mosquito56
Posted: Mon Nov 05, 2007 10:11 am Post subject: mounting engine with body on stands. |
I am building my plane in my backyard. I am just reaching the point where I will be putting the body on stands. I was wondering if I can mount the engine with it on stands or if I need to move it to the driveway to mount the landing gear first?
Airplane will not fit thru gate with landing gear attached.
Any thoughts?
Don
Do not archieve
_________________ Don Merritt- Laredo, Tx
Posted: Mon Nov 05, 2007 10:55 am Post subject: mounting engine with body on stands. |
I loaded a fuselage on its gear into the back of a truck when the opening
was too narrow by angling it, "hooking" first one gear leg and then the
other. Will that work with your gate or is there no room to maneuver near
the gate?
Also without the engine on the fuselage is light enough to just pick up and
lift over the gate.
-- Craig
Gig Giacona
Posted: Mon Nov 05, 2007 11:13 am Post subject: Re: mounting engine with body on stands. |
Jay B has mounted his engine without the fuselage being on the gear.
I would suggest that you do the required fitting of the gear because, at least with mine, it required several "on and off" evolutions. I'd hate to think of doing it with 200 lbs of engine on front.
| mosquito56 wrote: | I am building my plane in my backyard. I am just reaching the point where I will be putting the body on stands. I was wondering if I can mount the engine with it on stands or if I need to move it to the driveway to mount the landing gear first?
Any thoughts?
Don
Do not archieve |
601XL Under Construction
Posted: Mon Nov 05, 2007 11:21 am Post subject: mounting engine with body on stands. |
| Quote: | Also without the engine on
Make that "engine off"
-- Craig
Jaybannist(at)cs.com Guest
Posted: Mon Nov 05, 2007 12:10 pm Post subject: mounting engine with body on stands. |
Jay B also had his gear fabbed and fitted to the fuselage before mounting the engine. He fitted the gear by raising and lowering the gear for fitting, not raising and lowering the fuselage. He will do the same when installing the gear. The gear is not installed because of space limitations in the construction "hanger." (Garage) You could probably do the same.
He (alias Jay in Dallas)
"Gig Giacona" <wr.giacona(at)suddenlink.net> wrote:
> Any thoughts?
> Don
> Do not archieve
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=144007#144007
Gig Giacona
mosquito56
Posted: Mon Nov 05, 2007 4:03 pm Post subject: Re: mounting engine with body on stands. |
I always thought it was considered normal for nobility.
Don
glenn.d.morris(at)lmco.co Guest
Posted: Tue Nov 06, 2007 5:39 pm Post subject: mounting engine with body on stands. |
I need to get this list reset. I only want to get the digest.
Glenn Morris
Gig Giacona
Posted: Wed Nov 07, 2007 6:23 am Post subject: Re: mounting engine with body on stands. |
Glenn, you will need to follow the link down at the bottom of one of the e-mails your receive, sign in and make the desired changes.
You also have the option of reading it via the Web forum available here. http://forums.matronics.com
| glenn.d.morris(at)lmco.co wrote: | I need to get this list reset. I only want to get the digest.
Glenn Morris |
mosquito56
Posted: Fri Nov 09, 2007 1:52 pm Post subject: Re: mounting engine with body on stands. |
What could that possible have to do with the subject of Mounting engines. How could anyone think this was the place to inquire about getting another type of list.
LETS TRY TO STAY ON SUBJECT PLEASE!!!!!
