Albert Gardner
Posted: Tue Nov 06, 2007 9:18 pm Post subject: High Oil Temp |
Still working on getting oil temp down but a friend told me that the screen
on the SCAT tube at the back baffle heading down to the oil cooler might
impede the airflow a bit so I cut it out to see. Gives me about 8 or so
degrees I think. Now I'm going to look at that area a bit more.
For what it's worth went up this morning to see what removing the screen
would do and collected these numbers in cruise:
OAT 72, 3500', MAP 23", RPM 2300, oil 231F, GPH 16.8, 155kt. I better get
those wheel pants on too see what the top speed will be. Climb out from Yuma
(180' MSL) was 2200 FPM. Wow! Hit pattern altitude at the end of the runway.
Keep building.
Albert Gardner
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
AirMike
Posted: Tue Nov 06, 2007 10:42 pm Post subject: High Oil Temp |
It might be a pricey remedy, but how about Alex's higher capacity oil cooler? Especially in the Central and souther tier of the country it might not be bad to add 20% to the cooling capacity of the oil cooler
_________________ See you OSH '18
Q/B - sold. |
Albert Gardner
Posted: Wed Nov 07, 2007 7:14 am Post subject: High Oil Temp |
I'm not familiar with this oil cooler-do you know who carries it?
Albert Gardner
Yuma, AZ
RV-10 N991RV |
Posted: Wed Nov 07, 2007 7:35 am Post subject: High Oil Temp |
Al,
Heres the link.
http://www.aviationtechproducts.com/
Rick S.
40185
Deems Davis
Posted: Wed Nov 07, 2007 7:36 am Post subject: High Oil Temp |
Al, It's the one made by Airflow Performance. You can buy it direct form
them http://www.airflow-systems.com/ or you can buy it from Alex D.
Gary Foster put one on his RV-10 in OK. and reported a drop in oil temps
vs Van's stock cooler. I ordered and received one, but haven't installed
it yet. It's a bolt on replacement, the difference is that it has
significantly more cooling vanes (those zig-zag do-higgies).
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
Albert Gardner
Yuma, AZ
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Wed Nov 07, 2007 8:17 am Post subject: Re: High Oil Temp |
Is the 2006X big enough for a stock 260 HP or are most people going with the 2008X for the extra cooling capacity? (I'm in Oklahoma)
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Deems Davis
Posted: Wed Nov 07, 2007 2:43 pm Post subject: High Oil Temp |
Unless you've come up with an ingenuous way to mount it I don't think the 2008x will fit.
Deems
---- orchidman <gary(at)wingscc.com> wrote:
Gary Blankenbiller
RV10 - # 40674
Fuselage SB
(N410GB reserved)
http://forums.matronics.com/viewtopic.php?p=144419#144419
drfred(at)suddenlinkmail. Guest
Posted: Wed Nov 07, 2007 2:44 pm Post subject: High Oil Temp |
Gary;
I'm just south in Paris, Texas and went for the better cooling oil
cooler. Anything to keep the life blood of the engine as cool as
possible.
Dr Fred
orchidman wrote:
Gary Blankenbiller
RV10 - # 40674
Fuselage SB
(N410GB reserved)
mritter509(at)msn.com Guest
Posted: Wed Nov 07, 2007 3:11 pm Post subject: High Oil Temp |
I ordered the 2008X about two months ago. It's considerably bigger than the bolt on replacement 2006X and will not mount on the firewall due to engine mount interference. I sent the 2008X back and installed the 2006X. The oil temps went down about 8 degrees. Also can climb at higher VS with the new cooler. They did tell me if and when they figure out how to mount the 2008X in the RV-10 there would be a good trade-in arrangement.
Mark
RV-10/N410MR
Austin, Texas
<html><div></div></html>
> Subject: Re: High Oil Temp
Climb to the top of the charts! Play Star Shuffle: the word scramble challenge with star power. Play Now! [quote][b]
AV8ORJWC
Posted: Wed Nov 07, 2007 3:35 pm Post subject: High Oil Temp |
This would be a great time for someone to reach out to James McClow and get him to post an opinion on Static pressure changes in the airflow, both into and out of the stock VANS or 2006X coolers. Restrictions reduce airflow which is not a good thing. A composite duct (replacing SCAT tubing) and some simple mods should produce noticeable improvements to oil heat exchanger efficiencies. It is obvious as to why it is generally mounted where it is, however, the serpentine routing does not lead to efficiencies of operation.
Does anyone have his email address?
John
RV10 – #40600
Aurora, OR
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mark Ritter
Sent: Wednesday, November 07, 2007 2:57 PM
Subject: RE: Re: High Oil Temp
Mark
RV-10/N410MR
Austin, Texas
> From: gary(at)wingscc.com
> Date: Wed, 7 Nov 2007 08:17:39 -0800
> To: rv10-list(at)matronics.com
> --> RV10-List message posted by: "orchidman" <gary(at)wingscc.com>
> Gary Blankenbiller
> RV10 - # 40674
> Fuselage SB
> (N410GB reserved)
Climb to the top of the charts! Play Star Shuffle: the word scramble challenge with star power. Play Now! [quote] [b]
msausen
Posted: Thu Nov 08, 2007 7:58 am Post subject: High Oil Temp |
Pacific Oil Coolers also has options for replacing the stock Niagara.
Michael
orchidman
Posted: Thu Nov 08, 2007 9:21 am Post subject: Re: High Oil Temp |
| mritter509(at)msn.com wrote: | I ordered the 2008X about two months ago. It's considerably bigger than the bolt on replacement 2006X and will not mount on the firewall due to engine mount interference. I sent the 2008X back and installed the 2006X. The oil temps went down about 8 degrees. Also can climb at higher VS with the new cooler. They did tell me if and when they figure out how to mount the 2008X in the RV-10 there would be a good trade-in arrangement.
Mark |
Thanks Deems, Fred and Mark. It's good to know exactly the models that will and will not fit. Want to get it right the first time around.
RV10 - # 40674
(N2GB Flying) |
