Rivets? |
A6s certainly do. A few were included in my 601HD kit.
George
