		| Author | Message |
		| MJKTuck(at)cs.com Guest
				|  Posted: Fri Nov 16, 2007 7:15 pm    Post subject: Digital Readout Engine Gauges |   |
				| Hi Folks,
 I have a row of Mitchell Engine Instruments and have often thought about
 changing them to something with a digital readout. I sit and wait for
 that Oil Temperature needle to point (somewhere close to) 120 deg and
 think it would be neat to actually see the temperature is creeping up
 and maybe be a bit more accurate.
 I was looking online and found some possibilities in the custom auto
 industry.
 Anyone in the US tried any of these?
 The Dakota Digital ones have upper limits suitable for a Rotax, the
 Cyberdyne ones come up a bit short. Both have limits you can set so the
 displays flash as a warning. They seem pretty neat to me.
 Check out:
 http://cyberdynegauges.net/temperaturegaugesproduct.php
 http://www.dakotadigital.com/index.cfm/page/ptype=results/Category_ID 62/home_id=59/mode=cat/cat262.htm
 Comments? Any other suggestions?
 Martin Tuck
 Europa N152MT
 Wichita, Kansas
		| Back to top |  |
		| craigb(at)onthenet.com.au Guest
				|  Posted: Fri Nov 16, 2007 8:23 pm    Post subject: Digital Readout Engine Gauges |   |
				| doesnt say if you can get them in deg c, which i would want, and i wonder
how accurate that compass is, other than that they look ok to me
 the egt is about half the price of a digital aero one, so price is good
 craig
		| Back to top |  |
		| europa flugzeug fabrik
				|  Posted: Sat Nov 17, 2007 5:20 am    Post subject: Re: Digital Readout Engine Gauges |   |
				| Any engine instrumentation we buy has to be compatible with the Rotax temp and pressure senders.
 Fred F
		| Back to top |  |
				|  Posted: Sat Nov 17, 2007 5:58 pm    Post subject: Digital Readout Engine Gauges |   |
				| From what I can see they do require their own senders but they appear
to be identical in size/thread, etc.as the Rotax ones so switching them
 doesn't appear to pose a problem.
 Martin
 europa flugzeug fabrik wrote:
  	  | Quote: |  	  |
 Fred F
		| Back to top |  |
		| M.Grass(at)comcast.net Guest
				|  Posted: Sat Nov 17, 2007 8:58 pm    Post subject: Digital Readout Engine Gauges |   |
				| Martin,
 Be aware that only numerical displays impose additional workload to the
 pilot. You would actually have to read the number and the brain has to
 process the numbers and compare them mentally.
 In your case, I would look for some instruments with a combined analog and
 digital representation in one instrument.
 Example is at
 http://www.sportflyingshop.com/Instr/Stratomaster/SmartSingles/smartsingles.html .
 The nice thing about digital once is that many have a monitoring feature and
 will ring an alarm when certain programmed levels are exceeded.
 You find also nicer looking once in the automotive and aviation industry if
 you look further.
 Advantage of analog representation is that you just need to have a short
 look at the instrument to see that all data are in the right area. Much
 quicker and less workload to the brain. This is exactly the reason why the
 digital representation in a car never took of.
 Michael Grass
 A266 Trigear
 Detroit
		| Back to top |  |
		| patkinson
				|  Posted: Sun Nov 18, 2007 1:12 am    Post subject: Digital Readout Engine Gauges |   |
				| Michael
 I am probably totally biased now but I have to disagree. I can't comment
 on any extra brain activity that may be required but having sat in front
 of several different types of digital display over a number of years I
 find them just as easy to use as analogue ones and actually prefer them.
 Probably the best type of display is one that combines the two.  I am sure
 that it aids more accurate speed control, which is no bad thing,
 particularly in low speed flight near the ground.
 My car has a digital display (no analogue) and although it took a bit of
 getting used to I am very comfortable with it now, and no longer feel that
 an analogue display is necessary at all.
 Paul Atkinson
 On Sun, 18 Nov 2007 04:53:40 -0000, Michael Grass <M.Grass(at)comcast.net>
 wrote:
  	  | Quote: |  	  | Martin,
 and digital representation in one instrument.
 Example is at
 and will ring an alarm when certain programmed levels are exceeded.
 industry if you look further.
 short look at the instrument to see that all data are in the right area.
 Much quicker and less workload to the brain. This is exactly the reason
 why the digital representation in a car never took of.
 Michael Grass
 A266 Trigear
 Detroit
		| Back to top |  |
		| ami(at)mcfadyean.freeserv Guest
				|  Posted: Sun Nov 18, 2007 2:37 am    Post subject: Digital Readout Engine Gauges |   |
				| Paul,
I agree about the car thing; but in that instance a specific number is being
 sought (i.e. speed, to enable mental comparison to a limiting speed).
 I have to say that an analogue needle pointing to a green arc can be seen
 from the corner of an eye, without need to focus, read and interpret. Much
 easier in my view. Helps if the gauges aren't mounted at the bottom of the
 panel, however.
 The alarm facility on the digital gauges is without equal, especially as
 analogue gauges probably don't get looked at very often, or not at the
 precise moment needed !
 Duncan McF.
		| Back to top |  |
				|  Posted: Sun Nov 18, 2007 3:22 am    Post subject: Digital Readout Engine Gauges |   |
				| Not sure about pilot training in the UK and US but most of the schools in
Australia
 teach students to a C.L.E.A.R.O.F.F check every 15 minutes. A LOT can happen
 to an engine
 in 15 minutes (personal experience) and an alarm IMHO is the best way to go
 as people get
 tired and thus less vigilent, and you may be checking t's & p's etc, but not
 actually
 "seeing" them regardless of the gauge style especially on longer flights,
 one option
 for analogue gauges is to align them in the same way the old race cars did,
 so all the needles should
 point straight up or down under normal conditions, that way any needle not
 vertical is instantly evident, it does however
 give your panel an odd look with all your gauges at crazy angles.
 craig
		| Back to top |  |
		| Mark Burton
				|  Posted: Sun Nov 18, 2007 3:55 am    Post subject: Re: Digital Readout Engine Gauges |   |
 In that case, why not use a talking ASI? With one of those you don't have to look at the panel at all - you can keep your eyes outside which has to be a good thing from the safety point of view if you happen to find yourself low and slow.
 Obviously, if you are a highly trained pilot who flies lots of hours in glass cockpits then digital readouts would probably be no problem but for your average pilot who doesn't fly so many hours, digital readouts would, perhaps, be less easy to read quickly than an old fashioned "steam" gauge. Maybe a digital ASI would not be a good thing but for the other instruments, it probably makes no difference from the safety point of view whether they are digital or analogue.
 Cheers,
 Mark
		| Back to top |  |
		| patkinson
				|  Posted: Sun Nov 18, 2007 5:54 am    Post subject: Digital Readout Engine Gauges |   |
				| Mark
 Why not indeed. The only drawback that I can think of is that the constant
 chatter might become very irritating. If you can design one that talks
 when asked to, shuts up when told to, and otherwise gives the odd warning
 automatically now and again you might have a winner. There's a challenge
   If anything glass displays IMHO make things easier for everyone,
 experienced or not. Most that I have seen combine digital and analogue and
 because all the information you need is contained in a smaller area
 (compared to steam gauges) scanning it is a simpler task.
 Paul
 On Sun, 18 Nov 2007 11:55:54 -0000, Mark Burton <markb(at)ordern.com> wrote:
  	  | Quote: |  	  | In that case, why not use a talking ASI? With one of those you don't have to look at the panel at all - you can keep your eyes outside which
 Cheers,
 Mark
		| Back to top |  |
		| paul.the.aviator(at)gmail Guest
				|  Posted: Sun Nov 18, 2007 6:21 am    Post subject: Digital Readout Engine Gauges |   |
				| Hi folks,
 Well I would like to share my experience with using digital only
 displays in my aircraft.  I had the exact same concern that it would
 take some level of interpretation, but I really didn't find it a
 problem at all.  I actually find it quite seamless.  The only
 exception might be when something is trending, but to be honest I
 haven't had any experiences one way or the other.
 At the end of the day I think it really depends on the individual on
 how their brain is "wired" to receive and interpret data... we are all
 different in that regard.
 Cheers,  Paul
		| Back to top |  |
		| Mark Burton
				|  Posted: Sun Nov 18, 2007 6:26 am    Post subject: Re: Digital Readout Engine Gauges |   |
 Such a thing is already available - the technology is straightforward, the real challenge is getting people to buy them!
 Cheers,
 Mark
		| Back to top |  |
		| johnwigney(at)alltel.net Guest
				|  Posted: Mon Nov 19, 2007 8:40 am    Post subject: Digital Readout Engine Gauges |   |
				| Hi Michael,
 I hope your project is progressing well. I would like to offer another opinion on digital vs. analog. When I was designing my panel, I installed a 2 1/4" analog tachometer with the rpm range markings for the 912S. I also installed a Grand Rapids EIS 2004-W, see http://www.grtavionics.com/model_2004.htm, for my engine monitoring, fuel status and annunciator requirements. I assumed that the analog gauge would be my primary reference for engine speed. Before flying the plane I had been talking with Greg Toman, the Grand Rapids Pres., and mentioned my analog tacho. His comment was "Oh, you will never use that. You will always use the EIS." My reaction was that he was incorrect since I also thought that analog readings were easier and quicker to interpret. However, I found that as soon as I started flying the plane, I never looked at the analog gauge. The EIS digits refresh very quickly and are very accurate. When I build my next panel?, it will have an EIS and no analog tacho.
 Cheers, John
 N262WF, mono XS, 912S, Whirlwind c/s prop
 Mooresville, North Carolina
 [quote]ORIGINAL MESSAGE
 Subject: Re: Re: Digital Readout Engine Gauges
 Martin,
 Be aware that only numerical displays impose additional workload to the pilot. You would actually have to read the number and the brain has to process the numbers and compare them mentally.
 Example is at http://www.sportflyingshop.com/Instr/Stratomaster/SmartSingles/smartsingles.html .
 The nice thing about digital once is that many have a monitoring feature and will ring an alarm when certain programmed levels are exceeded.
 you look further.
 Advantage of analog representation is that you just need to have a short look at the instrument to see that all data are in the right area. Much quicker and less workload to the brain. This is exactly the reason why the digital representation in a car never took of.
 Michael Grass
 A266 Trigear
 Detroit[b]
		| Back to top |  |
		| rowil(at)clara.net Guest
				|  Posted: Mon Nov 19, 2007 10:25 am    Post subject: Digital Readout Engine Gauges |   |
				| At 18/11/07 21:25 +1000 craig bastin wrote:
  	  | Quote: |  	  | most of the schools in Australia
 Craig - that's new acronym on me! I can make a guess at some of it,
 but would like to know the "authorised verion", please!
 regards
 Rowland
 | Rowland Carson  PFA #16532    http://home.clara.net/rowil/aviation/
 | 840 hours building Europa #435 G-ROWI  e-mail <rowil(at)clara.net>
		| Back to top |  |
				|  Posted: Sat Nov 24, 2007 5:31 am    Post subject: Digital Readout Engine Gauges |   |
				| C.L.E.A.R.O.F.F
 Compass and DI aligned, flying correct heading
 Location. Fix your position
 Engine, T's & P's where they should be
 Altitude. Correct for plan/heading, and current airspace clearance.
 Radio, Correct frequency, still working.
 Oxygen (pressurisation)
 Fuel, contents sufficient for remaining flight time, correct tank (if
 required)
 Flaps both wing and cowl correct
 the prelanding one ammuses most new students
 BUMFFISH
 Brakes, working
 Undercarriage, (down and locked/Fixed)
 Mixture full rich
 Fuel, pump on, contents sufficent
 Flaps set, both wing and cowl
 Instruments (T's and P's correct)
 Security, loose objects secure
 Hatches and harnesses set for landing.
 Short Final check
 PLUFF
 Pitch (full Fine)
 Landing clearance (granted / runway clear)
 Fuel, full rich, pump on, contents sufficent
 Line up check
 TWAD
 Transponder, switch to alt, squark correct.
 windsock. Crosswind estimate
 Aimpoint, for after takeoff
 DI and compass agree with runway heading.
 I am sure there are other ones that work just as well, are there any others
 people want to share
		| Back to top |  |
