wcurtis(at)nerv10.com Guest
Posted: Sun Nov 04, 2007 5:56 pm Post subject: Vans RV-10 Parking Brake kit |
Is builder David Ward on this list? I see Vans has added a parking brake kit to the accessories catalog. According to the description, the kit was developed by him. Can someone tell me what is in this kit that they are charging $179? The text says "Everything is included except for the valve (BRAKE PARKING PV-1), and a CT A-740 type cable to operate the valve."
http://www.vansaircraft.com/cgi-bin/catalog.cgi?&browse=airframe&product=parking_brake-kit
This is my setup.
http://wcurtis.nerv10.com/08fuselage/fuselage38o.html
Total cost WITHOUT the PV-1 ($107.95) and T handle cable from Spruce for $17.90, about $8.
1 - F-1048; included
2 - K1000-3 = 1.36
2 - AN3-11A = $0.36
4 - AN816-4D = $5.44
The total for my setup is $134, including the PV-1 and T handle cable.
William
http://nerv10.com/
dlm46007(at)cox.net Guest
Posted: Sun Nov 04, 2007 6:30 pm Post subject: Vans RV-10 Parking Brake kit |
do not know what is included but the only things required are the matco
parking brake valve (PV1) and the cable and a couple of adel clamps. Of
course you have to fabricate a bracket from some scrap aluminum. $180
without the cable and valve is BAB (beyond all belief)
westexflyboy
Posted: Sat Mar 21, 2009 10:59 pm Post subject: Re: Vans RV-10 Parking Brake kit |
| wcurtis(at)nerv10.com wrote: | Can someone tell me what is in this kit that they are charging $179?
William
http://nerv10.com/ |
If you're like me - devastated and losing sleep because I forgot about the parking brake until after I had already installed the complete brake system according to the plans - the David Ward adapter kit from Van's is FANTASTIC!. Simply drill out eight rivets (i.e. remove the bracket that mounts the AN brake fittings to the firewall) and rivet this beautifully machined anodized bracket in the same holes. No drilling through stainless steel. All countersinking already done and nutplates already installed. It comes with all the right fittings and hardware with no trial and error, and no research required, and no modification to my brake lines that I proudly fabricated exactly per plans. Well worth the price IMHO. I did miss out on the satisfaction of solving the parking brake challenge on my own.
Kudos to David Ward, whoever and where ever you are!
_________________ Chase Snodgrass
Presidio, Texas
www.flybigbend.com
Simultaneous RV-10 twins under construction |
pascal(at)rv10builder.net Guest
Posted: Sun Mar 22, 2009 9:24 am Post subject: Vans RV-10 Parking Brake kit |
This was asked a while ago by william and he was asking how it can justify
so much money when one can do the same thing for far less.
No disagreement that a parking brake is needed, and doing it oneself can be
accomplished for far less without major work.
Pascal
Sent: Saturday, March 21, 2009 10:59 PM
Subject: Re: Vans RV-10 Parking Brake kit
> William
> http://nerv10.com/
Chase Snodgrass
Presidio, Texas
www.flybigbend.com
http://forums.matronics.com/viewtopic.php?p 35594#235594
AirMike
Posted: Sun Mar 22, 2009 12:24 pm Post subject: Vans RV-10 Parking Brake kit |
For those of us cheapskates - you can do it youself. Maybe not as elegant as the Ward kit , but still effective and cheeeeeeaaap
http://forums.matronics.com/viewtopic.php?t=41575&highlight=matco
See my post of 3/31/08
_________________ See you OSH '18
Q/B - sold. |
