				 Posted: Mon Nov 12, 2007 8:47 am    Post subject: Removal of fuel tank access panel |
				Has anyone on one of their RVs had to remove a fuel tank access panel(the
 ones Van's sells, The twelve screw hole, thick plate). I placed mine on with
 a proseal and I am considering removal. but I think due to the tight fit and
 the proseal acting as a very strong adhesive, and due to the limited access,
 it might be a lot of trouble getting the plate off.
 Someone suggested using a heat gun to loosen the proseal but, that did not
 appear to do anything on a test piece of proseal and it would affect the
 proseal that is beneath the structural reinforcing plate around the opening.
 Ideas?
 John G. 409
		n277dl
				 Posted: Mon Nov 12, 2007 10:14 am    Post subject: Re: Removal of fuel tank access panel |
				John,
   I've taken the plate of off the -7A that was prosealed on (actually have done this a couple times).  Ended up not being a big deal.  Just take the screws out (I used some allen head screws which made taking them out much easier on the 7) and use a putty knife or something similar to get started.  Once it starts just work around the edge prying a little and the proseal will turn loose.
 Doug....  riveting the tailcone together.... soon will be waiting on QB Fuse and wings.
  _________________ Doug
"Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. |
				 Posted: Mon Nov 12, 2007 11:29 am    Post subject: Removal of fuel tank access panel |
				Thanks for the heads up.
 I bought some exacto blades shaped likes a chisel head, but still leaves the
 access between the skin flanges and the tank attachment angles a slight
 issue with the blade handle.
 Hopefully it will be easier than my mind is imagining it.
 John
  	  | Quote: | 	 		  From: "n277dl" <dljinia(at)yahoo.com>
 Subject: Re: Removal of fuel tank access panel
 Date: Mon, 12 Nov 2007 10:14:10 -0800
 John,
 will turn loose.
 Fuse and wings.
 Doug
 RV7A flying ~500hrs
 http://forums.matronics.com/viewtopic.php?p=145440#145440
		n8vim(at)arrl.net Guest
				 Posted: Mon Nov 12, 2007 12:22 pm    Post subject: Removal of fuel tank access panel |
				Use a PLASTIC putty knife...  works well, doesn't carve out aluminum!
 Also, it will avoid the wrath of J.C.
 -Jim 40384
 n277dl wrote:
 John,
 Doug
 RV7A flying ~500hrs
		rv10(at)sinkrate.com Guest
				 Posted: Mon Nov 12, 2007 1:18 pm    Post subject: Removal of fuel tank access panel |
				Just a reminder... anyone removing proseal should use extreme caution to
 avoid scratching the underlying aluminum.  Use plastic tools.
 I am always somewhat paranoid of scratches as I had an elevator spar on my
 Cessna 152 crack do to a scratch.  Good thing my A&P noticed a small bit of
 flex in the elevator hinge points on an annual and wouldn't let it slide.  I
 can imagine elevator spar failure in flight will ruin your day and probably
 those below you as well.
 -Ben
		Kellym
				 Posted: Mon Nov 12, 2007 3:32 pm    Post subject: Removal of fuel tank access panel |
				You might also consider using the non-hardening version of PRC for
 resealing the access panel. That is what Mooney specifies for their
 access panels.
 James Hein wrote:
  -Jim 40384
KCHD |
		AV8ORJWC
				 Posted: Mon Nov 12, 2007 7:32 pm    Post subject: Removal of fuel tank access panel |
				Use of a metal putty knife is a "Termination Offence" at work (Spelling
 is Canadian cause the planes are designed by French Canadians.  The
 damage inflicted on aluminum skin quickly exceeds the 10 to 15% damage
 depth permitted to be blended smooth after scrapping.  Plastic scrappers
 are given out by the dozens.
 We remove easily 100 panels per night using fiberglass reinforced
 plastic scrapers. Teams of guys "Lay to" the process to get at the
 goodies needing fixing below the covers.
 Skin knives are contraband yet some have them hidden to use leverage
 after the perimeter seal is broken with plastic scrapers.  Boeing
 surplus and Ebay have been a source of all things connected with
 sealant.
 John Cox
		AV8ORJWC
				 Posted: Mon Nov 12, 2007 7:55 pm    Post subject: Removal of fuel tank access panel |
				"The Tree of Life is Self Pruning". (No disrespect intended).
 If a builder is not aware of why aluminum edges and drilled rivet holes
 need deburring, then why the use of a metal scraper can condemn the skin
 to replacement is a waste of words.  Of the 800 RV-10 builders, at least
 100 must be using primitive tools from their woodworking days.  Leave it
 to an RV-7A builder to turn on the light to this age old problem.  Why
 not just use a screwdriver and hammer and get it over with.  And James,
 I did not shout.
 Be diligent, Build Safe, Fly Often, Fly Safe, Live long.
 Off to work with my plastic scrapers in hand.
 John C.
 Do not Archive
		n277dl
				 Posted: Mon Nov 12, 2007 8:24 pm    Post subject: Re: Removal of fuel tank access panel |
				John,
   Thanks for reminding me why not to post to these boards.  I do certainly appreciate your wisdom in correcting the errors of my ways as I don't desire to steer anyone wrong.
 Doug
 RV-7A flyer and -10 builder
