Jaybannist(at)cs.com Guest
Posted: Sat Nov 03, 2007 6:02 pm Post subject: Oil Access Door |
I am now contemplating the access door to get to the dip stick on my 601XL with WW Corvair engine. I have some ideas, but I would like to see what others have done, learn from your experience and maybe get it right the first time. I've had enough "do-overs" already, thank you.
Jay in Dallas
Posted: Sat Nov 03, 2007 6:32 pm Post subject: Oil Access Door |
What's wrong with William Wynne's standard cowling? Four quarter-turn
fasteners release the top right cover which exposes the dip stick. Pictures
attached of William's tail-dragger. Somebody (Bill Clapp?) bent his and
brought it out through the hole in the cowl. But I bet the standard
alternator position might block that.
-- Craig
Description: |
Filesize: |
118.36 KB |
Viewed: |
433 Time(s) |
Description: |
Filesize: |
106 KB |
Viewed: |
444 Time(s) |
Posted: Sun Nov 04, 2007 8:26 am Post subject: Oil Access Door |
Hi Jay,
I put in a door that's easy to make for the fiberglass cowling. Using
fine jigsaw blades in an Exacto blade holder, you can manually cut a
very fine door
from the cowl itself and then remount it on a frame plate and hinge with
Dzus fasteners. See link,
http://www.macsmachine.com/images/cowling/full/cowlaccessbaseplate2.gif
http://www.macsmachine.com/images/cowling/full/cowloilaccess2.gif
http://www.macsmachine.com/images/cowling/full/cowloilaccessopen2.gif
http://www.macsmachine.com/images/completion/full/601ezfrontright.gif
Good luck,
Jaybannist(at)cs.com wrote:
Jay in Dallas
Gig Giacona
Posted: Mon Nov 05, 2007 7:42 am Post subject: Re: Oil Access Door |
I'm with Craig on this one. The WW cowling really doesn't need another hole in it.
Jaybannist(at)cs.com wrote: | I am now contemplating the access door to get to the dip stick on my 601XL with WW Corvair engine. I have some ideas, but I would like to see what others have done, learn from your experience and maybe get it right the first time. I've had enough "do-overs" already, thank you.
Jay in Dallas |
601XL Under Construction
