nuckolls.bob(at)cox.net Guest
Posted: Thu Nov 08, 2007 4:16 pm Post subject: Tyco and all its problems |
Sorry your having so much trouble with this procurement
my friend. Allied Electronics, for one, carries the
Kilovac series devices. The catalog page is:
http://tinyurl.com/3e3hyj
I believe you want the Allied Stock #433-0016,
Kilovac Model EV200AAANA, Tyco part #1618002-7
The part you have may be this same part.
The data sheet for this part can be had at:
http://relays.tycoelectronics.com/datasheets/ev200.pdf
It shouldn't be hard to confirm with a multimeter
that your holding current is on the order of .15A
Hope this helps.
At 09:58 AM 11/8/2007 -0500, you wrote:
Perhaps someone can give me direction in a particularly troublesome regime.
I refer to "TYCO". At somebody's suggestion, I dialled up:
http://relays.tycoelectronics.com/datasheets/ev200.pdf,
which gave me a somewhat expensive solution to the low output of the Rotax
dynamo on my 914. Its advantage was to reduce the holding current to a
large contactor to a small percentage of one Amp. I believe Ron Parigoris
was the source of my info, but others had added to the list as well.
The info sheet gives the description of the device as -
"TYCO EV200 series contactor with 1 form A (SPST-NO)" and under the photo
is:
"EV200 Series Contactor
(CZONKAR Relay, Type III)". What the significance of the 'Czonka ' is, is
left to the customer to divine.
I attempted to order a copy from the Canadaian office, which after 10
minutes of opting button 1 or other, left me talking to a clerk who admitted
no knowledge of contactors. I then tried to order from the US office and got
another series of button choices which promised technical assistance and
delivered only the names of 6 women with no hint of their duties - all of
this on long distance. I finally managed to find a sales clerk somewhere in
USA who promised to deliver the required contactor and yesterday I picked it
up in NY and paid the requisite duties and import tariffs only to find that
it bears no connection with the above, but boasts a "GIGAVAC GX11BAA" tag. I
have no idea what its holding current is, [try to find a column on the spec
page which lists that] nor can I find anyone (human that is) who is willing
to clarify the discrepancy.
Failing education from Bob or Ron - or any other kind correspondent
- I am going to recommend staying a hundred miles from
TYCO/CZONKA/KILOVAC/GIGAVAC and its myriad ancillaries.
Cheers, Ferg
Drdavevk30(at)cs.com Guest
Posted: Sat Nov 10, 2007 10:56 pm Post subject: Tyco and all its problems |
These EV200 contactors are available from electronics suppliers. I got mine online from Newark electronics. They had several configurations in stock.
Dave Doucette
drdavevk30(at)cs.com
"Fergus Kyle" <VE3LVO(at)rac.ca> wrote:
is:
Cheers, Ferg
dballin
Posted: Sun Nov 11, 2007 7:45 am Post subject: Re: Tyco and all its problems |
Another solution is Gigavac. Their GX11 is basically the same as the Tyco ev200, but less expensive.
http://www.gigavac.com/products/relays/gigavac/index.htm
I had a very good experience ordering from them. They evidently are a bunch of ex Tyco people, are very knowledgeable and friendly.
Dan Ballin
Legacy #286
Posted: Sun Nov 11, 2007 8:43 am Post subject: Tyco and all its problems |
dballin a écrit :
Dan,
It seems the GX11 hold current is about 700 mA, whereas the EV200 is 140
mA....
Or am I missing the obvious ?
Best regards,
Gilles
http://contrails.free.fr
Eric M. Jones
Posted: Mon Nov 12, 2007 8:41 am Post subject: Re: Tyco and all its problems |
Gilles, You didn't miss anything. The reasons for using the EV200aaana or the GX11 are more than just hold current. (Gigavac also has a lower hold current model if you ask)
This is mostly a repost.
Compare---
____________________Type 70__________GX-11
Weight.........................12.5 Oz.............18 Oz
Temp...........................50 DegC...........75-85 DegC
(50 degC 122 F) makes the type 70 unusable....
Position........................Cap Down..........Any
Environmental...............Dust-Proof.........Hermetically sealed
Coil Suppression............Must be added....Built in
B&C Type 70 uses diodes, GX-11 uses transorbs (SnapJacks!)
Continuous Amps............80 at 50C..........150A at 75C
Inrush A.........................150...................500-2000
Open against Vmax.......... 35V.................>>100V
(...same as Kilovac)
Hold current.....................1.0 A................700 mA
(Kilovac is 100 mA, Gigavac has lower hold currents on request)
G-force opening...............2G ??................>>10G
Anyway the GX11 will be about $120, but the Type 70 ($37.00 from Newark) is not really useable in my opinion. You may want the accessory contacts and long leads...couldn't hurt.
The Kilovac EV200aaana (aka Blue Sea 9012) is still great (similar to the Gigavac GX11).
The type 70 is problematic even if very common and long in the tooth. It is deficient in four main areas:
1) Poor coil suppression (this can be retrofitted to improve it)
2) Inadequate operating temperature. My GUESS is that the early ones had fiber/bakelite interiors, now they are Nylon. Regardless 122F spec is way too low to use.
3) Inadequate G force withstand. 2G ??
4) Open against Vmax. 35V. They could sustain an arc if the alternator runs away.
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
dballin
Posted: Mon Nov 12, 2007 9:03 am Post subject: Re: Tyco and all its problems |
Gilles
You are absolutely right and my mistake. Gigavac does make a more efficient model the GX11TA 24v 45mA hold down current. You just have to ask for it!
Thanks for catching my error.
Dan Ballin
Legacy #286
Posted: Tue Nov 13, 2007 7:08 pm Post subject: Tyco and all its problems |
I presume we're discussing use of the Type 70 as an
alternator b-lead disconnect device. For use as battery
contactor (99.99% of all applications in 200,000 or
so airplanes for 60 years) the down-sides
are not so significant.
| Quote: | You may want the accessory contacts and long leads...couldn't hurt.
Gigavac GX11).
Not "poor" but "no" coil suppression as a factory installed
feature. This is typical of the majority of contactors and relays
on the market. It's presumptuous for a manufacturer to
include coil suppression out-of-hand . . . this should
be left up to the system integrator. Tests
here have shown that the simple diode arc
suppression offers no significant effects
on relay/contactor service life.
See:
http://www.aeroelectric.com/Pictures/Curves/704-1DelayNoDiode.gif
http://www.aeroelectric.com/Pictures/Curves/704-1DelayWithDiode.gif
http://www.aeroelectric.com/Pictures/Curves/704-1OpeningTimeNoDiode.gif
http://www.aeroelectric.com/Pictures/Curves/704-1OpeningTimeWithDiode.gif
| Quote: | 2) Inadequate operating temperature. My GUESS is that the early ones had
too low to use.
. . . under the cowl perhaps. Unless irradiated
by exhaust stack IR, parts under the cowl spend
very little time in a 122F environment . . . and
the most striking scenarios involve hot-soak of
airspace under the cowl after engine shutdown.
Under this scenario, the b-lead contactor is
de-energized which eliminates a large source
of temperature rise energy, internal coil
dissipation. These contactors have been used
successfully on the firewall of thousands of
aircraft.
Where does this come from and of what
significance? I found no manufacturer's
data limiting acceleration. Since inflight
g-loading is applied while the contactor
is energized, g-loads are not an issue
for as-installed performance. I'll have
to dig through the archives but I believe
tests showed that it takes 4+ G of linear
acceleration to close a de-energized contactor.
| Quote: | 4) Open against Vmax. 35V. They could sustain an arc if the alternator
runs away.
Don't know where "35" comes from, it depends
on lots of variables not characterized by
White Rogers in the data sheets. Yes, if
the contactor is called upon to do a real
OV shutdown, there is a risk with current
designs that an arc will establish between
spreading contacts and continue to destruction
of the contactor as well. However, it poses
no little if any risks to the rest of the system.
But an investigative goal I have for this
winter when the drive stand . . .
http://www.aeroelectric.com/Pictures/Alternator_Test_Stand/DSCN0961.JPG
. . . is running will be to see if I can deliberately
precipitate meltdown in an S701 contactor.
Irrespective of this yet to be demonstrated condition,
the AEC9004 . . .
http://aeroelectric.com/articles/Adapting_IR_Alternators_to_Aircraft.pdf
will keep dv/dt stresses on the low-cost contactor
well within its design limits. I've had two readers
comment on conducted noise emissions from EV200
contactors . . . so all is not 'golden' with
the $high$ contactors.
Test plans for the repeatable experiment are in
place. We'll be able to convert WAGs and hypothesis to
demonstrable working practice in the not too distant
future.
